Engine Stall Power Loss Solved!
Hi,,
I thought I needed to write this with the easiest search criteria for whomever should have the same issue I did. I have a KoldFire tune and recently my Exige started stalling and losing power until the problem really became a major issue that totally freezed the car. Moreover, the AFR started increasing and became up to 14-15 on WOT at high rpm, with the car totally losing power. Having scanned the engine, the MAF value was 2.85 on idle whereas all other values of Injector trims were normal. THe O2 sensor readings were oscillating up and down which was normal as well. I replaced the MAF and the car didnt react on the first drive. However, on the second drive, it started to pick up. After running a whole day, it became much more responsive in terms of power and the stalls reduced drastically. On the third day today, the car has self-learned and is surging more power than I have ever felt before! The stalling: still about 10% of the time but I can live with it. THe MAF value on idle is now 3.2, a slight increase from the defective old MAF which proved to have made quite a difference! Cheers, Wael |
| Sponsored Links | |||
Advertisement | |||
Noways iz sittin outsides
glad you found it. I have a similar issue, but not suspecting the MAF.
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 Lotus Exige S310 WTC 2 |
you're reading these MAF values at idle? what is it @ WOT?
I'll have to hook up my reader and check it out.
ok, mine is reading .5 lbs/min @ idle
.8 lbs/min on decel what is conversion from g/s. aarrrghgh [.5*(453.6/60)] SO mine is reading 3.78 g/s? sounds like my MAF is fine then.
#7 (permalink) |
Unattractive Nuisance
Which/what readers are you ppl using?
05 elise (PES chip, SSRs, shift tower mods, Multivex; HID low beams); 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "Political language is designed to make lies sound truthful and murder respectable." G. Orwell. "Incontinence Emergency Hotline- Can you please hold?" |
#9 (permalink) |
DENNAB
I replaced my MAF with a new unit. So far it hasn't stalled
It has only stumbled once or twice below 500 rpm's but the car managed to save itself. The car is so much more enjoyable now not having it save it from stalling at every other light. With the old MAF sensor it was stalling at least once every drive. Thanks for the tip Waz! P.S The car has cold started a little rough the first few times. I'm wondering if the ECU is relearning. |
#10 (permalink) |
glad you solved the problem Roger. Car feel more powerful, too?
#13 (permalink) |
Hi,,
As a follow up to my post here, I was shocked to have the idle-stall again! The power was not lost this time and the MAF is all brand new!! I decided to give the car to the garage for a full strip of vacuum lines and intake/exhaust installs. To our surprise, the header had a large crack (2Bular is NOT to blame here: the install by the previous garage was bad, very bad!!! No need to elaborate...). The mechanic reviewed vacuum lines and restored and retight all the surrounding parts. All fixed and done, SURPRISE!!: the car is as smooth as out of the factory! The rpm drops to 1.3k then slowly to 1k and settles under. The idle-stall which was unbearable is once again solved. As much as we thought it was the KoldFire tune, then again Lukas proved he was again so right by continuously asking me to review the leaks! For months he asked me to do that and I neglected the possibility of such a mechanical fault. I hope many of the members here read this as to really go deep-in mechanically when they experience the idle-stall syndrome! Thanks, Wael |
#14 (permalink) |
Haxord but mine
Glad you regained your trust in the car. Seems weird you could screw up a header install, its pretty straight forward on this car
-David 2006 Storm Ti Exige + VF TVS BOE Nikasil 10.5:1 + Vision Function TVS Vision Function MP62 Based Supercharger Install Thread Turn Signals Blink Fast? Stereo Harness Info |
#15 (permalink) |
I had the same problem. Turned out to be my crankcase vent lines were connected backwards. Same exact symptoms.
"CHARLIE DON'T SURF" When it comes down to making out, whenever possible, put on side one of Led Zeppelin IV. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
