LotusTalk.com is the premier Lotus Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 02-08-2006, 03:22 PM   #1 (permalink)
Fists of the Red Lotus
YAUDI's Avatar
Question Clutch Replacement?
If a clutch is not slipping and still gripping fine, can it still be worn out and need to be replaced? Will a worn clutch cause shifting problems for the gearbox? Just trying to figure out if my clutch can cause my slow tranny shifting problem. Dealer wants to tear her down since they can't diagnose the problem other wise... If the a worn clutch is the culprit, I get to fit the full bill . Help please, TIA...
Here is my other thread:
http://www.elisetalk.com/forums/showthread.php?t=19436
-Fists of the Red Lotus-
2002 S4 MaD wAgOn, 2003 Golf TDI "Fuel Tank on Wheels", 2005 Ardent Red Lotus Cartoon Car, Sport Pack , Hard Top, Quicksilver RIP, 2bular 6" Ultra Thru , DBA rotors , BADAR888S, ekological HIDs, Fidanza+South Bend
http://www.thedriversedge.net/, http://www.apexdrivingacademy.com/
YAUDI is offline   Reply With Quote
Old 02-08-2006, 09:44 PM   #2 (permalink)
I would guess your clutch is not disengaging propely. I do not believe that is a sign of a worn clutch... I assume your or the dealer tried to ajdust it?
Matthias
95 993 cab (sold)
00 Volvo V70
05 NIB Elise LSS
matt is offline   Reply With Quote
Old 02-09-2006, 04:15 AM   #3 (permalink)
YAUDI's Avatar
Yeah, that seems to make the more sense. It's hard to gauge, but after the slow shifting started occurring, I can sense the clutch pedal vibrates more when you first start pushing it. I wonder it it could be the throwout bearing?
I'd image you can adjust the clutch engagement without removing the tranny? I guess nobody else on ET has had something similar to this ?
Old 02-09-2006, 07:18 AM   #4 (permalink)
J. Caesar
evomind's Avatar
who the heck is so eager to remove ur tranny or clutch b4 investigating every and any other option?
removing anything should always be the last thing to consider. its not an easy job on this car to r and r a clutch or tranny.
they should be looking at things like linkage and engagements. once they rule EVERYTHING else out, then start removing stuff.
fwiw, it doesnt sound like a bad clutch, but is it possible? sure.
if its a tob, u will more than likely hear it squeaking too.
sounds like more of a linkage/engagement issue to me.
Vati.
C6 ZO6.
THE OBITS, YO!
KEEP CRYIN! WHAA!
REDNECK = PERSON WHO LIVES IN A DUMP BUT DRIVES AN ELISE!
I never played by the rules, and I never really cared
My nasty reputation takes me everywhere
It is admitted by all that he was much addicted to women, as well as very expensive in his intrigues with them, and that he debauched many ladies of the highest quality; among whom were Posthumia, the wife of Servius Sulpicius; and Lollia, the wife of Aulus Gabinius.
evomind is offline   Reply With Quote
Old 02-09-2006, 08:39 AM   #5 (permalink)
YAUDI's Avatar
After discussing with a tech and reaffirming with the service advisor, I think they have been pretty thorough. Bottomline is I want it fixed and I want to know what caused and maybe why something failed... My car has seen lots of track time, so I'm sure I'll get things that more mildly used ones will not... I'll keep you guys informed since this seems like some undiscovered territory...
Would suck to know if the clutch could take the usage, I can't say I've been that hard with it ... I'm very good about off throttle up shifts and heel-n-toe downshifts. Over 17k miles, still no standing starts logged by ECU... Well, that's how the cards fall sometimes ...
Old 02-09-2006, 08:51 AM   #6 (permalink)
Kold-Fire.com
Dave's Avatar
Clutch replacement averages about 10 hours...my ACT install labor was just over a grand. 10 hours is in-line with most other posts I've read.
Dave is offline   Reply With Quote
Old 02-09-2006, 08:57 AM   #7 (permalink)
J. Caesar
evomind's Avatar
my shop charged me 10 hours too...and said they used everybit of 10 hours and probably more....
thats really stupid to design a sportscar that takes 10 hours to r and r a clutch.
Vati.
C6 ZO6.
THE OBITS, YO!
KEEP CRYIN! WHAA!
Old 02-09-2006, 09:16 AM   #8 (permalink)
Kold-Fire.com
Dave's Avatar
Not to change subjects, but evo how many hours for your flywheel? Did you do it at the same time?
