Old 08-27-2009, 09:11 AM   #1 (permalink)
Ex and future Lotus owner
Cardinal's Avatar
Images: 8
Engine hesitates/stumbles at speed
I got an email today from the guy that bought my car. He said he was driving on the highway, and the car stumbles and lost power for 3 or 4 seconds. Its been OK since then. I'd only had that happen when the engine was cold, but I have a feeling the engine was warm. I've been thinking about it, and I'm not sure exactly what it may be. I was thinking dirty MAF maybe? Anybody have any ideas? I'd do a search but I'm on a blackberry and the search doesn't work right on this thing. Thanks.
the1sen: why move forward with design when you can recreate a monstrosity from the past?
Cardinal is offline   Reply With Quote
Old 08-27-2009, 09:59 AM   #2 (permalink)
User, Registered
fpitas's Avatar
Maybe the AC relay problem?
Sudden power loss around 4Krpm
Francis
fpitas is online now   Reply With Quote
Old 08-27-2009, 10:11 AM   #3 (permalink)
Finally
NJdrool's Avatar
Second that.
Bob in NJ
06 Sport Elise # 23 Stage II/Micromirror/Green wire mod/S111 tow hook/BWR front plate holder/Green filter/desnorkled/HID's-Hi & Low/Stealth Bulbs.
NJdrool is offline   Reply With Quote
Old 08-27-2009, 12:55 PM   #4 (permalink)
Cardinal's Avatar
Images: 8
I don't know what the AC relay problem is. I can't search because of this POS blackberry curve. I can't even read the responses without replaying first, and seeing what's written below. I will check that problem out once I have access to a computer or some mobile device that isn't total trash. I should check to see if he was using the AC. Thank you for your responses.
Old 08-27-2009, 01:38 PM   #5 (permalink)
Mountain Road Nut
ChrisH's Avatar
A dirty air filter will cause the engine to stumble as you describe. At first it will be very intermittant, then later become more common. Eventually it will cause rev limiting, and then a CEL.
Old 08-27-2009, 01:42 PM   #6 (permalink)
User, Registered
fpitas's Avatar
SERVICE Date: 03.08.06 2006/20
BULLETIN Model: '06 Elise/Exige a.c.
Service Manager Service Reception Supervisor Parts Manager
Lotus Cars Limited, Norwich, Norfolk, NR14 8EZ. England.
CLASS 3
TITLE: Momentary engine power interruption.
REASON: It has been found that on a very small number of '06 model year cars, with an unfavourable tolerance
a.c. control module, it is possible under some circumstances that sparking across the a.c.
compressor relay contacts can cause a voltage spike which results in the engine ECU resetting.
This will be experienced as a momentary interruption of engine power, and is likely to occur only
very occasionally. It is also possible that a throttle related trouble code may be set. e.g. P0638.
Action: If this symptom should be reported, it is recommended to replace the a.c./fan control module
A117M0038F
Francis
