Another Honda Powered Lotus
So the time has come for me to write about a regular Mase Engineering stable mate. It’s a 2007 Lotus Exige S owned by Dr. Christopher Prusinski. While ultimately its normal duties were to serve as a steady, reliable, and fun track car, it also is still registered for street use. We left the Lotus fairly unmolested at the beginning of its life. Before the engine conversion, it normally rocked the carbon fiber aero additions, stock 2zz Toyota engine and transmission, AP Racing front brakes, and Lotus Track Pack. We developed a liquid to air intercooler several years ago that did a very nice job keeping the intake temps cool compared to the inefficient stock air to air intercooler. Other than that, the only other performance additions besides the ECU tune was the exhaust we fabbed up. Last year during NSXPO, when we sheared off a gear in Dr. Prusinski’s 500+ whp Turbo NSX (another beast of a track car), we turned to the lotus as the backup track car. Unluck unfolded, after 12,000 miles, the factory Toyota engine decided to puke after a few laps. The OEM piston failed and ripped completely clean off the wrist pin, destroying just about everything within the engine. ![]() We all had a big decision. The lotus had been very reliable up to that point, (minus a broken axle at Watkins Glen) but with the desire to always want more power. Rebuilding the 2zz would yield a stronger engine, but not really much more power. So by the time money was spent on building a forged internal engine as well as upgrading the factory supercharger, it would be dumping a lot of money into the setup. Along came the idea of swapping a K-series engine into the mix. I’ve worked with many high horsepower Honda K-series engines, and configured a naturally aspirated build that would be reliable, powerful, lighter, more fuel efficient, and run cooler, this is a huge plus given the high heat and humidity down here in Florida. Dr. Prusinski gave the green light. Doing research I found innovative motorsports, who when talking to them, said they have everything we would need for the swap. Little did I know it would actually take 11 months later after I ‘placed’ the order would I receive the final parts. Owning a motorsport company I’ve been accustomed to hardships of all sorts. I hate to ever speak bad about another company, so I will leave out many of the frustrating problems I had and focus on the end result. Luckily for me, I was able to source a lot of the items we needed to fulfill the empty promises from Innovative didn’t come through with on time. At the end, we used the innovative mounts, throttle pedal and throttle cable. Everything else didn’t show up/fit/or not up to par. ![]() The engine setup I designed was to be very straight forward. The motor consists of a Honda K24 bottom end. I chose the 2.4L out of a 2008 Acura TSX due to the revisions they made to the block for the 2006-2008. The cylinder head, we went with a k20 cylinder head off an Acura RSX Type S. We modified a new Type S Oil pump to flow better, and added a bafflle inside the oil pan. High compression forged pistons, light weight rods, balanced, and assembled by me. Full valvetrain, SS valves, and a set of aftermarket Cams. I used the same intake manifold we use in our Grand-Am race cars at RSR Motorsports. I chose a Hybrid-Racing throttle body due to the solid construction, and the fact it bolts up to the intake manifold without an adapter. I designed the header to be a 4-1 collector with a good merge angle and runner diameters. Thanks to Dwight at Stage 6 motorsports for the fab work on the header and exhaust, as well as the brackets for the oil cooler in the side vent. I chose a 2007 Civic Si Transmission due to the fact it was newer, and comes with a limited slip differential. It had very low miles so I didnt want to break it open. 6th gear is quite long in it, but being that it is still able to be driven on the street, another reason to keep the stock gearing. Using this transmission meant I had to modify some circuitry so that the Hondata PRB Ecu could read the correct VSS Signal. In the future, I’d love to get a sequential gearbox in the car. Way back at the end of 2011 I started on the engine harness. I wanted to make the swap as clean as possible, I sourced some of the Lotus ECU Connectors, and tied a brand new oem honda engine harness that literally plugs into the factory harness. Hondata makes a CAN adapter that will drive the factory Lotus gauge cluster, it works pretty well, except we noticed it cutting out every once in awhile on track. If I had to do it all over again, I would certainly recommend someone to buy a complete swap. Luckily Jacksonville’s fastest Honda drag car owner, Cesar Olin, has a stock pile of miscellaneous parts, and was a big help to me when building the engine. The result: 295 whp and 212 ft/lbs of torque on my very low reading dyno dynamics dynamometer. In the near future I will roll the lotus on the scales and see how much weight we’ve been able to shave off due to the lack of heavy supercharger/intercooler, the removal of other oem components such as the two factory oil coolers and lines that run all the way to the front and back. The car is a totally different beast. The car is making another 80 horsepower over what it had with the supercharged 2zz engine. The power and torque makes this car very quick around the track. Here is an in car video of the first time the car was tracked with the new setup at Daytona Speedway: Honda Powered Lotus Exige S at Daytona Speedway - YouTube More info will be later posted on our facebook: http://www.facebook.com/MaseEngineering |
| Sponsored Links | |||
Advertisement | |||
The more I read about these Honda swaps that involve Innovative, the more I wish there were alternatives when doing a K swap. Innovative, from all accounts, sound like a pain to work with: long lead times, questionable quality control, missing pieces.
