Gear (usually 3rd) crunch
I find that when shifting into 3rd, and occasionally other gears, it does not shift in buttery smooth. Without knowing the technical difference between crunch and grind, it feels like a crunch. Basically there is resistance that I have to push past. It doesn't make any noise other than a slight metallic noise when pushing past the resistance.
I find this most often occurs when shifting at higher RPMs. When shifting at 2-3k RPM, it occurs much left often. Since I bought the car used I'm not sure what tranny fluid it has but I'm thinking about trying Redline MT-90. Other than that, how concerned should I be about my tranny? Thanks. |
#2 (permalink) | |
User, Registered
G-200 Driver
MT-90.
#4 (permalink) | |
2006 Elise, Chrome Orange, Sport Pack, Touring Pack, Stage 2 2004 Cooper S, Black, -15% s/c pulley, 22mm sway bar |
Cross gate cable is out of adjustment or is stretched and getting ready to break would be my guess.
2006 Diasio D962R Arancio Borealis SOLD: 05 Elise, Benetec Carbon Fiber full body & rear wing, FF 275 turbo kit , Ikeya sequential shifter, Ohlins coilovers, Porterfield R-4, Sector 111 RTD brace & HNT pad, Yokohama A048, Caterham seats, Simpson 5 point belts, Moroso oil pan, Sector 111 Boomerang, AutoMeter CF Oil Pres-Boost-Vac gauges. No AC, heat, airbags. 1619 pounds "wet" |
