Old 08-16-2007, 04:52 AM   #121 (permalink)
ZAMMY
take heart. it's the way swaps go.
i did a diesel engine into a bmw bike.
it looked great til i was finishing up the clutch details and then had to add an inch to the bell housing.
engine mounts and all had to be moved, fork had to be redone...
you're doing a great job and it takes time and, usually, more effort than originally expected.
you have a lot of us rooting for you.
sam
Old 08-16-2007, 08:29 AM   #122 (permalink)
Thanks Zammy1, I will forge forward and get-er-done!
exigeme is offline   Reply With Quote
Old 08-23-2007, 08:16 AM   #123 (permalink)
The dry sump pan
I have exhausted myself with finding an easy solution to my dry sump pump
mounting location and am in the process of a total redesign of the pan and
pump configuration. It has halted my swap progress but in the end will be a
cleaner less cluttered configuration. ADR engineering has offered to build it
if I do the design layout.
I am hoping to finish the intake manifold in the next week with the throttle
body and supercharger inlet to follow shortly after.
Old 08-23-2007, 08:47 AM   #124 (permalink)
Hoon
Amarao's Avatar
Did I miss a post somewhere? What's the problem with the original mounting location?
Amarao is offline   Reply With Quote
Old 08-23-2007, 12:01 PM   #125 (permalink)
You did, see post #118. The oil pump is mounted where the half-shaft carrier
bearing mounts to the block. Evidently the setup I bought was designed to work
with a non-transverse engine application. The oil pump could be moved but would require
the A.C. compressor be removed.
Old 08-24-2007, 07:40 PM   #126 (permalink)
choi0706's Avatar
hrmmmm... these just came in too..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 08-25-2007, 07:52 AM   #127 (permalink)
Wow, what years, what mileage and how much? If I would have know you sell
JDM engines I would have bought mine from you.
Old 08-25-2007, 10:04 AM   #128 (permalink)
choi0706's Avatar
These are gen2 (05-07)
max 30,xxx kms
Rally Ready
Old 08-25-2007, 10:48 AM   #129 (permalink)
Matrix XRS 2zz-ge
kortik's Avatar
oh yes Japan likes to give away/sell cheap thier engines becuase of the strict emissions laws
05 Toyota Matrix XRS Indigo Ink Pearl 2zz-ge
Progress Rear Sway Bar
TRD STB
PBR Groundwires
MagnaFlow Cat Back Exhaust
Tein SS coilovers
TWM Short Shifter
Injen CAI
C-one perfromance Fr. Rr. Bar
C-one Underpanel
kortik is offline   Reply With Quote
Old 08-25-2007, 07:17 PM   #130 (permalink)
Hoon
Amarao's Avatar
Uh... what?
Old 08-26-2007, 10:40 AM   #131 (permalink)
In Japan automobile owners are taxed heavily based on the age of their vehicle, this promotes their economy buy forcing people to buy new cars often.
Old 08-26-2007, 10:42 AM   #132 (permalink)
Matrix XRS 2zz-ge
kortik's Avatar
sorry for my English but exigeme said what I was trying to say
TRD STB
PBR Groundwires
Tein SS coilovers
TWM Short Shifter
Injen CAI
C-one Underpanel
Old 08-26-2007, 11:43 PM   #133 (permalink)
Hoon
Amarao's Avatar
Nothing wrong with your english.
I was under the impression it was done for the sake of their economy as exigeme said. But we're all on the same page.
Exigeme, so I'm guessing you're unwilling to give up your AC?
Old 08-27-2007, 08:42 AM   #134 (permalink)
Amarao, I do not want to give up my AC for several reasons, non comfort related. Living here in the Seattle area we get lots of wet days that fog up the small passenger compartment of the Lotus easily and secondly removing the AC changes the whole belt routing which limits the belt contact patch on
the supercharger pulley.
Old 09-16-2007, 12:13 AM   #135 (permalink)
choi0706's Avatar
any update?
Rally Ready
Old 09-17-2007, 02:04 PM   #136 (permalink)
Not much to report as far as pictures go but I have been working behind the scenes on a new oil pan design. I am just starting on the engineering work
but plan to incorporate a electronic pre-oiler into my dry sump design with a externally mounted direct drive pump and be able to retain all ancillaries.
On a second note, I have been looking into an engine management system that will offer excellent engine control as well as traction control with a digital dash. I have narrowed down my choice to the Pectel SQ6.
I had shoulder surgery in the end of May and spent the summer doing very little because of physical limitations and am now back to my usual traveling for work so things have slowed down some as far as progress on the car goes.
Old 09-17-2007, 07:55 PM   #137 (permalink)
choi0706's Avatar
have you looked into motec?
http://www.motec.com/products/kits/hondakit.htm
M4 Honda Kit Features:
Allows full Sequential Injection High or Low Impedance Injectors software configurable
Waste gate Control, and Nitrous Fuel Enrichment capable Idle Speed Control Capable
Dual RPM Limit based on Fuel cut, Ign cut or both Exhaust Gas Temperature Capable - up to 2 Inputs
Cooling Fan and Fuel Pump Control capable Narrow Band Closed Loop Fuel Control
External Trim Switch capability for Fuel, Ign and Boost Single Axis Accelerometer Capable
Turn on Shift lights and provide signal for Tachometers Traction Control Capable
Pre-wired for Lambda and 2 or 3 Bar MAP Inputs Individual Cylinder tuning for Ignition and Fuel
http://www.motec.com/products/dash/adl2dash.htm
Rally Ready
Old 09-17-2007, 10:32 PM   #138 (permalink)
I did consider Motec but Pectel offers more program flexibility, channel options and price per option cost breaks. Check out their site http://www.pectel.co.uk
Old 09-18-2007, 07:37 AM   #139 (permalink)
Hoon
Amarao's Avatar
What's the avg. price on the SQ6?
Old 09-18-2007, 06:25 PM   #140 (permalink)
The price depends on how it is configured but prices start around $4500.00
for the SQ6.
