I have been gone for a little over a month and now I am back and to my surprise the car started right up. However when I shifted into revers and the clutch engaged there was some griding. Then when I shifted into first there is more grinding when the clutch is being engaged. It drives fine and I can shift into any gear without problems but there is some vibration/grinding when I shift gears. It is more prominent when I am taking off in first gear.
I replaced my clutch with an ACT set up about 9K ago and I have no track days, just normal driving. Has anybody ran into this problem? Clutch replacement at the dealer?
05 Lotus Elise R/K Supercharger upgraded to VF2, Stage II exhaust, Moroso Oil Pan, RTD Brace, High Volume All Aluminum Radiator, Stainless Steel Break Lines, Oil Catch Can, ACT Clutch, HID, Carbon Fiber Spliter, Reverie Side Scoops, CF side skirts, FF gauge pod, BWR gauge pod, S111 front & rear tow hooks, upgraded tail lights-LED, Driving lights, LETSLA, ...
Moderator Extraordinaire!
Check the throw of your clutch slave cylinder push rod to make sure it is moving all the way out and if not, bleed the system to make sure no air has leaked into the slave or master cylinder while the car was sitting. From your description, it sounds like the pressure plate isn't completely disengaging when you step on the pedal causing some clutch drag and the grinding. If this fails to correct the problem, you may have a partially failed pressure plate spring or a bad pilot bearing which means the trans. needs to be pulled for another clutch replacement. I hope simply bleeding the clutch hydraulics cures the problem.
took the car to the "doctor"/dealer will keep you posted on what is going!
Has that happen on my Del Sol with ACT Clutch. The pedal is very stiff; the master/slave cylinders strarted leaking ( bought the car used )
Replaced them then the transmission has to be rebuilt as well ( 1-2 months later). This all might be unrelated; but I have the strongest street ACT Clutch ( not the racing four-prong one)
07 SY ExigeS |
2.0-6262
sometimes the slaves go bad after sitting and the pressure might have leaked out a bit like someone said, it might just need to be re-bled
Please PM if you need anything, i am working from home now. |
#8 (permalink) | |
Race lines on the mind
the dealer...
The dealer will just say its the super charger, pat you on the bottom and send you on your way ![]()
2003 Honda S2000 - Suzuka Blue 2005 Magnetic Blue Elise Forcefed 275 turbo - Sold 05/20/09 |
#9 (permalink) |
Unattractive Nuisance
Next time, maybe pump the clutch pedal a few times and see if trans goes into gear more easily (= air, bad adjustment, etc)
05 elise (PES chip, SSRs, shift tower mods, Multivex; HID low beams); 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "Political language is designed to make lies sound truthful and murder respectable." G. Orwell. "Incontinence Emergency Hotline- Can you please hold?" |
#10 (permalink) | |
1. air in the system 2. disk springs broken 3. pressure plate?? However this is an ACT system and it should have lasted more than 8K of normal driving! I will call them later on today and hopefully I will have something to pass on by tonight!
#11 (permalink) |
I think it is the clutch because I can shift ok into every gear. The problem is that when I start easing of the clutch in first gear to start going it emits a vibration/grind that is felt in every gear. But I can shift ok in all gears up and down!
#12 (permalink) |
Am a bit confused by description, but I guess dealer will soon diagnose. could be clutch, input shaft, etc. If this NVH is present only when car is in gear and not when clutch pedal is in any position but car is not in gear, I would bet on a non-clutch issue. Moot point until you hear from dlr.
Why did you change the clutch the 1st time? Good luck and keep us posted.
#14 (permalink) | |
#15 (permalink) |
IT -
Don't forget to tell us the denouement....er....outcome. Thanks.
#16 (permalink) |
Update
Got the car back........same issues but I am getting a new AC compressor!!!:
.......I just ordered a new clutch set and I will take it apart myself! I will keep you guys posted!
