Old 06-14-2008, 05:49 PM   #1 (permalink)
Systemz's Avatar
Cam Rocker Arm Wear Update
My car has been with a mechanic for a few weeks. When it first was taken apart, the apparent problem was one cam shaft (intake side?) was badly worn, while the other was ok. It also ended up that the Rocker arms on that side were badly worn too, allowing these little shims, that sit below the rockers to space them correctly, to simply fall off. One of them fell off and it caused a valve to bend in and dent the hell out of the cylinder head/cylinder. I think it was the number 3 cylinder for reference. The mechanic should be finishing pretty soon, but i have to tell you, for a "bullet proof" engine, this scared the hell out of me. About $1,400 in parts, and a little over $2,000 in labor. 4 months out of warranty, lol.
91' Elan M100
04' Lexus Is300
05' Elise
Systemz is offline   Reply With Quote
Old 06-14-2008, 05:57 PM   #2 (permalink)
tesprit's Avatar
Sorry to hear about this. My car is going in for cam/followers replacement as well, but the wear isn't as severe as yours. This really should be a wake up to anyone out there with their warranty about to expire to go get their cam cover removed for a visual inspection of the cam lobes on the intake cam even if you don't have any outward signs/symptoms of cam or follower wear.
Old 06-14-2008, 06:21 PM   #3 (permalink)
Hoon
Amarao's Avatar
Is there any preventive maintenance that can be done to protect against this?
Amarao is offline   Reply With Quote
Old 06-14-2008, 06:22 PM   #4 (permalink)
lotusforsale's Avatar
Images: 8
I had mine checked by the Lotus Dealer about a month ago. The car has relatively low miles (2005, about 9500 miles when checked), but the PO had hit the rev limiter a lot.
Fortunately, no signs of wear....
lotusforsale is offline   Reply With Quote
Old 06-14-2008, 06:44 PM   #5 (permalink)
tesprit's Avatar
At this time, no there is nothing you can do. It only seems to happen to some of the engines and there is no known cause or way to prevent it. After seeing mine and knowing how easy it has been driven, I am in the camp of those that say the cam lobe hardening process was done incorrectly and the these cams were defective from day one. My car only has 2,900 miles on it and that lobe looked like it had at least 150,000 miles on it. Everything else in the valve train looked spotless and brand new.
Old 06-14-2008, 06:53 PM   #6 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Scary....... I almost want to save for it as I feel it's inevitable and I don't want it to screw me.
Old 06-14-2008, 08:31 PM   #7 (permalink)
larez2's Avatar
RE: preventative maintenance?
You can pull off your valve/cam cover and visually inspect the cam. Some guys that experienced cam lobe wear have mentioned a severe ticking sound from the engine, almost like a diesel engine, not quite a preventative thing, but at least some warning.
I wonder if this would work. I was talking about cams with buddy, he's a car guy - big ford guy and he put a performance cam in one of his cars that had been cryogenically treated. He said that treatment hardens the cam. I googled it and came up with the explanation:
One Cryo Cryogenic Tempering for Racers - Performance Racing Industry Magazine
or you could just buy a new or performance cam (not sure if any performance cams exist for our cars yet though), i wonder how much they are brand new from Lotus - one has to think a new one *should* be durable/reliable.
hth,
Larez2
larez2 is offline   Reply With Quote
Old 06-14-2008, 08:37 PM   #8 (permalink)
Ave
You know how to whistle
Ave's Avatar
Just FYI, that's great advice for those still under warranty. Get it checked. I'm about 6 months out of warranty, and my car has been a prisoner for the past week and a half, getting new cams on my dime. I don't have a final quote yet, but parts are about $500. *sigh* I suggest, as Icedog has in the past, that we start a campaign to write to Lotus USA.
Wendy
'05 BRP, baby #5!
Ave is offline   Reply With Quote
Old 06-14-2008, 08:41 PM   #9 (permalink)
Hoon
Amarao's Avatar
Piper makes cams for the 2zz - Piper Cams frames page
My concern is that I drive my car hard all the time. With 7000 miles in 3 months and lots of time spent at high rpms I wonder how mine are looking.
