2007 Exige S
Anyone stuffed a 2.5l Boxer (STi motor) in a Lotus?
Random thoughts, wondering if anyone attempted this?
I loved this little motor in my old 04 STi, didn't have any oiling problems, easy to get 500 HP out of it, silky smooth, very reliable, low center of gravity. Can't seem to find out the engine weight in stock form. Rob
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
posts++;
I don't think it would fit in an Elise/Exige, it's a pretty wide motor.
SwaqValley.com Checklist: Graduate (check), Marriage (check), Employment (check), House/Garage (check), Increase wealth (in progress), Lotus Elise or Rossion Q1? |
Not the swap I'd want to do, but crazy ideas are fun.
These guys put Subaru engines in their mid-engine porsche 356 replicas, so they'd know weight, dimensions, and fitment difficulties: SPECIALTY AUTO-SPORTS,Porsche Speedster,Porsche Replica,Porsche Replicas,Porsche Speedster Replica,Porsche 356 replica, Speedster replica,Porsche Speedster replicas, 356 Speedster replica,VW Speedster,Speedster,XK120 Jaguar,Speedster,356A replicas,Po |
#5 (permalink) | |
2007 Exige S
Anyone have the specific dimensions? Thanks, Rob.
#6 (permalink) | |
2007 Exige S
#7 (permalink) | |
you think this engine will fit? it looks too long on either side of the axle... |
#8 (permalink) |
2007 Exige S
No, it would require some chassis modification -- question is, how much modification. That's not the STi motor but good enough for visual -- exhaust and turbo and IC can be reworked -- all those heat shields make it look bigger.
But I think it's doable -- I think valve cover to valve cover is key measurement -- I "think" from axle to front is ok, but need measurements. Thinking salvaged Elise (pending how bad chassis is damaged) -- this would be a LONG LONG term project car (probably a 2-3 year project). I gotta learn how to weld aluminum first - dooh! (details). 10K rpm motors built for 30 PSI can put out about 650 HP. $13K for a new built motor. And lots of parts sources. 1000 HP hmmmm...I'm dubious Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 06-11-2009 at 11:02 AM. |
#9 (permalink) |
My car is really small
I don't think it is a good choice for the engine compartment even for the most ambitious of swappers. There are too many other chices that make much more sence. The 2.5l subaru motors are great and torquey little guys but it would be much easier to fit some other 2 and a half liter FI motor with similar results.
If you really want a subaru motor in a light mid engine chasis, they swap int 914s with relative ease...
05 Safron Yellow "bumbleBee" Not sure I can ever go back to a regular car 84 930 turbo "no nickname yet" 06 WRX Wagon "silverbullet" |
#10 (permalink) |
Drunk on alcohol
Cosworth built Scubbie engine long block for reference
![]() High Performance Long Block Assembly - Subaru Engine Assemblies - Cosworth USA
'06 Evo IX Stage 1E Tuned by Road Race Engineering(Stock:turbo,intake,internals,ECU) Walbro 255lph fuel pump,RC Engineering1000cc Injectors, AVO exhaust,RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband,Zeitronix Ethanol Content Analyzer, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com |
#11 (permalink) |
2007 Exige S
Not finding big HP numbers for the 914.
This type of project would NOT be easy (admit almost crazy) - rear cross member adjustments would be fine, but side to side and axle to firewall room I think is the go or no-go on a project like this. Oh, and if the motor is just too heavy -- but some of the motor weight (whatever that is) can be offset with lack of AC, smog, etc. etc. Race/Track only purpose, not street obviously (certainly not in CA anyway). Rob. P.S. and it doesn't need to make sense either but it does need to retain some sense of cost.
#12 (permalink) |
Drunk on alcohol
How about a Suzuki Hayabusa engine??
![]() The replacement for displacement = 11,000 RPM ![]()
#13 (permalink) |
2007 Exige S
Interesting piston design.
#14 (permalink) |
2007 Exige S
That's only a 1000 rpm more than a built scooby motor. Dont' think a Busa could put out 650-1000 HP, but it would fit and be light weight.
#15 (permalink) |
this will be my new engine($28,000) when that nigerian guy gets back to me with my share of the kingdom:
HOME PAGE... |
#16 (permalink) |
This would be a nightmare to attempt. The boxer is a longitudinal engine, mated to a longitudinal transmission.
Unless you lengthen the car to move the engine forward, it's not really possible. You probably only need ~6 inches of added room, but that's not a trivial task. Just because of this, I wouldn't even attempt it. The chassis is going to be incredibly difficult to safely extend because you're gonna have to change the geometry. Not to mention you'll then need a custom rear clam on top. If you get past that.... Once you get room in there, the rest is going to be pretty easy. You'll need to build new motor mounts and a carriage assembly, and work out the drive shafts (you may actually be able to use the Subi shafts). For the motor mounts and carriage, you also need to keep in mind the difference in the torque direction of the engine. I transplanted a EJ25 into a 1976 BMW 2002. By far the hardest part was engineering the engine bay. Going from a chassis meant for an inline 4, to a boxer 4 presented all kinds of problems. We got it to work though, and now that it's been done once, it would literally be a piece of cake to do it again. |
#17 (permalink) |
If I was going to go to the trouble to put an EJ257 In there I would probably just go for an LS7 swap. I am semi serious.
I think renegade Hybrids have the EJ swaps for the 914. Motor mounts and kit parts are available IIRC
#18 (permalink) | |
2007 Exige S
![]() Probably my worse nightmare -- but I need a good long term project and it would NOT be for my existing Exige S -- like I said, most likely a well used and/or salvaged Lotus Elise -- strip the car down and do a rough CAD layout. The more difficult it would be to produce, the more likely it'll truely be unique. But it's gotta remain sane on the cost front - labor will be me of course. Rob
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 06-11-2009 at 04:17 PM. |
#19 (permalink) |
OSX Black hat
honda K series is a good choice, and its already been done a bunch of times, the audi motor too.
iv'e heard of a few failures on the chain tension on the m96 but you never know if you're just seeing the anomalys.
#20 (permalink) | |
