Old 03-21-2007, 04:33 AM   #21 (permalink)
James*BuzzmanNitroBlaster
The Buzzman's Avatar
Originally Posted by The Buzzman
I dyno'ed out at 229 hp at the wheels and 185 torque with a Turbo XS intake and a Zex 75 shot, you know what!
Fuel air mix is perfect, no problems.
Other than that.....all stock and extremely quick, quick, quick.
How do I attach my pic of the dyno to post it for all to see?
Attached Dyno below. I will get a cd for a clean digital shot of my dyno.
2004/2005 Elise, Sport pkg., Red Lux. pkg., hard top, Exige silver wheels, 175 whp with a TurboXS Intake, and now a Zex Wet 75, Of You Know What!.........Gives Me 229whp and 185 torque to the wheels, with no heat blankets or special anything needed. It lasts a long time with the 75 shot and two or three gears needed here and there. Fuel Air Mix starts around 15 and drops to the 12's all the way to 8200 rpm's...nice and safe. No lag, no bogg, just instant take-off!
The Buzzman is offline   Reply With Quote
Old 03-21-2007, 06:34 AM   #22 (permalink)
Drunk on alcohol
25psi_Elise_Killer's Avatar
Bone stock pull versus stage 1 mods
'06 Evo IX Stage 1E Tuned by Road Race Engineering(Stock:turbo,intake,internals,ECU) Walbro 255lph fuel pump,RC Engineering1000cc Injectors, AVO exhaust,RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband,Zeitronix Ethanol Content Analyzer, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com
25psi_Elise_Killer is offline   Reply With Quote
Old 04-18-2007, 10:12 PM   #23 (permalink)
I have 4-Wheel OCD
raygr's Avatar
Exige S Dyno
Here is my dyno set from today. Exige S, Larini Exhaust, Daytona intake, otherwise stock (stock cat). Note the 219 hp at the wheels. Not bad for a car that is supposed to be 220 hp.
We also drilled a hole just downstream from the intercooler to measure boost pressure. For some reason, the boost reading was uneven. Not sure about that, but it does look somewhat consistent. I think the average boost reading (using an analog pressure gauge) was about 6.5 psi. Note in the first run, we did not have the boost sensor hooked up.
Ray in Washington State - 06 Elise, 07 Exige S
www.mentalmotoring.com
raygr is offline   Reply With Quote
Old 04-18-2007, 10:20 PM   #24 (permalink)
I have 4-Wheel OCD
raygr's Avatar
Here is a comparison of my N/A Exige with the Exige S (from the same dyno shop).
N/A Exige: Larini exhaust, Daytona intake, ForcedFed headers, ForcedFed sport-cat.
Exige S: Larini exhaust, Daytona intake. (stock cat)
Old 04-18-2007, 11:14 PM   #25 (permalink)
finally someone posted this!
what mods does each car have?
vortrex is offline   Reply With Quote
Old 04-19-2007, 08:21 AM   #26 (permalink)
I'm Lovin' It!
ChrisB's Avatar
Images: 1
It looks like the variable cam switchover point under these conditions is about 4500 RPM on the S.
Old 04-19-2007, 08:27 AM   #27 (permalink)
Drunk on alcohol
Looks like the engine knocked around 6200 RPM
Old 04-19-2007, 08:52 AM   #28 (permalink)
I have 4-Wheel OCD
raygr's Avatar
How so? Are you referring to the N/A Exige run? That dip is the cam switchover.
Old 04-19-2007, 02:56 PM   #29 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
Thanks a lot for posting! A 40 HP difference!!! you have the stock cat on there?
I'm going to try to have mine done still. I've only done the desnorkel/funnel mod. Still haven't put on my exhaust yet.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 04-19-2007, 04:40 PM   #30 (permalink)
I want to know what has been done to the S to get 220 WHP! that's about 30 HP more than stock, no?
Old 04-19-2007, 04:46 PM   #31 (permalink)
OSX Black hat
charliex's Avatar
cam switch on the S is 4400-4600 under load , 6000-6200 under city driving
Old 04-19-2007, 06:24 PM   #32 (permalink)
I'm Lovin' It!
ChrisB's Avatar
Images: 1
Charlie, any thoughts on the shallow torque valley in the 7,000-7,700 range? It's very consistent run to run. The A/F and boost (as ragged as the measurement is) doesn't seem to be a cause. Timing pulled for some reason maybe? Or a result of intake/exhaust resonance?
Old 04-19-2007, 06:45 PM   #33 (permalink)
Mods are good for you
Dave's Avatar
Mine...
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 05-08-2007, 08:08 PM   #34 (permalink)
Phanthom Black Exige S
funS111's Avatar
Exige S
FF street header w/ highflow cat
Arqray single ti
First run is a 3rd gear roll on
Seccond run is a 4th gear WOT
07 Exige S
FF street header w/ De-cat, Arqray single Ti, Cup airbox, Ohlins Track, Matt Black RACs,
Moroso Pan, RTDbrace, Schroth Profi II, RLS intercooler & pipes, AP Racing 4 corner, Track mounts
funS111 is offline   Reply With Quote
Old 05-09-2007, 04:08 AM   #35 (permalink)
mikelr's Avatar
S1 Exige Rover 1.8L VHPD N/A (1580 lbs car)
stock header, Yoshimura exhaust , Piper 1444 cams with Emerald ECU (stand alone)
Lower map is last season before I ported the head.
Power to wieght ratio of 8:1
00' S1 Exige (7.14lbs/hp)
94' S4 Esprit
07' Ram Quad cab 3500 hauler
mikelr is offline   Reply With Quote
Old 05-10-2007, 08:25 PM   #36 (permalink)
I have 4-Wheel OCD
raygr's Avatar
Exige S w/FF Headers
Exige S, Larini Exhaust, FF street headers & cat, ReVerie Daytona Intake, Shell V-Power 92 gas.
This compares my best run w/o the headers with the best run with the headers. The best run was obtained by spraying compressed air into the roof intake to cool the charge-cooler. Intake air temp went from 85 deg F to 123 deg F in 1 pull!
I'm concerned now that it is too lean. We may install larger injectors.
Old 05-12-2007, 07:49 PM   #37 (permalink)
Haxord but mine
Westrock's Avatar
Man, ain't that a hoot..overrate the Exige and underrate Exige S
Heres mine.
06 Exige
Arquay Twin Muffler
Mystery Lotus Of South Bay reflash (done in 06)
Video of Dyno
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
Old 05-14-2007, 02:41 PM   #38 (permalink)
shay2nak's Avatar
dynosaur! now that is funny.
what do you mean "mysterious reflash?"
Old 05-14-2007, 03:32 PM   #39 (permalink)
2zz exorcism complete
dstevens's Avatar
Images: 4
05 Elise, 7000 miles, all stock. Dyno measures at the hubs, so expect a higher reading than an inertia dyno. The lack of go between 4500 and 6500 rpm is apparent.
dstevens is offline   Reply With Quote
Old 05-16-2007, 10:53 PM   #40 (permalink)
Haxord but mine
Westrock's Avatar
Because it was done last year at Lotus Of South Bay, before I owned the car, and before all these various options were on the market. So I would assume that its the Lotus Sport ECU, but I can't say with 100% certainty....but its obviously NOT stock
-David
