Old 07-15-2006, 11:03 PM   #1 (permalink)
The Elisetalk Adolescent
EliseKid's Avatar
Engine Temperature Question
Hey,
Today we took the Elise up to the mountains in about 98 degree weather. Because of the extreme heat I made sure to keep an eye on the temperature gauge. While on the freeway, with A/C full blast, the temperature was a steady 193 degrees F. (Keep in mind this is at 80mph.) When we reached the slower mountain twisties however, the temperature gauge shot straight up to a high point of 225 degrees F.(the average speed here was around 40-50mph) Becoming worried, I didn't know what to do and then realized that the A/C was still blasting. I turned it off quickly and the gauge immediently dropped to 198 degrees F in about 2 minutes.
So here's my question:
Was the engine really that hot? How could it possibly have lost heat that fast with just the push of a button?
'05 Graphite Grey Elise w/ dark blue interior, starshield, touring.
EliseKid is offline   Reply With Quote
Old 07-15-2006, 11:19 PM   #2 (permalink)
OSX Black hat
charliex's Avatar
it does go up and down pretty quickly, 225F is getting up there thats for sure.
Old 07-15-2006, 11:19 PM   #3 (permalink)
kaz
JabStrongFierce
kaz's Avatar
It's normal don't worry...eventually your radiator fans will kick on too.
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning
kaz is offline   Reply With Quote
Old 07-15-2006, 11:22 PM   #4 (permalink)
... _ . ..._ .
nvrblu's Avatar
According to the service notes, the fans switch on at 98C at 1/2 speed on temperature rise, full speed at 103C. They'll switch back to 1/2 when the temperature falls to 98C and off at 94C. Above 85 mph, the fans switch off because inducted air flow speed exceeds the fan stall speed. The fans run at full speed whenever the A/C is on.
I've never seen temps above 200F while moving. 225 seems high but is still below the boiling point of proper coolant mixture and system pressure. So the engine probably wasn't too hot... but getting close to the limit.
The A/C condensor is between the fans and the radiator. When the A/C is running, you're pumping heat out of the incoming (warm) fresh air and into the condensor so the ari flowing over the radiator is much hotter than the 98 degree ambient air. When you shut off the A/C, the condensor cools and the air flowing over the radiator is subsequently cooler. You probably could have switched the A/C to recirculate cabin air and lowered the temperature by not pumping so much heat into the condensor.
nvrblu is offline   Reply With Quote
