#21 (permalink) | |
Chris
2005 Magnetic Blue Lotus Exige Drivetrain: Honda K20A Type R | Innovative Mounts | Arqray Ti | Innovative Exhaust | Custom Intake | Hondata KPro | proRAD | Setrab Cooler | Innovative Shifter | KTuned | V2 Fuel Tank | Radium Coolant Tank | Aero: Exige Clams | Reverie | TWRD | Craftsquare | Denag | IMRP | BSK Hatch Suspension: Nitron SA | V2arms | RTDbrace | Volk CE28N | Toyo R888 | DBA4000 | Pagid RS14 Interior: Recaro SPG | Willans | WorksBell | Sparco Wheel | aspec Ti knob |
| Sponsored Links | |||
Advertisement | |||
#22 (permalink) | |
Lotastic
![]() How much lighter is the k24 than the 2zz?
Life Lesson #1: If you can't fix it with a hammer, you have an electrical problem. Life Lesson #2: It's more fun to drive a slow car fast than it is to drive a fast car slow. |
#23 (permalink) |
Why Honda?
The Honda 2l K motor is very well developed and supported. I do not know if it is that much lighter than the Toyota/Yamaha motor. Some reports around this site quote either 15 pounds less or 20 pounds more....
Immitation is the best form of flattery and the Toyota motor is a bit of a copy and a response to the K20. There are various 'formula' classes around the world where the K20 is spec'd. Honda tried to displace Ford in F2000, when Ford threatened to stop casting the old 2L blocks. Honda K motors are used in Midget racing. Look at 4piston, 400HP, naturally aspirated!! I would use that for a hell of a track car, although, personally, I like turbo motors. So, cost-effective, reliable, powerful. The only disadvantage is that the Lotus did not come with it. Anton |
#24 (permalink) | |
00' S1 Exige 94' S4 Esprit (SOLD) :-( 10' Ram Crew cab 1500 hauler |
#26 (permalink) |
Lotastic
You beat me to it. The B series Honda engines of the 90s were clearly the inspiration for the 2zz. Honda made 1.6, 1.7, and 1.8 liter engines with the v-tec technology heads developed first on the NSX. All with outstanding power/displacement and reliability. The 1.8L B-series Type-R engine is the one used by Sun International when they were importing the S1 into the states. The 1.7L in my Integra had 200,000 hard driven miles on it when I sold it and was still running strong.
Life Lesson #1: If you can't fix it with a hammer, you have an electrical problem. Life Lesson #2: It's more fun to drive a slow car fast than it is to drive a fast car slow. Last edited by me73; 01-01-2013 at 03:52 PM. |
#27 (permalink) | |
And although Honda has taken the design further it has also porked it up compared to the Rover. This is one of the main reasons S1 cars are so much lighter then S2 variants. The Rover K in my car weighs 300lbs fully dressed with transaxle,starter,alternator,exhaust header, etc... dripping fluids.
#29 (permalink) |
Lotastic
Just to clarify, the Rover engine to k20a swap was a reduction of 25lbs? How much of that was exhaust if any? The Rover is lighter than the 2zz, correct?
#30 (permalink) |
My car is really small
I dont know much about 4 cyl engine families, but 300 hp from a NA 4 cyl is beyond impressive. What makes the K series so great? Are there a few key features or is it a case of alll the details summing to a great package?
Seriously, my car is small 07 Exige-S, "Landshark" 05 Saffron Yellow "bumbleBee", on to a new owner Also: 84 930 turbo, 06 WRX Wagon |
#31 (permalink) | |
It's OK to admit that Honda has stood on the shoulders of other engine manufacturers designs . I'm sure with enough changing of wheels, exhaust and other deletion of parts you could get an S1 to a net +25 lbs over at completely stock K engined car..you only have to make up for 100 lbs or so. I love how you Honda guys get so defensive of your brand..
#32 (permalink) | |
I'm sure the 2ZZGE could make similar numbers with the same displacement and the right accoutrements.
#33 (permalink) |
2zz exorcism complete
So calling me a fanboy is a valid counter to my argument?
Honda does not use the head bolt through to bearings, but you'd have to predate aero engines of the 30s to claim to be first with the idea. So exactly what did Honda copy from the rover k? Perhaps the plastic dowels and weak liners? 25 lbs referred to engine swap (engine, trans, exhaust, mounts etc) not other changes.
2005 Elise with Honda engine |
#34 (permalink) | |
Sent from my iPhone using AutoGuide.com App
DIY 2007 Exige S K20A2 C38 Rotrex OneHotLap build thread http://www.onehotlap.com/2012/07/lot...rned-into.html http://www.onehotlap.com/2012/07/lot...d-into_11.html |
#35 (permalink) |
you guys do realize dstevens is the owner and brains behind Hondata?
2009 Monaco White Elise. 1978 Toyota Corolla Sport Coupe. Canon 5D, Sigma DP1x, Sigma DP2. http://www.youtube.com/watch?v=zbU0UJAdFj8 http://www.youtube.com/watch?v=jQOnOXXc-ps& A must watch! Lotus Elise Inside Story |
#36 (permalink) | |
#39 (permalink) |
Lotastic
The reduction includes exhaust. I suspect this is where the savings comes from.
#40 (permalink) | |
The only real solution is the mr2 5speed conversion or a quaife..run the stock tranny and let's see how it lasts with the 2zz-rev400. And unless you are running race fuel and a fully built motor you can forget 400whp out of a TVS-2zz. See Phil's car for mods and whip results. My k20 is stock block, pocket port head and a c38-70 Rotrex and I'm at 400whp on pump fuel. That's with boost limited at 15psi and the vision function intercooler. I am putting in GearX 1-6 close ratio forged chromoly gears in this winter and the tranny should be ready for some serious abuse. That's why I went Honda! Sent from my iPhone using AutoGuide.com App
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
