Forcedfed Stage 1Turbo Kit Pricing
Hello Guys,
We have finalized production pricing on our kit and we are looking at March 7th to start accepting installs at our centers around the country. The pricing works out as follows: 275 horsepower Stage 1 Turbo Kit with the following parts: Garrett GT28R Turbo Stainless Steel Turbo Support System 321 Stainless Tubular Manifold Heatshielding for turbo and manifold Spearco 450 HP Intercooler Core 750CM Puller Fan Aluminum Dedicated Intercooler Ducting Powder coated Aluminum Intercooler Pipes with isolator Mounts and Chassis Brackets Samco Intercooler Hose 304 Stainless 3 Inch exhaust system with flanged removeable cat and muffler with optional tip and test pipe, using the factory donut with swivel and motorcycle springs for flex 550cc Injectors Propetitary Unichip Plug and Play Computer Dedicated Air Intake System Modified Toyota Oil Pan (core exchange) Pressure Adaptor Fitting and Line NGK Spark Plugs Bosch Porsche BOV with Plumbing for Recirculation Brackets, Braces, Lines and Fittings Engineered Engine Restraint System Turbo Elise Key Chain Turbo Elise Badging Turbo Elise Supplemental Owners Manual Price : $7200 Total weight gain over stock 20 pounds 240whp and 175 pound feet of torque at the wheels Introductory Installed price for the first 2 kits at Forcedfed $8700 275 horsepower Stage 1 kit with optional redesigned baffled alumium oil pan (recommended for track sessions and hard use for both N/A and Turbo versions) Price: $7495 Optional extras: Forcedfed Aluminum Baffled Oil Pan $475 ACT Heavy Duty Clutch $349 ACT Extreme Clutch $399 (Needed for 400 horsepower Stage 2 kit) Quaife LSD $1300 (Needed for 400 horsepower Stage 2 kit) Aluminum Lightweight Flywheel $375 (saves 12 pounds over stock) 2 Gauge Aluminum Holder $TBA Aluminum Cup Holder $TBA (sacraligious we know, it will be light! )Odyssey PC 680 Dry Cell Battery $105 (saves 10.5 pounds over stock) Aluminum Battery Tie Down $35 400 Horsepower Stage 2 Kit with the following parts: Forcedfed Built Long Block with British Racing Green Crinkle Valve Cover Forcedfed Engineered Fuelling System Garrett GT28/71 Turbo Internally Gated Stainless Steel Turbo Support System Larger Runner 321 Stainless Tubular Manifold Heatshielding for turbo and manifold Spearco 450 HP Intercooler Core 750CM Puller Fan Aluminum Dedicated Intercooler Ducting Powder coated Aluminum Intercooler Pipes with isolator Mounts and Chassis Brackets Samco Intercooler Hose 304 Stainless 3 Inch exhaust system with flanged removeable cat and muffler with optional tip and test pipe, using the factory donut with swivel and motorcycle springs for flex 550cc Injectors Engine Managment System TBD Dedicated Air Intake System Forcedfed Aluminum Baffled Oil Pan Pressure Adaptor Fitting and Line NGK Spark Plugs Bosch Porsche BOV with Plumbing for Recirculation Brackets, Braces, Lines and Fittings Engineered Engine Restraint System Turbo Elise Key Chain Turbo Elise Badging Turbo Elise Supplemental Owners Manual Price: $TBA I will have Alcon brake and Stage 2 Kit prices in approx 2 weeks as well for you guys. I am sure there will be a few people unhappy with our prices but I think the majority of our customers will see that we are selling a quality kit and not a cheap piece. Have a great weekend. |
This sounds real nice...what do we do if we're from the east coast?
Also, this does not use the stock exhaust? How does it sound? Does it void the factory warranty? Thanks, Bruce |
Looks good, does the setup require any tuning after install?
Is the puller fan to run air through the intercooler? If so, does it run all the time or only when there is hot air coming out of the intercooler maybe? I think you need to get with Lotus and help them offer a turbo version of the car for the US Although EPA testing maybe be a large hurdle. |
insert clever title here
Will you be pursuing CARB approval for this kit?
#5 (permalink) | |
If CARB approved, I will purchase the kit after breakin. If not, well, we'll see.... I like what he has done and the price is reasonable, imo, CARB or no CARB.
I wonder if Stage 2 needs a core swap. I'd definitiely get big brakes if upping to 400 hp. 400HP in the Elise, I can hardly imagine. I think anyone serious enough to run 400 HP should do the wide body to be able to get more rubber on the track for adequate braking at much higher than stock speeds prior to any given track turn, with larger diameter discs under larger diameter wheels, etc. It's another animal altogether, imo!
Elise #2393 Bordeaux/Biscuit/LSS/HT/WindowTinting/Shield. Purchased new 06/01/05. Canton Mecca Spin-on Oil Filter, Redline Lubricants. Last edited by Prolene : 02-04-2005 at 05:39 PM. |
#7 (permalink) | |
KTR Performance LLC. 99 Fitchburg Rd. Ayer, Massachusetts 01432 Tel: 978-772-9911 Fax: 978-772-9499 E-mail: info@ktrperformance.com As for warranty that is up to your local dealer at this time. |
#9 (permalink) | |
#10 (permalink) | |
vv My Awesome Wife vv
Where are your locations for installation? |
#11 (permalink) |
I'm wondering how we will get 400HP to the ground with those little tires of ours. I had a hard enougth time putting all that power to the ground in my old Eclipse GSX AWD and not have it puff up into smoke on slicks.
#12 (permalink) | |
Jugga Jigga Wugga
ed
Magnetic Blue/LSS Delivered: 1/13/05 |
#13 (permalink) | |
That's why for the Car and Driver Super Tuner shootout in June we are developing an Alcon brake kit for the dreaded 150mph-0 stop that is part of their test. |
#14 (permalink) | |
So far so good with 230-250whp. We will have a Quaife LSD and bigger rear tires for the 400 horsepower kit as options. |
#15 (permalink) | |
We are setting up a dealer in Houston and Tampa hopefully as early as the end of this month. Otherwise you can ship me the car in California or send it to Franz at KTR Performance. |
#17 (permalink) | |
hmm...so it wouldnt make a difference on the track straightaways mashing on the brakes repeatedly from 150mph rather than 120mph???...more power leads to more speed on the straights and more aggressive braking and more brake fade no???
ardent/blk...lss...touring...HT..starshield...perhaps QS. |
#19 (permalink) |
Prez: The K.G.B.
A key chain!!! A key chain!!! Sign me up!
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - stripes - harnesses - Pagid pads - Green air filter 2002 Jaguar XKR convertible 2000 BMW 528i President - Lotus Limited Southeast http://autos.groups.yahoo.com/group/LLSE/ |
