Old 08-24-2007, 08:18 AM   #1 (permalink)
short angry bloke
codymac's Avatar
Images: 19
(2ZZ) dry sump?
Is there one?
From what I've seen, there's some good practical (cost-wise) solutions for the Hondas but not much available for the Toyotas outside of the 4A series engines (and those are pricey).
Is there any interest in a dry sump for the 2ZZ? Are we all too weight conscious?
Old 08-24-2007, 09:02 AM   #2 (permalink)
Boosted2.0's Avatar
If you search theres a guy in the UK that had a custom one made, but there are none comercially available
Boosted2.0 is offline   Reply With Quote
Old 08-24-2007, 11:41 AM   #3 (permalink)
Regurgitated User
fitfan's Avatar
the main benifit is that (assuming the bell housing is not a limiting factor) you can drop the engine and lower the center of gravity in the car.
so unless there is a way to do that.... not "too" much point of going dry sump. personally i am suprised the 2-11 doesn't do this?!?!
Driving it around!
Old 08-24-2007, 12:12 PM   #4 (permalink)
jamie's Avatar
The one I have seen was on a Red MS car (race car) and its quite a lot of stuff to package eg big oil tank where the boot would be. When I inquired about it they said it really was race only the belt tenson needs adjusting etc. My understanding was that you would not want to lower the motor anyway as it would increase the angles that the CV joints have to work at leading to issues.
jamie is offline   Reply With Quote
Old 08-24-2007, 12:38 PM   #5 (permalink)
Regurgitated User
fitfan's Avatar
...smaller wheels bigger gears is where its at
Driving it around!
Old 08-24-2007, 01:00 PM   #6 (permalink)
Grrrrrr Baby
Dmbrown34's Avatar
Doesnt dry sump usually gain a few HP (i.e. an honest 10 HP to the tires)?
Your crank wont have to slice through all that oil sitting there in a wet slump...same reason why people knife edge their cranks.
When your in an all motor class...ITB, Dry Slump, coated internals and fuel management make the difference.
2005 Lotus Elise LSS
2003 Corvette 50th Anniversary Convertible
Dmbrown34 is offline   Reply With Quote
Old 08-24-2007, 01:53 PM   #7 (permalink)
Makin' house calls . . .
mark.r's Avatar
You could look into the DMC oil pump kit from FF.
DRS Tuned FF275 '06 Exige - Sold
My racing prediction for '09 . . . the Japanese guy on the Italian bike and the Italian guy on the Japanese bike.
mark.r is offline   Reply With Quote
Old 08-24-2007, 03:51 PM   #8 (permalink)
The dry sump insures oil to the engine at all times. A wet sump won't do that under all possible conditions. It also pumps oil from the pan into a tank. If designed well, much or the aerated oil goes to the top of the tank, unaerated oil, at the tank bottom supplies the engine. Another benefit is better oil control for the rings. The slight crankcase vacuum causes a pressure differential for the oil rings. While oil is being scraped off the wall, the vacuum helps pull the oil through the holes or slots in the piston groove. You can run less radial tension on the oil rails and gain more power. External pumps can, of, course, be replaced, inspected, and its pressure adjusted without taking off the pan. And yes, you can also expect a power gain from not having all the oil flying around to be collided with by rotating and reciprocating parts.
MikeW is offline   Reply With Quote
Old 08-24-2007, 04:39 PM   #9 (permalink)
short angry bloke
codymac's Avatar
Images: 19
Hmmm... a bit of better searching turned this up - looks like Lotus already came up with something:
http://www.lotussportcadena.com/car_specification.asp
Note Laminova oil cooler circled in red and oil pump circled in yellow:
Old 08-24-2007, 07:18 PM   #10 (permalink)
#334
Chococar's Avatar
I'm interested in a reasonably priced dry sump system.
Old 08-24-2007, 07:59 PM   #11 (permalink)
Elise Booster
lucien's Avatar
Dry Sump for lotus Elise 2ZZ GE engine
Call Sandy Wilkins at Wilkins Motorsports, 919-218-1866 for information about a dry sump system for your Elise.
Lucien Wilkins
LUC
lucien is offline   Reply With Quote
Old 08-24-2007, 08:10 PM   #12 (permalink)
Chris Mackey's Avatar
The best reason to get a dry sump is to impress the ladies
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 08-24-2007, 09:18 PM   #13 (permalink)
short angry bloke
codymac's Avatar
Images: 19
Absolutely!
They all know that a man with a dry sump has a big end that'll last longer.
Old 08-24-2007, 09:50 PM   #14 (permalink)
Yep, I knew about this. They did it because they had to. The Accusump and stock pan they offer is a bandaid. Surprised they wasted so much time with the
roof scoop and air to air intercooler. Maybe in a couple of years we'll get the Laminova.
Old 08-25-2007, 12:39 AM   #15 (permalink)
right seat driver
Brent Bauman's Avatar
That laminova looks to be in the identical spot as mine. Anyone have more pictures of the Cadena cars. Thanks.
Brent Bauman is online now   Reply With Quote
Old 08-26-2007, 06:55 AM   #16 (permalink)
choi0706's Avatar
http://www.komo-tec.com/index.php/cPath/109_110
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 08-26-2007, 07:57 AM   #17 (permalink)
short angry bloke
codymac's Avatar
Images: 19
Originally Posted by choi0706 View Post
Comes with everything but the tank and lines but I can't understand how that sump would bolt up to a 2ZZ. That said, it makes me wonder if they actually have one working.
Old 08-26-2007, 08:58 AM   #18 (permalink)
My other car's a mtn bike
R'elise Me's Avatar
Any idea how much weight is added by the dry sump system.
Sometimes you have to go in circles to move forward.
05 Elise NA 1750 lbs w/ full cage, fuel cell, aero, 173 whp - Colin would be proud.
2008 LR3 HSE
2005 Mini S Convertible
If I'd thought that one day ALL my cars would be British, I'd have laughed at myself!
R'elise Me is offline   Reply With Quote
Old 08-26-2007, 10:29 AM   #19 (permalink)
Not exactly sure but best guess would be 10 to 15 lbs.
exigeme is offline   Reply With Quote
Old 08-26-2007, 08:31 PM   #20 (permalink)
R'elise Me's Avatar
that's not too bad, but sounds too light - 2 pumps, hoses, tank, more oil usually. On the other hand, I haven't heard of any issues with the accusump/lotus sport oil pan on the cup cars and they run on slicks - so I'm not sure why MikeW refers to the accusump as a bandaid solution. The HP boost would be a nice benefit though not to mention improved spousal relations :UO
2008 LR3 HSE
