Mikey likes it!
Camshaft cover defect causing rocker-arm breakage (P1302)?
Badnis on exiges.com—in a thread documenting rocker-arm breakage and P1302 codes—suggested that the high-lift intake cams may be getting improper distribution of motor oil from the overhead oil feeds in the camshaft cover. He backed that up with a photo of a test conducted in his shop where fluid was circulated through the camshaft cover system, which appeared to show less-than-desirable flows.
Well, I thought this was plausible, and—along with my buddy Nick (ZTEC)—felt it would be worth trying to repeat Badnis’ experiment. We first tried to avoid any mess by trying a quick CSI-type setup (sorry, no lasers!) to see if there might be anything to this. The first shot is Badnis’, from exiges.com, the next two are our dry tests. The results warranted further investigation.
-Michael '05 Nighfall Blue with Rallye Stripes! |
Mikey likes it!
part 2
The following shots are the wet experiments. It’s clear that the direction of oil spray for intake cam lobe #3 is directed differently from the other seven oil streams.
Careful measuring further shows that—since the oil distribution structure in the camshaft cover is narrower-than, and centered-over the intake/exhaust cam pair—the spray streams must be directed slightly laterally to be effective. It is obvious (at least, in my case) that Intake #3 is directed inward. In order to adequately coat the leading and back side of the spinning cam lobe, the oil stream should be directed toward the centerline of the spinning camshaft—over the High-lift cam lobe. It’s likely designed this way since the rocker-arm pad (at the top of the tappet) is not a low-friction roller, which I’m sure generates a lot of heat. Nick does a great (and creative) job here of setting up the ‘lab’.
Mikey likes it!
Bottom line....
...if those of you who have repaired (or will be repairing) one of these, have you replaced the camshaft cover? Just consider that it may be the cause of the problem.
Anybody who has had this repair done under Lotus warranty.... did Lotus replace the camshaft cover?
Wow!
Pretty damn good illustration!
The trick is how to fix it!
'06 Krypton Green Elise (touring/LSD/HT) '05 Magnetic Blue Elise (sport/HT) dedicated track car '07 Jeep Wrangler Unlimited (4 door!) Excelsior-Henderson Super X/Ducati Monster 620 ie 3 Series BMW/Acura MDX Carver Yacht |
#7 (permalink) |
2006 Lotus Elise
would it be possible just to re-drill the hole?
“The biggest cause of trouble in the world today is that the stupid people are so sure about things and the intelligent folks are so full of doubts.” Bertrand Russell John 3:16 |
#8 (permalink) |
Hydrocarbons Rule
good find and good demo, would be nice to see a few others done in this way to find out if they are all bad, or just a certin few. Would also like to see a Celica 2zz one done as well to see if toyota tried to hook lotus up...
2006 Exige; TVS Supercharger, Adj Sway Bar, Ohlins Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Clutch, BOE Exhaust, Black Volk Racing CE28N's w/ Toyo R1R's, 2 piece rotors, Pagid Black Pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Panels), Dry Carbon rear Diffuser, Harness Bar, BWR Gauge Mount, OMP Superquadro steering wheel, LETSLA Short Shifter, V2arms, Rear Tow Link Brace, RLS Battery Bracket, BOE Tow Bar, Stickers. |
#10 (permalink) |
Great work! I posed the theory of a lubrication problem in the cam cover to my dealer after my failure and never heard any followup from the dealer or Lotus. At the time I didn't know that the problem was endemic to the #3 cylinder and speculated that there culd be an obstruction in one f the passages. Great to see someone document this!
Alan '05 Elise, Magnetic Blue |
#11 (permalink) |
Third Eye Open
Visually you could see the #3 "sprinkler" was off on the intake side if you were looking down the line from the side. It is obvious this was not intended during manufacturing and is a defect in at least Michaels valve cover - It was interesting to see how the fluid reacted under different pressures as well - More pressure and the stream staightened up pointing the fluid further inboard away from the cam.
At the very least a visual inspection of your cam lobes are in order and if you see any wear on the lobes that is not in line with your mileage or obviously different than the others, Take a good look at your valve cover and the lubrication system. Now comes the speculation into how many made it past Quality Control into our cars? Thanks Joshua (lotushark) from Fourniers for the phone advice
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Hawk HT-10! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's! Knowledge is knowing a tomato is a fruit, wisdom is not putting it into a fruit salad. Last edited by ZTEC; 01-06-2008 at 07:54 AM. |
#12 (permalink) | ||
Mikey likes it!
That'd be difficult; size, direction, position.... plug original hole?
(sorry, there are probably some who would actually go through the trouble)
#13 (permalink) |
You can replace the oil shower tubingwith similar size tubing, but it is possible to braze or weld up the holes and then add correctly aim new ones at selected points along the cams to lube and cool better than stock. I have done this recently as part of the blueprinting to improve the details not possible in the manufacturing process.
Another point to consider is the viscosity of the fluid (hot oil) you are spraying versus the size/shape oriface in the tubing. Just as with the oil squirters in the block, the size and shape will determine the spray pattern and volume. The holes earlier in the circuit may need to be smaller than the ones that are fed oil at a slightly lower pressure due to being located later in the circuit. If you alter the tip shape of the drill bits you are using to re-drill the holes, you can produce a small cone in the hole opening that produces a cone-shaped spray pattern instead of a simple stream. This will allow the oil to cover a slightly wider area of the cams and rockers. I used smaller holes than stock, but more of them. Then I drilled the openings using slightly larger bits with varying narrow-angle tapers cut into the ends to produce small cone-shaped jets. Oil drain back in the head and block can be improved as well. The blocks and heads of the 2zz-ge engines I have, all needed the considerable internal casting flash removed, and a good coating of Glyptol or other oil shedding coating. Just my .02, but I hope it helps.
Everything I post is my opinion, and tends to be notoriously WRONG. Anything that is correct, can only be attributed to my being dropped on my head as a small child - repeatedly. Most of what I know is a result of breaking something first. |
#14 (permalink) | |
Future 2ZZ-GZE member...
VERY NICE DETECTIVE WORK!!!
Was it like that from factory, or did it deviate after lots of use in LIFT???
#15 (permalink) |
Third Eye Open
The lubrication system is a static tube in the valve cover itself with no moving parts just tubing with holes designed to spray Oil on the high lift cam lobe. Mileage or driving style has no effect on it's condition or performance.
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Hawk HT-10! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's! Knowledge is knowing a tomato is a fruit, wisdom is not putting it into a fruit salad. |
#17 (permalink) |
That sucks....Do you have any pictures of the cames/head to show the 3rd lob and the related wear? I'm also assuming that this is the same on the toyota cars themselves that have the same engine and not 'Lotus' specific? I also agree we'd need to "test" them as well. Then it might have to go to Toyota directly instaed of Lotus....
06 Evo IX SE GG RobiSpec'd/TTP Tuned |
#18 (permalink) | |
Third Eye Open
#19 (permalink) | |
Moderator Extraordinaire!
#20 (permalink) | ||
Mikey likes it!
| Thread Tools | |
| Display Modes | |
