Old 03-18-2006, 12:09 PM   #81 (permalink)
PWR2W8's Avatar
Originally Posted by Casey@ForcedFed
What kind of sealant are you using?
This is being done at the dealer. I do know that the dealer is pissed because the sealant they are using is expensive. I don't believe it is the sealant since the first pan leaked through a pin hole crack in the weld and the second pan is warped (not level) to the mating surface.
Brad
Michigan
PWR2W8 - I'm Back!
PWR2W8 is offline   Reply With Quote
Old 03-18-2006, 12:10 PM   #82 (permalink)
PWR2W8's Avatar
Originally Posted by kestrel74
Brad, I'll be getting a chance to see it on Monday.....dropping mine off for some service/warranty work.
John,
Check it out when you are there. Just tell Don Reed to bring you back to the car, he'll show you what's going on.
Brad
Michigan
PWR2W8 - I'm Back!
Old 03-18-2006, 12:20 PM   #83 (permalink)
PWR2W8's Avatar
Originally Posted by MyElise
Put mine on the center console in front of the e-brake.
What boost levels are you running?
Brad
Michigan
PWR2W8 - I'm Back!
Old 03-18-2006, 12:25 PM   #84 (permalink)
Casey's Avatar
Try using GE silver silicone for aluminum...they have it home depot. It's cheap and has worked better than everything else I've tried, including the factory stuff.
Casey is offline   Reply With Quote
Old 03-18-2006, 12:53 PM   #85 (permalink)
Mountain Road Nut
ChrisH's Avatar
I was curious about the properties (temperature range, recommended uses, etc.) of GE sliver silicone for aluminum, so I went to GE's website for their silicone compounds:
http://www.gesilicones.com/
However, I can't find what you are referring to, and GE seems to have thousands (okay, maybe hundreds) of silicone RTV products. If you have a tube handy, do you have a more exact name for it and the GE part number so we could look it up?
Old 03-18-2006, 01:09 PM   #86 (permalink)
Casey's Avatar
GE stock#GE5050 silicone2 aluminum and metal...temp range -65f to400f.
We have used this on all the cars we have put this pan on and have had 0 failures.
Old 03-27-2006, 12:47 AM   #87 (permalink)
A smile a mile.
NMRJock's Avatar
Charles gave me a tour of your car on Friday. I am VERY impressed at the work he's been doing on it. I think that you will be quite happy with the attention to detail in the install.
Are you getting their shortened shifter while they've got it? I tried it out in another car while I was there and tacked it onto my order...
Paul Parkanzky
Magnetic Blue with Biscuit Touring, LSS, Starshield
NMRJock is online now   Reply With Quote
Old 03-27-2006, 09:48 AM   #88 (permalink)
Porsche-Pro
perryeyges's Avatar
Just curious why you didn't just re-weld the first pan or use an internal epoxy patch compound on it? These pans are not OEM and may require some "adjustments".... I guess I'm used to making repairs on "new race parts".
Hand fabbed components often require some "additional work" to get them up to speed.
A warped mating surface is another story altogether though !!
perryeyges is offline   Reply With Quote
Old 03-27-2006, 12:30 PM   #89 (permalink)
Eyelise's Avatar
Mine did require a bit of "working" Several of the welds overlapped the pan bolt area and had to be grinded. The windage tray had to be trimmed and the pan modified to accept the dipstick. It wasn't cheap at dealership labor rates, fortunately I have checked for leaks and thus far nothing.
Eyelise is offline   Reply With Quote
Old 03-27-2006, 04:28 PM   #90 (permalink)
G-200 Driver
kestrel74's Avatar
John,
Dropped my CO off today.... I saw your new, new, new oil pan --beautiful !!!! I like your aviation-type switchgard also !! classy !! ( those things aren't cheap either ! ) Can't wait to hear it .... give me a call when you're out driving sometime... or I'll see you on the 8th.
Old 03-29-2006, 07:21 PM   #91 (permalink)
PWR2W8's Avatar
Finally back in town from a long needed vacation. The Morosso oil pan has held things up but it's on the car now. We should have oil back in her tomorrow and finally get it on the lap top to clean up the E-manage program. I am also impressed with the work A/E has completed on my car. They are making sure everything is 100% before I get it back. I am very anxious to drive my car and I'm sure it's just a matter of a few days until this can happen. Of course this all depends on the oil pan actually working.
As for tweaking the oil pan, here are my thoughts.
1. The pan was designed for the Elise, why should you have to trim anything?
2. Reweld a $500.00 oil pan? No thanks, make the product right.
3. Try implementing a quality system and you won't have these issues.
Sorry if I'm being a bit harsh but it's just not good business to supply parts that need to be reworked to work properly.
Brad
Michigan
PWR2W8 - I'm Back!
Old 03-29-2006, 07:31 PM   #92 (permalink)
PWR2W8's Avatar
Paul, My car will get the shortened shifter - I loved the feel.
Brad
Michigan
PWR2W8 - I'm Back!
Old 03-29-2006, 07:33 PM   #93 (permalink)
PWR2W8's Avatar
John,
I hope to have it back next week I'll call you as soon as I get it back.
Brad
Michigan
PWR2W8 - I'm Back!
Old 03-30-2006, 03:44 AM   #94 (permalink)
G-200 Driver
kestrel74's Avatar
John,
I'll see it again today.... You had better get the Valentine 1 mod for your car now. I got mine on monday ( been testing it out in the VW ) it's great. Best radar detector I've ever used.
Old 04-15-2006, 05:08 AM   #95 (permalink)
PWR2W8's Avatar
Tuning has held up the completion of the turbo. We are very close but not quite there yet. The car looks great and the attention to detail with the install is top notch as expected with Auto Europe.
I think we are finding that the Lotus ECU is a pain to piggy back. Should know a lot more next week if the plan we have is implemented.
Brad
Michigan
PWR2W8 - I'm Back!
Old 04-15-2006, 06:01 AM   #96 (permalink)
ciexlsyd's Avatar
What are some of your issues with the tuning? Is it running lean at boost? Are you running off the maf or map?
On my Mr-s it was really rich at low rpms and then when boost hit it leaned out to dangerous levels.(14.7)
K
ciexlsyd is offline   Reply With Quote
Old 04-15-2006, 07:23 AM   #97 (permalink)
Bruce's Avatar
I thought the Hass kit came with tuning. Your install is really dragging on for something that's supposed to be a complete engineered kit.
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate
Bruce is offline   Reply With Quote
Old 04-15-2006, 04:20 PM   #98 (permalink)
ciexlsyd's Avatar
It does come pre-tuned, but it has a basic map on it. You will have to get it tuned by someone who is familiar with emanage. I took mine to Matt at MonkeyWrenchRacing.
Old 04-16-2006, 07:24 AM   #99 (permalink)
soulmn's Avatar
That might be why you had your leaning out problems.
soulman
soulmn is offline   Reply With Quote
Old 04-16-2006, 07:31 AM   #100 (permalink)
Bruce's Avatar
I guess since you're new you don't know about the Monkey Wrench Elise turbo installation fiasco.
