Easy Cheap Intake Mod Simple Enough for Idiots
The following is a very simple and easy Mod to increase air flow through the stock airbox. It is basically a tutorial for a Mod that Stan did quite some time ago. According to Stan, Randy, and others the best intake has been this modification to the air box. There are pros and cons to this mod as well:
Cons: Louder Exhaust Note Pros: Louder Exhaust Note Slightly better Hp results according to both Stan & Randy's Analysis No CELs This mod can be performed in 20 minutes. Tools required: Torque Wrench Philips Screw Driver Flat Screw Driver Jack Wheel Wedge Last edited by scottyb : 10-21-2006 at 09:14 PM. |
Next remove the drivers side rear wheel. I realize there are quite a few members who may be hesitant to do this, trust me it's easy to do.
Then remove the Wheel Liner. All you need to do this is a Philips screwdriver. You loosen the plastic retaining screws in the liner. I think there are 5. The liner then comes out nice and easy. You now have a nice easy access area to work from. Last edited by scottyb : 10-21-2006 at 09:15 PM. |
The last picture shows the cardboard/felt lined intake snorkel. This is held on by a single black plastic clip on the top of the air box. Place a regular screwdriver in between the retaining clips metal and the top of the air box and you can pop this clip out in no time. Then you simply slide off the snorkel from inside the wheel well.
You will notice that there is a restriction on the amount of overlap in one corner of the stock air box which makes fitting the coupler a little tricky. I simply cut a section of the rubber coupler so it would fit better and could be secured properly.
#7 (permalink) |
I then slid the Velocity Funnel on the other end. It just fit without having to alter the funnel. I did flex the coupler a little though. I then tightened the clamp for the funnel. After that I checked the whole setup by wiggling it the air box to make sure everything was secure. After that I replaced the wheel Liner and then the Wheel. I do recommend that anyone who removes their wheel, have a good torque wrench available for putting the wheel back on to spec.
#8 (permalink) | |
Great writeup - well done! |
#10 (permalink) |
Certified Fun Stopper
Very nice writeup; Thanks! I removed my snorkel a month or so ago, but now I'm thinking of adding the funnel as well.
Ian
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC '05 Elise; Arctic Silver/Ruby Red (R.I.P) |
#11 (permalink) |
eliseaholic!
Exc. writeup scotty! Question for everyone, what's the purpose of the rubber snorkel anyway, my duc 996 had them took em out early on.
Chris Club111 #3 06 Solar yellow/Touring/Traction Ctrl/Blk Whl Pkg/Strshld
#12 (permalink) | |
#16 (permalink) |
My other car's a mtn bike
Doesn't the snorkel also assists in cold air intake?
I'm wondering if removing the snorkel hurts the fuel/air density since the intake air temp would presumably increase. Do you think the air tem in the body cavity is higher than the end of the snorkel air temp?
I wouldn't mind a more interesting motor sound, but I certainly don't want to hurt the HP output. Randy - can you back this claim up? ![]()
Sometimes you have to go in circles to move forward. 05 Elise NA 1750 lbs w/ full cage, fuel cell, aero, 173 whp - Colin would be proud. 2008 LR3 HSE 2005 Mini S Convertible If I'd thought that one day ALL my cars would be British, I'd have laughed at myself! |
#17 (permalink) |
I can. I did not use that funnel thingie, but we dynoed the intake without the snorkel. Keep in mind that the intake is a Toyota designed part, not one designed by Lotus.
#18 (permalink) | |
#19 (permalink) |
We concluded that removing the snorkel helped hp. If a very small amount. In a dyno setting.
#20 (permalink) | |
'05 Storm Titanium / Red Touring / Hardtop / Stage 1 / Exige Wheels / Ohlins / RTD Brace / Traqmate |
