Old 06-30-2009, 05:58 AM   #1 (permalink)
2006 elise, 2007 BMW 335i
Code and weird Dyno P0016 HELPPPPP
Title says it all. I have a code in pending P0016 (Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)) and it has turned into a real code a few times. My dyno is also looking very wierd since the code has been thrown. Now i did read what the code stood for in our engines. I am trying to figure out if I have a bad sensor and if so what sensor. Any help would be great.
cpeteod is offline   Reply With Quote
Old 06-30-2009, 06:19 AM   #2 (permalink)
User, Registered
fpitas's Avatar
You may want to shrink that picture
Francis
Old 06-30-2009, 07:15 AM   #3 (permalink)
Yeah the last picture was huge, didn't notice that. Thanks
Old 06-30-2009, 07:35 AM   #4 (permalink)
Cthulhu's Avatar
I'm not sure if this helps, but if you turn the dyno graph sideways, it looks like boobs.
2009 135i - Montego blue/Coral red.
2007 Lotus Exige S (deceased) - Storm Titanium.
RIP SCCVC11127HL80723
May the roar of your supercharger forever shatter the serenity of the heavens <3
Cthulhu is offline   Reply With Quote
Old 06-30-2009, 07:35 AM   #5 (permalink)
GR8 SCAPE
waydui's Avatar
I can't find a listing or definition for a P0016 Code in my manual or on OBD-Codes.com.
I do have a pic of all the engine sensor locations, which may help. The Crankshaft sensor (#8 in the diagram) is located at the bottom of the engine, get at it from underneath.
Good Luck!
Regards,
Wayne
_______________________
Old 06-30-2009, 07:44 AM   #6 (permalink)
Cthulhu's Avatar
http://www.justanswer.com/uploads/sk..._05_rolla1.pdf
The above Toyota .pdf may help. It's for the Corolla and Matrix, but they use variants of the 1ZZ and 2ZZ engine.
Old 06-30-2009, 07:50 AM   #7 (permalink)
tesprit's Avatar
Maybe he should rotate the graph and make it huge again?
Old 06-30-2009, 08:00 AM   #8 (permalink)
Good Luck!
Regards,
Wayne
Wayne,
Thanks for the chart. I am leaning towards replacing the sensor, since it believe it is easy to get to. Do you know the toyota part#.
Old 06-30-2009, 08:16 AM   #9 (permalink)
GR8 SCAPE
waydui's Avatar
I believe the part number is W0133-1786732. It's for a 2ZZ engine, Matrix, 1.8L. Costs $100 at a bunch of on-line stores.
Regards,
Wayne
Old 06-30-2009, 12:36 PM   #10 (permalink)
OSX Black hat
charliex's Avatar
hard to tell conclusively without the whole dyno to get an idea of the scale of the dip, but its saying your cam offset is incorrect, which would tie up with a decent loss of power. the sensor reads the position, it doesn't set it.
Old 06-30-2009, 01:17 PM   #11 (permalink)
Thanks Charlie, I dont' have the whole pic right now. It is a 30hp drop when hitting the second cam. Car runs great except for that lol and the code. I may try to change crank sensor because P0016 comes up in pending right when the car turns over. I read this paper that has me leaning this way. http://www.ncttora.com/fsm/04-06-Tun...e/cip0016p.pdf But my RPM gauge is working correctly, so I would think it isn't the Crank sensor. Oh the car runs very smooth so i don't think it is not aligned.