Old 06-14-2008, 08:46 PM   #10 (permalink)
A smile a mile.
NMRJock's Avatar
I'm worried about mine too. My car went out of Warranty in February.
I considered tearing it apart and looking at them, but then realized that there's no point now that it's out of warranty. I'll continue to drive it and try not to think about the cams. If they wear prematurely I'll fix it when the time comes. I certainly won't be happy about it. There is obviously a problem and I think that Lotus should be doing something to make this right. Compensate the people that have had to repair this out of warranty at the minimum.
Paul Parkanzky
Magnetic Blue with Biscuit Touring, LSS, Starshield
NMRJock is offline   Reply With Quote
Old 06-14-2008, 09:39 PM   #11 (permalink)
tesprit's Avatar
I hear what you are saying, but waiting for the cam to wear so badly that the cam follower finger breaks off could also mean you will need work on the valve and guide that has been beaten to death by that worn follower. If you catch the wear early before it affects the way the engine is running, you will only need a new cam and followers and not be required to have the head removed for valve repairs. Unfortunately the cost to fix this problem goes up with the longer you wait to replace the worn parts. Removing the cam cover is a very straightforward job that does not require special tools and does not take that much time. I think it is time and money well spent to minimize later expenses whether your car is in warranty or not.
Old 06-18-2008, 07:50 AM   #12 (permalink)
Guys ... please see this thread, there's some momemtum building to get Lotus to do the right thing The "Post Mileage" and "What Broke" Thread?
GTI-Guy is offline   Reply With Quote
Old 06-18-2008, 08:02 AM   #13 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Also PLEASE post your engine number here Post Engine No.-Worn Camshaft Lobe we need this info.
Old 06-18-2008, 08:13 AM   #14 (permalink)
I drank what?!?
Icedog_16's Avatar
Systemz, sorry to hear about your problem. I added you to the list in this post.
Code 1302 & 1301 years and miles
If anyone has had this problem that doesn't appear on there, please post so I can add you.
Icedog_16 is offline   Reply With Quote
Old 06-18-2008, 08:51 AM   #15 (permalink)
Head LOONY
tvacc's Avatar
I am sitting here thinking. I may just buy a set of the Piper cams and have them put in my car the next time I go to Auto Europe.
What is the exact piper number do we need and what is the cost?
Tony Vaccaro
2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter,
www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus
Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances
tvacc is online now   Reply With Quote
Old 06-18-2008, 08:53 AM   #16 (permalink)
Head LOONY
tvacc's Avatar
Maybe we can get a group buy on the Piper Cams?
Tony Vaccaro
Old 06-18-2008, 08:55 AM   #17 (permalink)
Head LOONY
tvacc's Avatar
Tesprit...
Maybe you should just buy the Piper Cams and have them put them in your car. I wonder if you could. What difference would it make to Lotus. Just keep the cams that Lotus sends you.
I am now sorry I did not just do that. Cost of the Cams is probablay (dont know the cost yet) not that much compared to the labor....
Tony Vaccaro
Old 06-19-2008, 05:46 AM   #18 (permalink)
What is the rationale of the Piper cams? Do we know people are using them and they are not wearing out like the Toyota cams?
Old 06-19-2008, 06:38 AM   #19 (permalink)
tesprit's Avatar
I'm not so sure the Piper cams are the way to go. I found some pricing info. on them here Piper Camshafts - Toyota 2ZZ-GE and $949 (on sale) does seem to be close to Lotus stock pricing seeing as you are getting a new exhaust cam as well. The problem I see with the Piper cams is that, as far as I can tell, they only come in special performance grinds which may or may not be compatible with the tuning in our Fed. ECMs because they are designed for the "rest of the world" market cars. Even if they are compatible with our ECM tuning, I am quite sure that because of the special grinds they are not OBDII or emissions compliant and this would be a major problem for me. Does anyone know if they make a stock grind for our cars?
Old 06-20-2008, 07:59 PM   #20 (permalink)
Time to DRIVE
adamant's Avatar
Images: 2
If they are from stock cores would that not mean they have
the same (lack of) durability ?
2006 Exige Chrome Orange
adamant is offline   Reply With Quote
