Old 09-17-2009, 08:54 AM   #1 (permalink)
ILuv4REs
ILuv4REs's Avatar
Help.please..... Intermittent shifting issue.......
Hello,
I hope ya'll can help. I have a 2005 Elise with about 7k miles on it.
Recently, it started becoming difficult to put into gear from a stop. However, this is an intermittent issue, not something that happens all the time.
I already bled/flushed the brake fluid in both the brake lines as well as under the car at the clutch, and even with the new fluid it is still doing the same thing. In addition, it doesn't appear that the clutch is slipping and clutch pedal feel is normal. Just hard to get it into gears from a stop.
Its at the dealer now. He rebled the clutch again, and checked all linkage/cables.....all ok, yet still doing the same thing.......
Anyone have any ideas/suggestions/info before I have them pull the trans to check inside????
ILuv4REs is offline   Reply With Quote
Old 09-17-2009, 09:29 AM   #2 (permalink)
Race lines on the mind
Tracktimeplz's Avatar
So if you are having trouble with the gear box, why are you looking at clutch fluid?
You may be leaking transmission lubricant. Drain (If needed at this point!) and refill your transaxle.
2003 Honda S2000 - Suzuka Blue
2005 Magnetic Blue Elise
Forcefed 275 turbo - Sold 05/20/09
Tracktimeplz is offline   Reply With Quote
Old 09-17-2009, 10:54 AM   #3 (permalink)
ILuv4REs
ILuv4REs's Avatar
If there was an air bubble in the clutch line, it could cause issues. So, that was an easy thing to check first. Plus, it was time to flush the brake fluid again anyways.
I will have them check the tranmission fluid level. That's a good, easy thing to check.
Perhaps I have the pressure plate ring/clip failure issue??
Old 09-17-2009, 11:15 AM   #4 (permalink)
Will There Be Cake?
ItsThaMonsta's Avatar
This may not be the same thing but all 3 manual cars I have owned have intermittent problems of getting into reverse. It just gets stiff sometimes. All I do is bring it back to neutral, left the clutch go and then do it again and it usually goes. I never thought anything of it. But again, this may be different than your problem.
ItsThaMonsta is online now   Reply With Quote