Old 02-09-2006, 09:23 AM   #9 (permalink)
TTP
TTP's Avatar
Images: 28
Frankie,
Have you searched the celica boards to see if there are simlair issues since we do share some of the same systems?
TTP is offline   Reply With Quote
Old 02-09-2006, 12:01 PM   #10 (permalink)
esprit89
esprit89's Avatar
That's funny - ever replace a clutch on a 4-cyl Esprit? It takes at least that long if not longer: remove 3/4 window shelf over ECU; remove trunk floor disconnecting vacuum lines and all the relays and solenoids from ECU; remove chassis rear cross member; remove muffler and mounts; disconnect shift cables; drain transmission; remove roll pins securing driveshafts; disconnect rear suspension links to pull drive shafts; remove starter; remove clutch slave cylinder; remove turbo air intake hose; pull transmission. There's probably a few steps I'm missing as it's been a few months since I've done it.
I imagine on the Elise the transmission R&R time is no different than that of a Celica since the drivetrain was a straight drop-in. Need to blame Toyota if it takes too long.
Cheers,
esprit89 is offline   Reply With Quote
Old 02-09-2006, 12:34 PM   #11 (permalink)
esprit89
esprit89's Avatar
What do you mean specifically by slow shifting? Is more effort on the shift lever required to engage a gear? Are all gears affected? If you have the engine off and try selecting different gears is there any difference in effort required compared with before you started experiencing the symptoms?
If the problem occurs with all gears it would seem to indicate the problem is with the clutch not disengaging properly and dragging. If it's just one or two gears then the gearbox might be suspect.
A dragging clutch can caused by a worn, binding or misadjusted clutch linkage (clutch fork), or air in the hydraulic clutch lines, or damaged pressure plate fingers, or binding of the clutch disc on the input shaft.
Release or throw-out bearing problems usually show up in the form of whirring or growling sounds when applying the clutch pedal, which go away when releasing the pedal.
Since it is hydraulic, the clutch is self-adjusting.
I'm curious to know what they find.
Old 02-09-2006, 01:40 PM   #12 (permalink)
TimMullen's Avatar
Images: 19
Why wouldn't that be covered by the warranty? As long as you haven't abused it, it should last longer than 17,000 miles...
94 Miata R Package - Black
Old 02-09-2006, 01:44 PM   #13 (permalink)
YAUDI's Avatar
On an upshift, you have to wait at the gate for about a second before the gear will be allowed to be engage at revs over ~5000 RPMs. Shifts like normal at lower revs. As far as I can tell, all gears are affected. With engine off, the gear shifting felt pretty much normal. The dealer has bleed the clutch system and the problem still persists.
Old 02-09-2006, 02:03 PM   #14 (permalink)
YAUDI's Avatar
That's what I'm hoping. I am pretty sure I didn't abuse her, but we'll find out shortly what the dealer and Lotus deem as abused when they got her opened up. The service advisor stated something like if it's the clutch that's the problem, I mightl be paying since I could have abused it. But if it is another mechanical part, it would most likely be covered. It's all kinda semantics right now till the fingers start pointing... I figured the no standing starts ever from the ECU log in almost 400 hrs of engine operation is a good indication that I'm not abusive to the clutch. Regardless, I've always been a bit of a pessimist...
Old 02-09-2006, 02:31 PM   #15 (permalink)
choi0706's Avatar
mine vibrates also....
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
Old 02-09-2006, 03:24 PM   #16 (permalink)
esprit89
esprit89's Avatar
This thread has awoken a long repressed memory of having to replace the clutch on a '92 Integra I used to have. Pulling away from a light and shifting to second the clutch pedal went to the floor with a spongy feel and I couldn't shift into gear.
I took it to the dealer as it was still under warranty. They stated that if the problem was due to abuse it would not be covered. It turns out the pressure plate failed - the return spring "fingers" had bent. The clutch disc and flywheel/pressure plate surfaces showed no wear so the clutch was replaced under warranty.
The Centerforce clutch people have a diagnostic guide with some good information. The link is on the upper right hand side of this page: http://www.centerforce.com/
Old 02-09-2006, 04:04 PM   #17 (permalink)
Do you pull the engine to replace the clutch in the Elise? If so 10 hours is cruisin' right along.
Trip
tripdog is offline   Reply With Quote
Old 02-15-2006, 08:59 AM   #18 (permalink)
YAUDI's Avatar
Exclamation
Well, it was clutch related and you don't have to pull engine to get tranny and clutch out. See this thread for details:
CLICK ME!!!
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
