Anyone Running a Piper or MWR camshaft??
Has anyone run a Piper or MWR camshaft on a stock setup? I emailed Piper and they said it would be OK to use thier 285 camshaft on a stock setup. I am just not sure
![]() Thanks for any input |
| Sponsored Links | |||
Advertisement | |||
Plug Whisperer
The reason it's hard to get more NA power from the motor is because it's all ready a beast. It is just a 1.8L motor and makes 190hp all day long on 91 octane fuel... I digress
![]() As far as the cams go on a stock car, stock tune, etc = not a great use of funds, IMO. On the supercharged cars, we're doing some custom tunes for stage 3 cams on the stock ECU over the winter. We have been doing custom supercharged tunes on the 2s and 3s w/ the standalone for quite a long time. The best gains are with forced induction and the cams certainly help there. From an NA standpoint and to really make an appreciable difference, you need cams, more compression, custom tuning, etc and that will turn a street motor into a race fuel only motor... Plus, I'm pretty sure we're (kold-fire USA/BOE) the only ones doing totally custom tuning on the stock ECU, and we have no plans to do a "big NA" build/tune for anyone anytime soon. There's just not enough demand for such a tune to dedicate the time to it. That means you're going to be confined to a standalone for engine management-- a great solution for some, but not others... I have not degreed the MWR vs Piper Cams, but they're near identical. Both companies set the lobe centers to about the same as stock, so you can drop them into a stock tune and the car WILL RUN-- just not optimally for the cams. The MWR cams are running a tiny bit more lift as I recall. I think the duration is comparable across the two. Power output should be about the same. We have Stage 3 MWRs in the race car (Still street legal). It drives and idles just fine. In fact, the idle is truly as smooth as stock at around 1,100 RPMs. You'd never know it has big cams in until your either pulling on a car you "shouldn't be" down the straight or until VVL kicks in. The induction noise generated by the big Stage 3s at VVL is almost defening. Absolultely insane-loud induction noise when compared to stock cams--- or anything else for that matter!! ![]() ![]() There's a nickel or two from KS... Best, Phil
2005 GG Elige, Rev400, EFI, Race Car, 400+whp | 2005 GG Elise, Rev310, Street Car | 2006 CO Elise, Rev300, Steet Car www.boefab.com: Lotus Performance Engineering and Service Specialists BOE The Awesome ClamHinge | BOETVS SuperCharging, The Most Powerful Track-Worthy Forced Induction | EFI Engine Management | BOE The Essential Fuel Starve Solution | BOE Lotus Tow Package | BOE New-Tech Lotus Race Engines | Custom and off-the-shelf ECU Tuning![]() Engineering & Innovation by Lotus People For Lotus People Somethin ain't worth do'n, if it ain't worth do'n right
Being that it sounded like the cams in the 2zz are a weak point, I was going to upgrade to a after market ones, now I think I should just best leave things the way they are.
Thanks so such for your info!! Robert |
Elise Driver
![]() Join Date: Oct 2003
Both the Piper and MWR stage 2 cams can be installed in a stock engine with upgraded valve springs. It's easy to install the upgraded valve springs with the engine in the car and cylinder head still installed- no major surgery required. They run fine on a stock tune and even better with a custom tune.
The MWR and Piper cams are pretty similar. We sized the small lobe on the MWR model slightly bigger so the Piper is a little stronger from 2-3k and the MWR cams are stronger from 4-6k where you really need it. Both cams work great with the stock ~6k VVL (NA) engagement point because the small lobe is so much stronger. You no longer go from nothing to soemthing at 6k so the jolt from the VVL is less noticeable. The Stage 3 cams can be installed in a stock engine as well but they really only benefit those revving to at least 8800rpm. The cams work great in NA and supercharged applications. Keep in mind with a supercharger that you'll need a smaller pulley to maintain the same boost level when you improve the engine's airflow characteristics. If you do cams and don't change pulley size you'll find very minimal performance gains since the supercharger is not trying to move any more air.
