Check Engine Light Code P0171
Good evening everyone,
I would like to know if anyone else has encountered the above code. It means that I am running too lean. The light came on acouple of days ago while driving in Boulder, CO [5500ft]. My milage is 1160 and this is the first time that I have had a check engine light problem. Around 850 miles I installed a ITG intake exhaust and an Arqray SS twin muffler. My routine dealer visit was at 1023 miles. At that time they reset my ECU as per TSB dated 3/06 for stall problems of which I have never had to that point. Now it looks like another trip to my dealer to see what they can do for my situation. Does anyone know why this has happened and how to solve the problem so It doesn't happen again? Will my dealed say it's because of the ITG intake, so it is not covered by the warranty? There was one instance after my 1K service that the car did stutter at idle, corrected by a slight touch of the gas to keep it from stalling. Thanks for your opinions. Best regards, mr t Nederland, CO [ 8500ft ] |
insert clever title here
Just curious, did the CEL come on during WOT driving? If the ECU is running in open loop mode off of predefined maps, and if you significantly increase the airflow, it seems possible that you could be running leaner than usual. I think the dealer will almost certainly blame your intake and exhaust modifications and not agree to do anything more than reset the CEL.
#3 (permalink) | ||
I believe the most likely cause is a vacuum leak somewhere downstream of the airflow measuring device. Other possible causes are problems in the EGR system or a leak in the evaporative recovery system. Quote:
From the Service Manual (everyone should go to the Lotus web site and download the manuals for $25.)
Lotus Service Notes Section EMP Page 20 Fuel Control System Too Lean Or Rich P0171 P0172 P0171 System Too Lean P0172 System Too Rich Description The oxygen sensor sends a signal to the ECU corresponding to the exhaust gas oxygen content enabling the ECU to maintain a 14.7:1 air/fuel ratio under normal driving conditions. The ECU can make fuel corrections of ± 17% to the calculated fuel demand. If the ECU determines a rich condition exists (oxygen sensor above 0.450mV), it will decrease the calculated fuel demand to maintain a 14.7:1 ratio. If the ECU determines a lean condition exists (oxygen sensor below 0.450mV), it will increase the calculated fuel demand to maintain a 14.7:1 ratio. Enable Criteria
P0106, P0107, P0108 – Baro sensor faults P0111, P0112, P0113 – Air Intake Sensor faults P0131, P0132, P0133, P0134, P0135 – Oxygen sensor faults P0300, P0301, P0302, P0303, P0304 – Misfire faults P0441, P0442, P0443, P0447, P0448, P0450, P0451, P0455, P0456 – EVAP faults Monitor: Continuous Malfunction Criteria P0171 This code is set when the calculated fuel demand has been increased to its maximum limit of 17% and the system still cannot maintain an air/fuel ratio of 14.7:1 under normal driving conditions. Potential failure modes:
This code is set when the calculated fuel demand has been decreased to its minimum limit of -17% and the system still cannot maintain an air/fuel ratio of 14.7:1 under normal driving conditions. Potential failure modes:
The MIL will be illuminated if the fault is present for 2 consecutive trips. Further information on the sensor may be found inToyota 1ZZ-FE, 2ZZ-GE manual RM733E (B120T0327J) pages DI-67 to DI-72. I'd be looking for any loose connections frim installing the air intake and/or leaks.
Tim Mullen --- There is no such thing as Touring suspension or Touring wheels.I love being married. It's so great to find that one person that you want to annoy for the rest of your life. - Rita Rudner Chantilly, VA http://members.cox.net/elans4/ 05 Lotus Elise - Chrome Orange - No Touring - No LSS - No Hardtop - Lotus Driving Lights - Lotus "Chin Guards" - plain and simple. 94 Miata R Package - Black 72 Lotus Elan Sprint - Colorado Orange/Cirrus White Last edited by TimMullen : 06-13-2005 at 01:38 PM. |
J. Caesar
isnt 14.7 running rather rich??
Vati. C6 ZO6. THE OBITS, YO! KEEP CRYIN! WHAA! REDNECK = PERSON WHO LIVES IN A DUMP BUT DRIVES AN ELISE! I never played by the rules, and I never really cared My nasty reputation takes me everywhere It is admitted by all that he was much addicted to women, as well as very expensive in his intrigues with them, and that he debauched many ladies of the highest quality; among whom were Posthumia, the wife of Servius Sulpicius; and Lollia, the wife of Aulus Gabinius. |
#6 (permalink) | ||
The celica community went through these same problems with the first generation intakes that were made. AEM ended up having to have each mounting flange for the maf's to be mounted via machine, rather than by hand, this helped reduce the variance from intake to intake and stopped nearly all the CEL's their intakes were causing. Simply put, if its off center(the maf or mounting flange), or the rotated a bit so that it doesn't get correct air flow across it, or the section of the pipe is too turbulent the maf wont read airflow correctly. Not everyone who purchases this intake or any other intakes will have the same problem, only when the flange is just a hare off its mark will cause the CEL. There is a fix however, I can't take credit for it, but you can remove the fins in the stock intake tract, designed to provide proper airflow across the maf and incorporate that into the intake. This will eliminate your cell. Worst case I'd contact ITG, and request a new Intake, since yours is causing the CEL, and it seems others are not.
Controlled Inertia 02 Celica GT-S R.I.P. 05 Obsidian Black Pearl WRX STI |
#7 (permalink) | |
13.0-13.5 is generally as far as most tuners go for n/a power under wot full load conditions. off throttle/ low load can get up to 15.0's and still be okay for fuel economy. It also depends on how much ignition your running too and what your knock levels are like.
#8 (permalink) |
Interesting info, Illusive! Nice to have the Celica community's experience with this motor to help us out here.
#10 (permalink) | |
best spot is about an inch before the maf.
#11 (permalink) |
untitled
Someone in a thread about making your own intake claimed that there are no fins in the Elise intake tube. http://www.elisetalk.com/forums/showthread.php?t=12470
Lean condition could be any number of things, but I suspect the intake, too, since it's aftermarket and probably smaller diameter than stock (to make it run leaner on purpose for more power). Like Illusive said, if something is off by just a little bit in the MAF mount, that could do it. The MAF could be too low in the tube or crooked. Another thing to check for is an air leak. First place to look is the intake, since it was probably self-installed. Exhaust leak is also on the list, but if you had one of those you'd proabably hear it.
It is all about "Other". Last edited by Beanie : 06-13-2005 at 06:40 PM. |
