Old 01-08-2008, 08:41 AM   #81 (permalink)
i ran into a similar situation on a celica i was working on. at first i though the top of the valve broke where the shim sits, but now its possible that the rocker failed and that broke the valve. unfortunatly the valve fell in the cylinder and smacked the piston. it broke the valve guide. that was a simple fix. the piston was fine, so a new valve, rockers set and cam, and valve guide was needed in the repair.
2001 Celica GT-S Turbo
1990 Celica All-Trac Turbo
1997 Supra LE TT 6 Speed
Smaay is offline   Reply With Quote
Old 01-08-2008, 09:53 AM   #82 (permalink)
Meow!!
darkSol's Avatar
Ohhhh man that hurts to look at those pictures.
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is offline   Reply With Quote
Old 01-08-2008, 10:11 AM   #83 (permalink)
Boosted2.0's Avatar
Interesting. I have a couple 2ZZ valve covers in my garage. If I remember I will check the flow on them squirters tonight.
Boosted2.0 is offline   Reply With Quote
Old 01-08-2008, 10:23 AM   #84 (permalink)
ZAMMY
OFFSET VALVES!
a novel idea!
those pictures hurt.
toyota prices are not cheap.
my two cars have not had any codes, i just took the elise apart for precaution.
sam
Old 01-08-2008, 10:42 AM   #85 (permalink)
I'd rather be doing vvv
Ruchmate's Avatar
Is there anything that can be done to prevent this from happening to my '05? Or is it that after I inspect my valve cover and see a possible missalignment I just have to live with it?
2005 Ardent Red Elise. Sport, Touring, Hardtop. Stuff done (feel free to ask me about any): Moroso Oil Pan, Sector111 Micro Mirror, carpet buttons, re-enforcer, braille battery, Nitron Quickratio steering rack, SS lines, painted console, HIDs, Ohlins Sport, BWR front sway bar, BWR supercharger, 2Bular 6" Ultra Exhaust
2005 Suzuki SV650 nekkid
Ruchmate is offline   Reply With Quote
Old 01-08-2008, 12:17 PM   #86 (permalink)
ZAMMY
keep in mind, this, so far, is all circumstantial evidence.
it could still be metallurgy or such.
to get my squirt that was a bit off aligned, i put the back end of a #54 drill and slightly bent the orofice so it seemed to squirt in the correct direction.
remember, this is water i used and i don't know the fluidic relationship between that and the oil we use.
i had no problems, i only looked at it as a precaution.
and, it was not #3 squirt that was off in my valve cover. it was #1 IN.
looking at the cams is not a big job, it could be done in a couple of hours at most.
sam
Old 01-08-2008, 12:41 PM   #87 (permalink)
sam
My car took 60 days.
Just sayin'.
Brennon is offline   Reply With Quote
Old 01-08-2008, 12:42 PM   #88 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
sam
Sam,
I respectfully am going to correct you here
I had your pics as #3 intake was off just like Insane's and your Exhaust #1 was a bit off as well ! lets compare pics!!
First Insanes pic showing the intake side #3 off
then yours showing the exact Intake #3 off as well - Orientation of the cover is the same!
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
ZTEC is offline   Reply With Quote
Old 01-08-2008, 01:54 PM   #89 (permalink)
ZAMMY
ZTECH you're right, it was off also.
i may have 'twiddled' that one, too.
good eye!
i did notice that while the water is squirting, a touch with the finger will make the squirt sometimes change and stay that way til you finger it again.
(HELL GETTING OLD!)
it's back together again, hope i haven't forgot anything....
thanks, sam
like red green says, "we're all in this together"
Old 01-08-2008, 04:13 PM   #90 (permalink)
できそこないの傲慢嫌い
carlover's Avatar
I am incredibly impressed by the talent on this forum.
Keep up the great work!
