Old 07-31-2007, 07:16 PM   #101 (permalink)
beat's Avatar
Do you have detailed pics of the mounting kit? How much would it cost? Any problem with the drive shaft tilted at an angle? It is a problem with the rover engine Lotus swapping to K20 due to the subframe pushing the engine forwards therefore tilting the driveshafts....
Play only when you can afford to lose.
The truth aint for the weak.
beat is offline   Reply With Quote
Old 08-01-2007, 08:21 AM   #102 (permalink)
Beat, my conversion is a series two car that had a Toyota engine not a Rover. Drive-line angles look very good and after fitment of the supercharger is completed I will be making engine mounts. The engine and trans-axle have been in and out of the car countless times looking for the best position while going through this process.
exigeme is offline   Reply With Quote
Old 08-01-2007, 08:24 AM   #103 (permalink)
beat's Avatar
I have an S2 Exige with yota engine. If there is a mounting kit for the K20, I will be very interested...
Everything is fabricated?? Drive shafts, engine mounts, tranny mounts, etc....
What is needed for the swap?
Old 08-01-2007, 08:39 AM   #104 (permalink)
At this point nothing is fabricated, if you are looking for a k20 conversion kit
do a search and you will find others that offer such a kit. I do plan to fabricate most of my parts but will leave the drive-lines and exhaust to others that have a reputation of building the best.
Old 08-03-2007, 04:37 PM   #105 (permalink)
Carbon/ Carbon twin disk clutch
Not that its been holding up my progress but after waiting for two months it is always
nice to have in hand things you have spent good money for. Amazing to see that the
complete assembly, clutches and flywheel weigh around 13 lbs. Well engineered and
very nicely made and rated to hold 840ft/lb of torque it will more than well hold for my
application. It was expensive but due to the positive characteristics and excellent wear
rate I should be able to use it for years without having to pull the transaxle.
Old 08-03-2007, 05:22 PM   #106 (permalink)
youngin' in lust
Mmm, those parts are so sexy! (Forgive me, I'm a mechanical engineer)
elptex is offline   Reply With Quote
Old 08-03-2007, 05:26 PM   #107 (permalink)
jim-clayton's Avatar
Wow. I hope I'm reincarnated with a better paying job.
Your parts and pieces peg my money meter.
That clutch set-up should be on "pay for view" .
2005 Elise Storm Titanium
jim-clayton is online now   Reply With Quote
Old 08-03-2007, 09:17 PM   #108 (permalink)
Try to get the K20a Type R
Detailmaster
60 step detail.
Hands down the best detail ever.
By appointment only.
Detailmaster is offline   Reply With Quote
Old 08-03-2007, 11:32 PM   #109 (permalink)
Dan, you have such good taste! Nice choice. My friend has a single disc Tilton carbon/carbon setup on a formula car. Certainly much friendlier to modulate that an all metal. You could even drive up on the trailer with it. Better check all the Tilton fasteners. We pulled the engine and found all the fasteners holding the pressure plate together were ready to fall completely out. It's red Loctited to death now. Can trust anybody. Just got a bad one I guess. I found buying this stuff is a great way to get the limit on your credit card raised.
MikeW is offline   Reply With Quote
Old 08-03-2007, 11:44 PM   #110 (permalink)
Thanks Mike, I am happy about my choice so much so that I have gotten nothing done today but look at my clutch and new shocks. Building the supercharger transition is turning out to be a real pain in the ass and zapping my motivation. I will make sure I check the bolts, thanks for the heads up.
Old 08-04-2007, 04:02 PM   #111 (permalink)
holmz's Avatar
Images: 5
elptex - You know what engineers use for birth control?
holmz is offline   Reply With Quote
Old 08-04-2007, 10:09 PM   #112 (permalink)
youngin' in lust
Yea, yea, thanks, you're a real gem, too :-p
(Answer: Their personalities)
Old 08-05-2007, 08:57 PM   #113 (permalink)
Supercharger transition
Because you can't buy these things I had to make one on my own. It is quite
involved, first you have to machine a flange and then build your desired
shape piece by piece on to the flange. Lots of cutting and welding and grinding.
If you are fortunate enough to have a CNC mill you could machine one but I do not
so it was done the old fashioned way. Don't laugh, it took me many many hours....
Old 08-06-2007, 04:08 AM   #114 (permalink)
Parts scattered about...
MaineLotus's Avatar
Nicely done, impressive!
My car is modified.
MaineLotus is offline   Reply With Quote
Old 08-06-2007, 09:34 AM   #115 (permalink)
Dan
That kind of stuff is very time consuming. Only other practical way is to sculpt some kind of form in the shape you want and start laying up carbon or fiberglass over it. I did some brake ducts that wound their way between the upper and lower control arms. I used carbon and epoxy resin. Then you can form any curves you want. You don't feel as restrained. There's a lot of hit/miss the first time though. You may want to have someone guide you through the basics some time. It another option. Options are always nice. Overall not a bad job, Keep going,
Old 08-07-2007, 08:44 PM   #116 (permalink)
short angry bloke
codymac's Avatar
Images: 19
Curious about the clutch. Have you worked out:
- master cylinder?
- release bearing (slave & fork or hydraulic)?
- positive clutch stop to prevent overstroking?
Old 08-07-2007, 10:17 PM   #117 (permalink)
I did buy a master cylinder and a matched hydraulic through out bearing and plan to measure the movement using both the Lotus master cylinder and the new master cylinder. If I set it up correctly I should not need a stop.
Old 08-10-2007, 04:15 PM   #118 (permalink)
Had a setback yesterday while looking over the dry sump setup, feeling like an idiot for not noticing it earlier but at the present time the pump is mounted where the half shaft carrier bearing is located. I spent most of the evening yesterday looking for alternate locations where the pump can be mounted while keeping the AC intact and came up empty. I notified ADR engineering in the UK, the company I purchased the setup through and they are having a engine with ancillaries brought in to work with me on finding a solution. I am confident together we will find an alternate location and in the end have a better product. I really was not expecting them to jump in and help but rather just expected them to offer me a refund and knowing me, would just have come up with a solution on my own. Everything I have done so far revolves around the engine location in the chassis so this is of much concern to me. I guess it just gives me more to do as if I did not have enough already.
Old 08-11-2007, 04:08 PM   #119 (permalink)
More track time please.
Bleu Omdurman's Avatar
Dude, I walk away from the thread for 2 weeks and look what happens!!
This is awesome. I need to swing by sometime and drool in your garage.
Nice work man!
Bleu
Take my track day survey: here You should enjoy it. 10 questions.
Now take survey #2 here
Mods: TurboXS Intake, Ultra Disc Rotors, Adare Motorsports Racing Pads.
Bleu Omdurman is offline   Reply With Quote
Old 08-15-2007, 05:20 PM   #120 (permalink)
No drooling going on at this time, spending time in the garage has been a downer lately. I am spending all kinds of time making modifications to stuff I had already partially built. At the moment when I get sick of working the intake I have been looking for a larger drive by wire throttle body that will work with an aftermarket engine management system. I have also been trying to come up with a way to keep the AC and use the dry sump system I
bought. Unfortunately either the AC goes or a completely new pan has to be built to use the dry sump. Nobody I can find makes one that can be store bought and keep the AC for a transverse application. If anyone knows differently PLEASE let me know.
