#41 (permalink) | |
#42 (permalink) | |
#43 (permalink) | |
Elise Fanatic
Pete 05 Lotus Elise | 06 Porsche Boxster S | 97 Porsche Turbo |
#45 (permalink) |
Elise Fanatic
It was a typo; now fixed.
NMRJock - Yeah, I've got to stop using those 25lbs VDO gauges But you have a good point, we added at least 10lbs back for the fire system, harness bar and harnesses.
#48 (permalink) | |
I am curious as to the placement of the antibackup valve, the brass fitting in the picture. With the engine mounted filter having an internal antidrain valve, such a fitting usually is not required. I'd have to see how the Elise's Accusump in plumbed to figure out that one.
Elise #2393 Bordeaux/Biscuit/LSS/HT/WindowTinting/Shield. Purchased new 06/01/05. Canton Mecca Spin-on Oil Filter, Redline Lubricants. |
#49 (permalink) |
It looks like the thermostat sandwich plate adapter is still installed? Won't that cause an issue with Accusump charging? I thought you needed use an external thermostat and a sandwich plate adapter with no thermostat built in.
“The Edge…there is no honest way to explain it because the only people who really know where it is are the ones who have gone over.” |
#50 (permalink) |
That should be the standard adapter plate on the Elise (where the oil cooler lines attach). I wouldn't think that the thermostat in the adapter would be a problem - it should simply direct the warm oil through the cooler lines, and cold oil should bypass. I would assume that the lines remain pressurized, and if you plumbed the Accusump into the return line, there wouldn't be any problem...
#51 (permalink) |
It looks like it is plumbed into the return line. The 'T' fitting is just after the check valve.
#52 (permalink) |
What kind of fittings did you use to splice into the rubber line? Also, is there a check valve in the line on the oil cooler side? Did Canton supply it? Finally, what kind of fittings are used on the oil cooler lines into the sandwich plate - they're not AN although what Canton shipped me are AN.
#53 (permalink) | |
#54 (permalink) |
Elise Fanatic
Guys, I can't answer all your technical questions since I didn't do the installation. The folks at www.speedwaremotorsports.com have the complete kit. Please contact them for more info. I have a few more pics which I'll post; maybe they'll answer your questions.