Check the VIN of the Lotus you're considering buying
http://www.lotustalk.com/forums/f3/h...hl30039-66280/
carlover is offline   Reply With Quote
Old 01-08-2008, 05:18 PM   #91 (permalink)
tommyc's Avatar
This is the reason this forum is so valuable! I remeber the early 90's with no internet support. When the shifter in my mitsu started moving in 5th gear the dealer said it was normal. It wasn't until a forum"dsm.org" had a bunch of good guys figure out that the nut on the countershaft in the tranny was coming lose and eating away at the housing. Easy fix! to this day I do not think Mitsu had any recalls. This is whay we have to diagnose and modify things to function smoothly and share the info. I thank you all and hope we can all find out what this issue is with or without Lotus. This weekend I will pull my VC and check it out. Tommy
05 elise graphite sport touring BWR s/c Charliex tune
90 eclipse gsx 420 whp sold
04 civic si
tommyc is offline   Reply With Quote
Old 01-08-2008, 07:54 PM   #92 (permalink)
Mikey likes it!
insane's Avatar
Originally Posted by Dragon View Post
Looks like you got it straitened out pretty good there... I wonder if opening up the restricter just a tiny bit to allow a little more flow would help any. My only worry would be if the slight change in oil pressure could affect the cam change over at all. It probably wouldn't though as I'm sure the oil pressure regulator / bypass valve is already open at those rpms. Also not to keen on the wear patterns on the cam's, probably not a big deal, but the ununiform wear patterns make me wonder to the quality of the cam grind/valve train geometry...
We actually observed that increasing the pressure exacerbated the problem.
Hey! Nice work with the bit, Sammy!!!
-Michael
'05 Nighfall Blue with Rallye Stripes!
insane is offline   Reply With Quote
Old 01-08-2008, 08:09 PM   #93 (permalink)
Mikey likes it!
insane's Avatar
Cool
Originally Posted by insane View Post
You can bet that when I fix mine, there's going to be a new camshaft cover.
Here's my damage at this link.
By the way, if anybody has any good leads, I'm going to need replacement parts CHEAP! (pm me....)
-Michael
Old 01-09-2008, 02:08 AM   #94 (permalink)
Hydrocarbons Rule
Dragon's Avatar
Images: 2
Roger that... Higer pressure could hit so hard that it all bounces off the parts in stead of coating them. What may need to be done is increase the volume but at the same or slightly lower pressure.
Dragon is offline   Reply With Quote
Old 01-09-2008, 12:30 PM   #95 (permalink)
ZAMMY
VALVE COVER O-RING PARTNO.
FWIW:
i picked up a couple of spare o-rings that the valve cover uses one of.
the toyota part number is 96741-19009, $2.59 each. i like to have a spare handy, didn't really need one.
SAM
Old 01-09-2008, 02:24 PM   #96 (permalink)
I don't recall if anyone did any measuring, but I did and thought I'd share.
This distance from the oil sprayer tube to the cam, measured at the base circle, came out to .559" . When you compress the gasket, it's closer yet. The cam sticks up higher than the gasket surface of the head, by .666 on mine. So I'm not automatically in agreement about the off angle of the oil holes in the spray bar being the cause of cam wear. The angle would have to be way, way off for the oil to miss the cam.
Also, there's a difference between the distance of center to center of the 2 cams and the corresponding measurement of the spray bars. In other words, the bars are not centered over the cams. They're about 3/16" off center. Still pretty minor though. By the way, the holes in my spray bar were misangled too, with #1 intake a bit worse. The lobes looked ask good as you could ever wish for.
MikeW is offline   Reply With Quote
Old 01-09-2008, 03:34 PM   #97 (permalink)
Boosted2.0's Avatar
Overrev / rev limit riding -> mushroomed valve -> insufficient valve clearance -> cam wear & rocker breakage
Old 01-09-2008, 04:25 PM   #98 (permalink)
Future 2ZZ-GZE member...
GTsRasta's Avatar
I so called that. LIFT can be a killer...
Originally Posted by scottyb View Post
Maybe you should put a disclaimer in your sig saying that you don't have a Lotus nor have tried any of the products you are constantly posting about.
03 Celica GT-S, 6 Speed Manual, Carbon Blue
Performance Mods: AEM Cold Air Intake, TWM Short Shifter
GTsRasta is offline   Reply With Quote
Old 01-09-2008, 05:04 PM   #99 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Boosted what do you mean "insufficient valve clearance?"
Old 01-09-2008, 07:41 PM   #100 (permalink)
Mikey likes it!
insane's Avatar
...the valve hits the seat so hard, it malforms and heads up the valve guide (slightly) -- essentially 'stretching' the valve stem.
Boosted is correct; that's a way-common way to kill a valve train. ....but not the only way.
-Michael
