C-ONE/ KAZ - 6-Speed Gear Set - Top Speed
Hi guys
I have just fitted the 6 speed gear set to my car, mid gear acceleration is awesome, lot quicker and car stays in powerband longer Quick question, any one know the top speed of this gear set with the standard 4.55 final gear ?? I can't test this on public roads. On Transmission Gear Ratio Calculator, I got 237 km/h for C-One gear set with 4.55 and 283 km/h for standard gear set with 4.8 final gear. This is based on theoretical calculation. Pretty sure we cannot get 280 + top speed in a 260+hp lotus Any feedback will be appreciated so I won't get disappointed on track SIMON
Krypton Green Exige with Komo-tec 280S Photo Gallery : http://s229.photobucket.com/albums/e...omo/?start=all Modification List : http://s229.photobucket.com/albums/e...SIMONLAU-1.jpg |
elf
I haven't tried it.
But I recall reading here someone reaching 170mph+ (270km/h) with additional power and gears. So it sounds possible. Still run into aero issues though so it wasn't be quick getting there. With some guess work you might find the story I recall using search. |
#3 (permalink) | |
2008 Exige S Sport in HK (S240) almost stock. |
I have c-one final gear
My car is elise R (192hp)
I have c-one final gear(4.8) only. I could reach 240km/h before I changed but I can't reach that speed. Because stock 5th gear 8500rpm is 240km/h and c-one(only final) 5th gear 8500rpm is 225km/h. I can reach 225km/h much earlier but 6th gear cannot accellerate lacking of power. After changing final gear I just only 235km/h at downhill.
2007 Elise / Laser Blue / Toybox48 wheel / Larini Sports Exhaust / Larini Sports Cat / Ohlins 2-way Suspension / liquidcaddy cupholder / Stock harness bar / 4 point seat belt / white double line stripe / 3.3kg Fire Extinguisher / Engine Room LED Light / Engine Hood grill modification / V-Shield(like Starshield)/C-One Final Drive(4.529->4.8)/ACT XTSS clutch Kit/Fidanza Aluminum Flywheel(7.5lbs) |
Thanks Dleogml, actually I had the C-one 4.8 final gear fitted. I think it was a very good upgrade for street driving. Had the C-one 6 gear set fitted, mid gear acceleration is very good but highway crusing is kinda of compromise as the engine is running on a higher rev. I cannot test on public roads but do feel the new gearset will have a lower top speed than the larger final gear. Want to know the actual !
08 Exige S 240
Please keep us updated, im sure there is a few guys on here who would love to hear your outcome ...
Do you think the ratios are too short for your 280kit ? I looked at this option and thought for 280hp+ it would make the car very busy to drive on track. |
#7 (permalink) |
Hi cup 240
i have yet to try the top speed but on street driving, in gear acceleration is very good, the car feels alot more in the powerband and feels much torqier. You will change gear more frequently than 4.8 with standard gears but it doesnt bother me. I think this is a good mod, 2 other Exige S in HK has this upgrade as well as a 2-11 for track. From my mechanics comment, top speed is around 240km/h Simon
#8 (permalink) | |
Elise Test Pilot
Can you tell me what other parts you needed to fit this, other than the Kaaz gearset? In older threads, I've asked, but the owners weren't sure. Something about a Toyota Celica synchro or another part, etc...? MikeVR4
Mind the Gap! |
#9 (permalink) |
08 Exige S 240
So just to recap ...
You have the following right ? gearset and 4.8 final drive ? Gear Sets - Monkeywrench Racing - Celica - MR2 Spyder - Corolla - Lotus Performance Solutions Thanks for your advice, its clearing up a few questions i had ;-) |
#11 (permalink) | |
Republic to Thugocracy
We have fitted a dozen or so of the Kaaz gear kits and have had no issues to date. From my conversations with a Kaaz USA, Kaaz build the gears to hold up to around 210 foot ponds of torque. Above that and you are on your own.
"This is the moment when we must come together to save this planet. Let us resolve that we will not leave our children a world where the oceans rise and famine spreads and terrible storms devastate our lands." Community Organizer and Chief Obama...now intervening with natural occurrences!
#12 (permalink) |
I can confirm the gears from the gearset is a lot strong than OEM, the only weaklink is the original final end gear. Pity no one makes a 4.55 stronger end gear
#14 (permalink) |
133 stock to 210+. Are you using that Texas, GWB fuzzy math?
![]() http://www.mmsport.com.au/download.php?fid=34
#15 (permalink) |
2/3 hp to the paws.
The OEM gears in most all Toyota boxes are known for taking quite a lot more than stock torque with few complaints, except in relatively rare cases. If a company is putting a 210 ft. lb. spec limit on their gears, personally, I wouldn't use 'em.
#16 (permalink) | |
I'll note to Kaaz you personal choice of not using them. But I am not sure why you would comment or even use shorter gears. Do you use shorter gears from another company? Do you road race?
#17 (permalink) | ||
2/3 hp to the paws.
#18 (permalink) | |
If you are making more than 210 foot pounds of torque shorter gears of this design are probably not what you are searching for. This setup is probably too short. What sanctioning body and class do you run with?