Matt @ Monkeywrench 2005 Elise V6 / E153 340hp NA, 415hp Supercharged 2005 Elise Supercharged / E153 2001 Toyota Celica 2ZZ Turbo 950 crank hp, 200+ mph 2001 Toyota MR2 Spyder 500+hp, 10's http://www.monkeywrenchracing.com/ |
#6 (permalink) | |
4.GRIP
Bringing it back...
I see the Celica forums talking about 10 whp, which to me is pretty decent for our already light cars. Hell with 175-185 whp and getting the car down around 1950 lbs Id be happy... My total plans for the car power wise are: Custom burns lightweight exhaust, decat, stage 2 cams, and a tune (was hoping for stock ecu reflash) |
#7 (permalink) |
Elise Driver
If compleely stock you'd probably see a bit less than 10whp. Other bolt-ons like cold air intake and header are going to make a little more hp/$ on a stock engine. Once you've got the other mods and are moving more air the cams make better power.
#8 (permalink) | |
Haxord but mine
Sector111 Katana2 Supercharger for the Lotus Elise and Exige If theres anything I've learned over the years is that NA on a budget is just not the way to go on a 4 cylinder. If you go NA you have to go big. The only draw is that you *can* do it incrementaly, where as forced induction requires all the cost at once.
-David 2006 Storm Ti Exige + VF TVS BOE Nikasil 10.5:1 + Vision Function TVS Vision Function MP62 Based Supercharger Install Thread Turn Signals Blink Fast? Stereo Harness Info |
#9 (permalink) |
Has anyone compared wear of the Piper/MWR cams vs OEM?
Having just discovered the dreaded intake cam wear on my '06 I'm wondering if I'd be a fool to slap another OEM cam in. (I'm not really looking for a performance boost, though I certainly wouldn't mind one -assuming I'd do springs as well). The aftermarket cams seem to be 6-7x the $ of OEM though , so it's a big differential in spend.
2006 Chrome Orange Lotus Elise TC/LSD/Track/Sport/Touring - daily(ish) driver 1993 Honda Civic Si hatch - for those other days Swift DB1 Formula Ford - (Solo & Hill Climb) 2009 SCCA National Championship - 2nd CMod 2005 Canadian National Champion - CSP |
#10 (permalink) |
I have the Piper Stage 2 Cams running in my car. Big difference. Take a look at the Dyno I posted on Spyderchat.
Triz's 2zz Swap - Page 6 |
#11 (permalink) |
Noways iz sittin outsides
damn that's amazing difference between your car and stock elise. Almost same power as Exige 220S.
Always thought about changing the cams, would rather do it vs. a pulley, but a lot more work to install and remove than a pulley. Especially if you need to upgrade injectors. Don't want to do that.
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 Lotus Exige S310 WTC 2 |
#12 (permalink) |
My injector duty cycles were at 91% so we switched to the Lotus 440cc injectors and now there is plenty room. Injectors are pretty easy to switch out as I'm pretty sure your setup is identical to the MR-S. I am definitely pleased with the results how it wakes up the lower end. More impressed that I can hit "lift" at 4k RPMs.
#13 (permalink) |
IIRC, the stage 2 cams help the low end, but sacrifice the top end power?
#14 (permalink) |
'08-'11 XP National Champ
+1 on the MWR stage 3s we run on our XP car. Ultimately if you are going to get a S/C anyway, they will add power before and after. As Kenny Duttweiler or Corky Bell will tell you a better NA setup will generally give you more Forced Induction performance. Because of the low cam and high cam, the car idles and runs like stock. The only difference is on the dyno and seat of the pants!
fzust 2008-2011 X-Prepared SCCA Solo National Champion Lotus Performance Parts and Accessories Blackwatch Racing |
#15 (permalink) |
Elise Driver
I don't know of any customers wiping out any MWR or Piper cams. I assume I'd get requests for single cam purchases during the repair. I've had none. It is critical that you replace your rockers if they're damaged or worn when installing new cams. If you reuse rockers and your old cam wiped out then your new cam will wipe out regardless of what kind it is.
#16 (permalink) |
Elise Driver
Not at all. With VVL and VVT you can improve both without sacrificing the other. The best gains are in the 3.5-6k range but you do see improvement at high rpm as well.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