At any rate, the build looks awesome!
2006 ASPEN WHITE EXIGE Supercharged Honda K24A2 transplant in progress. |
Innovative is an awesome company run by a super good guy. Business is business, when you have an over abundance of "custom fabricated" work this are going to take time, at least someone is out there helping the community with k-swap parts. No other company had put in the time or RnD to do it.
I've never done business with Innovative only read stories from those who have. I'm sure they're nice guys but that kinda gets lost if they can't deliver their products as promised. People are willing to wait for custom fabbed parts but when those parts are done they should be right, or at the very least... you know, be delivered.
#7 (permalink) |
DIY 2007 Exige S K20A2 C38 Rotrex OneHotLap build thread http://www.onehotlap.com/2012/07/lot...rned-into.html http://www.onehotlap.com/2012/07/lot...d-into_11.html |
#8 (permalink) |
I am just about setup to do these swaps in my home garage in Massachusetts. I have already done my own which is a k20 c38 rotrex with 400whp. Each swap is a little bit different but I can do these at a very reasonable price since I don't have any overhead. Hit me up if you are interested. Sorry for the thread hijack
![]() Sent from my iPhone using AutoGuide.com App
#9 (permalink) |
I've got the powerflex at all 3-4 in board positions on my car. The thing FINALLY brakes straight after years and thousands of miles on the stock junk. Not suggesting against monoballs (i didn't put too much thought into what i had installed as my local shop keeps these in stock) but they're certainly better than stock. They do however need to be oriented correctly so they wont shift. Monoballs will by definition transmit more shock to the frame so there's an increased likelihood of stress cracking the frame, but i don't think there have been any reports of it, and seems like a fair amount of usage out there already.
2006 Aspen White Elise. LSS, LSD, Traction control, LS Toe Link Brace, LS Ohlins DA, Rota 15/16's, BOE surge tanks and Sector 111 Gpan2, Red leather, JL speakers all around with Acapulco MP54, CF dash top, gas shock opening rear deck, multi-vex mirros and replaced rear-view mirror with kit off this forum. |
#11 (permalink) | |
06 OCM elise with lil mods here and their
#13 (permalink) |
The height difference is minimal it works on an exige and Elise
#14 (permalink) |
Noways iz sittin outsides
you have a dyno? 295whp & 212 pretty nice numbers for NA. What type of dyno was this done on?
+1
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 Lotus Exige S310 WTC 2 |
#18 (permalink) |
Painful Novice
I am still trying to wrap my head around the "why" of the K20 swaps. Similar numbers can be achieved (Hp and torque) with a built 2zz engine and a TVS supercharger. An uprated transmission does make sense. If I am going to go through the challenge of an engine swap, I will likely wait until Monkey Wrench puts their finishing touch on the V6 swap kit they are working on. Or even better, pioneer the hayabusa v8 with 400 plus HP (NA, more supercharged) and a 10500 rpm redline.
Storm titanium 2005 Elise with carbon fiber spoiler, BWR sway bar, BOE toe links, gPan2, LidBone, sector 111 wheel studs, Grey RAC Monolite wheels with toyo R1R, Team Dynamics 1.4 with Hoosier A6/R6s, Katana2 Supercharger, ECU with 265 flash. PPE headers w/decat, CEL angle eliminator, Silent touch catback, Rear Panel Eliminator, HKS intake, V2 fuel tank, Walbro255 fuel pump. HID lights. |
#19 (permalink) |
Chris
Tim is a funny guy, but he's a good guy. He seems to sometimes dive into too many things at once but he's knowledgable and helpful. You just have to get on his case sometimes and keep a tab on him
Nice swap Question on the exhaust; did you custom fab the header and midpipe to connect to a Lotus muffler? It looks like a Larini SE exhaust if I'm not mistaken. Or did you custom make the muffler as well
2005 Magnetic Blue Lotus Exige Drivetrain: Honda K20A Type R | Innovative Mounts | Arqray Ti | Innovative Exhaust | Custom Intake | Hondata KPro | proRAD | Setrab Cooler | Innovative Shifter | KTuned | V2 Fuel Tank | Radium Coolant Tank | Aero: Exige Clams | Reverie | TWRD | Craftsquare | Denag | IMRP | BSK Hatch Suspension: Nitron SA | V2arms | RTDbrace | Volk CE28N | Toyo R888 | DBA4000 | Pagid RS14 Interior: Recaro SPG | Willans | WorksBell | Sparco Wheel | aspec Ti knob Last edited by 6i9; 01-01-2013 at 06:27 AM. |
#20 (permalink) | |
2zz exorcism complete
The Honda swap is lighter, stronger, more powerful & more reliable than the 2ZZ with better aftermarket support and availability of parts. Also consider the crank centreline moves down 2 inches and forward another 2-1/2 inches, and the throttle response is better, and the fuel economy is better, the cams don't wear out etc. In short, the only advantage the 2ZZ has is that it comes in the car and for racing series where you need to retain the original drivetrain.
2005 Elise with Honda engine |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
