Old 02-09-2006, 06:17 PM   #1 (permalink)
Avi
Avi's Avatar
Gridding Noise-3rd to second Gear- High RPM's
Took the elise for a spin through the canyons yesterday, and started noticing a sound that is simlar to changing gears without the cluch fully engaged. Its happening when downshifting at higher rpm's from 3rd to 2nd gear. I have an appointment in the morning with South BAy but wanted to see if anyone else has had this problem. I am thinking it's a transmission issue, but what would cause it. It goes into gear, but as soon as i shift at higher rpm's screech, just like grinding the gears? I dont think the dealer works on transmissions, would Lotus just put a new one in? Anyone ever hear of this happening?
Avi is online now   Reply With Quote
Old 02-09-2006, 06:41 PM   #2 (permalink)
Seabiscuit's Avatar
Sounds like a bad syncro to me. I would get it into the dealer. They most likely would replace the syncro if that is the cause. May want to check the tranny fluid as well. How many miles on the car????
______________
Greg
Seabiscuit is offline   Reply With Quote
Old 02-09-2006, 07:14 PM   #3 (permalink)
Avi
Avi's Avatar
I have about 4600 miles on her... could it be the gear box?
Could I have caused any damage due to the grinding?
Old 02-09-2006, 07:53 PM   #4 (permalink)
The box is probably just fine. If the linkage is okay (can you get the slots normally with the car stopped?) then I suspect a clutch issue. Perhaps the clutch is not disengaging fully. This tends to affect the up and downshifts and each gear differently. Can you get reverse and 1st easily when stopped? I'd make sure the clutch master and slave are up to snuff first of all.
Old 02-09-2006, 08:43 PM   #5 (permalink)
mlk_f1's Avatar
Images: 11
Yep, I get that only when the car is hot. The grinding noise only happens when I downshift to Third or Second gear. It doesn't happen all the time but enough to bother me. And no, It doesn't only happen when I'm speed shifting. It happens on slow shifting with the clutch fully depress too. My guess is the shift linkage. I'm taking it to the dealer on Monday to have it check out.
mlk_f1 is offline   Reply With Quote
Old 02-09-2006, 08:51 PM   #6 (permalink)
Seabiscuit's Avatar
I would be shocked if it was a syncro with that low mileage. Stan may be correct. The clutch could be the problem. You probably haven't hurt the car. Just double clutch on the downshifts till you take it in.
______________
Greg
Old 02-09-2006, 10:38 PM   #7 (permalink)
Avi
Avi's Avatar
The car is shifting normal all other times, including being stopped, and reverse, its just down shifting at high rpm's from third to second that is the problem
Old 02-09-2006, 11:11 PM   #8 (permalink)
mlk_f1's Avatar
Images: 11
I forgot to mention. I did do double clutch downshifting when the problem occurs to test it. It still grinds.
Old 02-10-2006, 06:29 AM   #9 (permalink)
Project Nirvana Elise
shinoo's Avatar
I suspect it is the tranny cables. The cross-gate cable may need some adjustment.
shinoo
sector 111 - tasty bits for your elise & exige
shinoo is offline   Reply With Quote
Old 02-10-2006, 10:02 AM   #10 (permalink)
Avi
Avi's Avatar
Ok, so i went to South Bay this morning for service. They took a drive with me and think it's a syncro issue. They did an ecu dump, and now have to contact a few Lotus folks before determining what they are going to do. Most likely they will install a new transmission.
Old 02-15-2006, 09:29 AM   #11 (permalink)
No more cone damage!
Surferjer's Avatar
Any update on this?
1993 MR2 autox car
Old 02-15-2006, 12:40 PM   #12 (permalink)
An entirely new transmission?! Wow . . . did they figure out what it was first? Brand new transmission seems a bit extreme if it was something like a synchro or a clutch issue, so I'm assuming something bad happened . . . I've been having a similar issue with 3rd gear on my car . . .
Varien is offline   Reply With Quote
Old 02-18-2006, 02:30 AM   #13 (permalink)
Avi
Avi's Avatar
No word yet from Lotus. I spoke with the dealer yesterday, and they told me they should know this week. I agree that a new transmission is a little extreme, but hey if it fixes my issue.....
Hopefully I can have the "new" improved stage 2 installed at the same time. My stage 2 has had issues for months now, and after multiple repairs it still rattlesl. Oh yeah Lotus can fix a bad rattle from the dash (where the window vin # is), and my soft top is falling apart.
I do have to say with all the issues i have been having the service has been amazing. South Bay has been really an awesome/impressive dealer to deal with. Also when I had my star shield replaced for yellowing, the SS people were awesome to. Overall a very good experience getting stuff fixed. I did buy the extended warranty with the car, as it may be very helpful in the future to have!
Old 03-16-2006, 11:07 PM   #14 (permalink)
Avi
Avi's Avatar
Still no word from Lotus on my issue. All I know is that someone else at my dealer has the same issue, but with only 2500 miles on their car. For my troubles of not being able to drive my car fully, for over a month, should I request my new Tranny with Traction Control, and or a lsd? I track every 2-3 months, but for fun. I would not mind a little piece of mind with traction control for driving in the wet? Does the traction control come with a new tranny, and is there much cost difference? Should I ask for it, and the lsd? Do I even need lsd?
Thanks for your input, as I am getting fustrated with the amount of time Lotus is taking to fix my problem. I also still have a F'd up stage2, a bad rattling noise coming from where my dash meets the windshield, and a soft top with one of the rails detaching from the canvas. I love my car, love the dealership, and service so far has been amazing.. until now? What should I do?
The Worlds Most Elite Designers
www.GNAH.com
Old 03-16-2006, 11:16 PM   #15 (permalink)
Surferjer's Avatar
Dollar-wise that's a big upgrade, and they're not even available as a retrofit yet. You can ask but you'll never get it.
I thought the LSD was a big enough deal to buy another car!
1993 MR2 autox car
Old 04-12-2006, 05:53 PM   #16 (permalink)
Avi
Avi's Avatar
Just got word from South Bay that my new transmission has arrived and they will be installing it next week aalong with a brand new Stage 2... If anyone has a similar problem report it immediately and ask for a new tranmission. The syncros will only get worse with time and grinding. There is one other case in the LA area where Lotus is also replacing this persons transmission. Oh yeah the cost for a tranny in our cars is 6000.00.. I saw the tranny paper work!
www.GNAH.com
Old 04-12-2006, 06:20 PM   #17 (permalink)
Super 7 Owner In Training
EburgE's Avatar
Can I have the old part?!?
'05 Lotus Elise
'07 Caterham Seven www.hals7.com
EburgE is offline   Reply With Quote
Old 04-12-2006, 06:41 PM   #18 (permalink)
loading...
turbo2nr's Avatar
man, you beat me to it.
(A few trannys out of 2000 go boom does not mean much on a sports car. No need to set off an alarm.
Now the subaru wrx....that's a real POS tranny. I have plenty of broken parts from stock cars around central VA. 1 out of 2 wrx cars will have tranny failure within 30,000 or so.
Boom Boom, shakka-lakka BOOM
turbo2nr is offline   Reply With Quote
Old 04-12-2006, 06:48 PM   #19 (permalink)
Surferjer's Avatar
My guess is Lotus or Toyota will want the old tranny to study.
1993 MR2 autox car
Old 04-12-2006, 09:16 PM   #20 (permalink)
Does that include labor for installing it? Otherwise Lotus has a pretty nice markup on the Toyota part.
Reto
2005 Lotus Elise (yellow, sport pack), #94 SS
2005 Nissan Xterra (LSV)
ConeFusion is offline   Reply With Quote
