Old 03-03-2009, 08:26 AM   #1 (permalink)
klone's Avatar
Compression Check
My warranty is just about up, so I took the Lotus in to get checked out. I have not had any serious issues, but just wanted to make sure everything was in order. My question is regarding compression. Where should my numbers be? I do not have them in front of me, but cylinders 1, 3, and 4 ranged from 191 to 195, while cylinder 2 was at 180. Is this a concern? I am not familiar with compression numbers. The search that I did brought up some compression numbers, but no real information. They were either higher or much lower.
Thanks in advance
klone is offline   Reply With Quote
Old 03-03-2009, 09:30 AM   #2 (permalink)
JLSELISE's Avatar
The actual number is not too important since it can vary with cranking speed, gauge accuracy and other factors. Cylinder-to-cylinder variations are potentially important, though, and probably should be less than +/- 5% -- about 10 psi for a 200 psi base line. So the 180 reading might be suspect. The problem, if it exists, could be rings or valves, and that can only be determined by a leak down test, which requires some specialized equipment and a good mechanic.
Joel
'67 S3 Elan dhc (owned since 1970)
'06 Audi A3 3.2
'04 Noble M12 (380 rwhp)
JLSELISE is offline   Reply With Quote
Old 03-03-2009, 09:44 AM   #3 (permalink)
klone's Avatar
The printout said there was a 6.x% difference. The dealership was not too concerned, but I wanted other opinions from the forums as well. Thanks for the input. I can look into a leakdown test.
Old 03-03-2009, 10:00 AM   #4 (permalink)
glb
Unattractive Nuisance
glb's Avatar
cheap, temporary test w/compression:
If low reading in a cyl, squirt oil into it and try again. If compression jumps up, likely it's rings.
Leakdown is the way to go.
Old 03-03-2009, 10:01 AM   #5 (permalink)
tesprit's Avatar
The compression reading you have for cylinder 2 may or may not be a problem. Have your mechanic do a full leak down test on your cylinders and if #2 comes in low compared to the others, then it is time to worry.
Old 03-03-2009, 01:21 PM   #6 (permalink)
JLSELISE's Avatar
Kind of semantics here, but it is a high leakdown (expressed as a percentage) relative to other cylinders that points to a problem.
Check this out for more info:
Leak-down tester - Wikipedia, the free encyclopedia
Joel
'06 Audi A3 3.2
Old 03-03-2009, 01:40 PM   #7 (permalink)
tesprit's Avatar
Yes, finding a high amount of air leaking past the rings and/or valves (high leak down) with a constantly maintained air pressure is the problem. Using a leak down tester, this shows up as a too low air pressure reading (too much air leaking past the rings/valves gives a lower than optimal pressure) compared to the constant air pressure being applied to the cylinder via a compressed air source.
Old 03-03-2009, 01:54 PM   #8 (permalink)
klone's Avatar
I have seen others have low pressure readings on cylinder #2, is this a known issue?
Old 03-03-2009, 02:38 PM   #9 (permalink)
NOT ßANNED!
Demonized's Avatar
Sticking valve due to "known" camshaft problem, perhaps?
Old 03-03-2009, 02:47 PM   #10 (permalink)
OSX Black hat
charliex's Avatar
cylinder 2 gets the most abuse, so its the one to show problems first.
Old 03-03-2009, 05:38 PM   #11 (permalink)
Mountain Road Nut
ChrisH's Avatar
How does one cylinder get more abuse than another? Uneven air flow form the intake manifold?
Old 03-03-2009, 05:48 PM   #12 (permalink)
Driving it every day!
davecarama's Avatar
I looked up leakdown testers and it appears they can be had for $40.
Is it that difficult to do a leakdown test? I was planning on etting the tool and doing one myself this weekend on my Meeyotter.
Vision without execution is a hallucination.
davecarama is offline   Reply With Quote
Old 03-03-2009, 07:21 PM   #13 (permalink)
registered nipple
fishguy's Avatar
Images: 1
dave,
i have been looking into getting one also.
$40 is pretty cheap. the ones i have been looking at are all ~$100, and usually you get what you pay for, and with tools skimping is frequently not a bargain.
the one i see from longacre looks pretty good to me.
2008-2009 SCCA AZ Regional "Driver of the Year"
1986 Swift DB-1 Sold
2008 HSR-West FF 3rd generation Champion
2008 "The Series" FF 3rd generation Champion
1987 Porsche Spec 944
2008-2009 season SCCA AZ regional Champion
Old 03-03-2009, 07:56 PM   #14 (permalink)
JLSELISE's Avatar
Looking through the Wikipedia link I posted above should give you a pretty good idea what's required. In addition to the tester, you'll need a source of regulated air pressure of course. To do the testing, it's best to rotate the motor by hand with the valve cover off so that you can see when you are exactly at TDC (Top Dead Center) or BDC (Bottom Dead Center) on each cylinder you want to pressurize to determine leak down precentage. If the leak down is excessive, check for hissing air in the crankcase for an indication of a ring problem, or at the exhaust/intake for an exhaust/intake valve problem, or check for bubbles in the coolant for a head gasket problem.
Joel
'06 Audi A3 3.2
