Old 07-14-2009, 07:55 PM   #1 (permalink)
Maypo's Avatar
Head R&R
Okay, I'm removing the cylinder head to replace a broken valve (and whatever other damaged parts I find) and I find that the long bolt that attaches the accessory belt tensioner assembly is too long to be completely removed. The bolt runs into the frame.
Will I be able to remove the timing cover and this tensioner assembly simultaneously? Can someone who has performed this task give me some guidance on this?
2006 PB Exige (Solo II ASP)
2001 M3 (daily driver)
1998 328i (wife's car)
1992 V6 Miata (grin factory)
'Ferrari 308s and F16s -- these are the conveyances of free men.' - P.J. O'Rourke
Maypo is offline   Reply With Quote
Old 07-14-2009, 11:29 PM   #2 (permalink)
Harrybauls's Avatar
You should be able to jack the engine up a enough to get enough clearance (after unfastening a 3 of 4 of engine mounts to get it free - leave the back engine mount in place). I had to have a go at this bolt (I took the engine out) after it sheared off at the race track due to being over torqued at the factory. Major PITA - I lost the head gasket from over heating and had to drill out the old bolt.
Harrybauls is offline   Reply With Quote
Old 07-15-2009, 10:16 AM   #3 (permalink)
Maypo's Avatar
Kind of figured that. Ridiculous, IMO.
Thanks.
Old 07-15-2009, 10:46 AM   #4 (permalink)
I had that bolt snap on me and had to replace it, what a pain in the a$$, to change 1 bolt I had to take the rear clam off . if you take the right side motor mount off and lift (or jack up) that side of the motor you should be able to get the bolt out, but it is a VERY tight fit. I had pry bars and was just bearly able to get the stupid bolt in there.
2006 Chili red Elise
ECPERFORMANCE is offline   Reply With Quote
Old 07-17-2009, 08:21 AM   #5 (permalink)
Maypo's Avatar
Here's what I found:
Old 07-19-2009, 07:21 PM   #6 (permalink)
choi0706's Avatar
thats not uncomon..
Jay-05' ST, HT, Touring Red
Rally Ready
choi0706 is offline   Reply With Quote
