LotusTalk.com is the premier Lotus Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 09-18-2006, 12:02 AM   #1 (permalink)
mlk_f1's Avatar
Images: 11
Helpful Tips for removing Stock Exhaust Manifold
I was trying to post this in the library but was denied access. So, if you Mods find this worthy, please move this to the Library section.
This might be helpful for those that plan to install header.
1) You do not need to remove Belt Tensioner
2) Nor, have to hacksaw the Air Injection tube off.
I did not take pictures, Photos are courtesy of ET user "milcher"
Stock Exhaust Manifold removal tips without the need of hacksaw or belt tensioner removal.
1) remove Cat, Exhaust Manifold upper and lower heatshields.
2) remove the 2 nuts and 3 bolts holding the Exhaust manifold. Also remove the one nut holding the Air injection tube from the rear right wheel well.
3) Remove the stud circled in RED below with a Torx socket.
4) Slide the exhaust manifold out until you have access to the Air Injection Tube Cap from the Rear Right Wheel well.
5) Use a plier to slide the clip free from the rubber hose cap circled in red below. You need to do this from the Rear Right wheel well. Remove the Hose Cap and Clip completely.
6) Now you can slowly work the whole Exhaust Manifold out of the engine bay from below. Trust me, it will come out at just the correct angle. Be patient.
Good luck.
mlk_f1 is offline   Reply With Quote
Old 09-18-2006, 04:02 AM   #2 (permalink)
User, Registered
fpitas's Avatar
Good tip, this looks like the best solution for getting the old manifold off.
Francis
2006 Chrome Orange Elise: LSD/TC, Nitron SAs with 425/650 springs, BWR 7/8" ("Hardcore") Front Bar, Eliseparts bumpsteer kit, VF Stage 2, 2bular Header + Sport Cat + 8x24 GT3 Muffler, ECU Tune by Jermaine, Smaay's fuel rail, ACT XT clutch, Saikou Michi dual catch can, Moroso pan, Manly's mount inserts & FF Engine Damper
2000 Black Integra Type R - DD: 223,000 miles!
Old 10-29-2006, 08:02 PM   #3 (permalink)
jhnmdahl's Avatar
Is there a reason to keep the cold air injection pipe once it's out? I'm considering doing this, but am thinking about cutting the cold air injection pipe off near the header and plugging it so it doesn't have to be snaked back beside the engine.
jhnmdahl is offline   Reply With Quote
Old 11-04-2006, 12:16 PM   #4 (permalink)
Mikey likes it!
insane's Avatar
Thanks for posting this--just tried it (well--I'm taking a break before i torque the nuts and bolts). I removed both of the studs and the rest was just as you said.
A couple of comments, though... I didn't go in through the passenger wheel well because I'm using rhino-ramps. The air tube fasteners were fairly easy to reach from the bottom.
But mostly, in step number 6, when you say 'patient', you should put that in bold, and underline it, and put it in caps, and underline it again!
But it all worked out. Thanks again.
-Michael
'05 Nightfall Blue
insane is offline   Reply With Quote
Old 12-06-2006, 01:07 PM   #5 (permalink)
The Mad Scientist
darkSol's Avatar
FYI: Sears has a seven piece external Torx socket set on sale today and tomorrow for $19.95:
http://www.sears.com/sr/javasr/produ...id=00934570000
It was also in yesterday's flyer in the local newspaper...
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1786lbs.
Drop down a cog give it a handful come round about the roundabout
darkSol is offline   Reply With Quote
Old 12-07-2006, 07:42 PM   #6 (permalink)
Boosted2.0's Avatar
Nope - its not hooked to anything anyways - the Elise doesn't have air injection. lately I've cut off and welded up all the ones I've ported.
Boosted2.0 is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
