#21 (permalink) | |
#22 (permalink) |
Hydrocarbons Rule
You might see some gains on a N/A engine, but on a forced induction engine they will be minimal. You'd be better off spending the porting $ on a smaller pulley and a new tune or removing more weight via expensive parts.
#23 (permalink) | |
Future 2ZZ-GZE member...
More VE is always a good thing.
NewCelica.org Forum - View Single Post - Update on me and head porting R&D
#24 (permalink) | |
Plug Whisperer
+1
The stock ECU remains in place to drive the stock dash. Short of that, the EFI is a complete standalone. Quote:
In otherwords, the hardware is sorted 100% for an upgrade. The tuning is still up to the end user at this point, which is why I haven't released a complete "kit"... PM/ring me for further discussion if you're interested... Sorry for thread jack... Good stuff boosted ![]() Later, Phil
#26 (permalink) | |
Plug Whisperer
I'll supply base tunes, tuning support, installation support, anything I can to help out with the EFI, but ultimately the EFI is purchased from DRS, who's on this forum... That said, I've helped a lot of folks with EFIs and still field EFI questions weekly, if not daily, regardless of whether they run something I made on their car... I'm a car guy first and businessman second When we get the PFC tune done, same thing will apply. I won't be selling the PFC, but I'll do everything I can to help with it. There are some really knowledgable PFC guys in the Celica world, and I believe Boosted is one of them... So there will be a couple standalone ECU options and I'm certain atleast one, if not two or three options to go to for a flash of the stock ECU...Hope that helps, Phil
#27 (permalink) |
ZAMMY
to get back to the original thread, with simply better breathing, why doesn't the MAF/O2 feedback system take care of the relatively minor change in breathing?
i would expect the long term fuel trim to change a bit. is there not enough trim to properly alter the F/A ratio? isn't this what happens when the breathing is improved when a less restrictive air filter element is used? or, is the system so 'knife-edge' set that it won't tolerate any change? i'm not talking about a ducting change, just a few percent in flow. i've been wrestling with this for a time. thoughts? sam |
#28 (permalink) | |
Dynamic Racing Solutions
![]() Join Date: Oct 2006
DRS 2ZZ Head Data Kris
Motorsport Components and Expert Service. Complete Lotus maintenance, installations, track preparation and specialty services. |
#30 (permalink) |
Plug Whisperer
Kris- Very Cool!
#31 (permalink) | |
Parts scattered about...
Third hand info - Monkeywrench said they did some before/after dynos and the differences were very small.
My car is modified.
#32 (permalink) | |
Kris
#33 (permalink) | |
We have a couple nicely built engines with P&P heads that we will be putting on the dyno shortly. UNfortunately both will have our new intake manifold on them. |
#34 (permalink) |
FWIW - Info on engine we built with ported head and other mods can be found here Its Alive! Big SC Power in the BWR FrankenLotus
thanks Kris
#35 (permalink) |
![]() ![]() ![]() it works. but the question is how much, where n when.
| CelicaSG.org - CSG | |
#36 (permalink) | |
2009 XP National Champion
![]() Join Date: Oct 2003
There are other mods to my car as Kris said, but our last adventure on the same mustang running more boost(17.5psi) net about 305rwhp and maybe 200lb-ft. Now the crank is lighter, the clutch is lighter and it has race cams, but my hand-figuring/guestimation says the head was worth 35-50HP.
