Old 07-10-2006, 02:20 PM   #41 (permalink)
Originally Posted by Eyelise
I believe the temp guage is at the radiator not engine. Hard for me to believe that you could have a dedicated A/W system in our engine bay running close to ambient. I bet if you monitored engine bay temps they would be in excess of 150 degrees. If you add to engine bay temps heat from the the intake charge exiting the turbo, it will run at least 185 degrees. You couldn't get enough clean air to cool a small radiator like the one pictured less than that. The system would have to be in parallel with the engine coolant system.
I doubt the box pictured is the actual 'radiator'. Usually an A/W system has a intercooler core if you will (the silver box in the picture) which is hooked up to an auxillary radiator in the front of the car. An inline waterpump circulates the water through the system. It is a closed loop not connected to the engine coolant system. This looks like an aftercooler by the way, meaning its after the s/c. Why run big pipes for an air/air system when you can run small water lines and also not get a pressure drop across the system? Boost is at a premium with the s/c, not like you can just crank the boost controller.
Ginetta is offline   Reply With Quote
Old 07-13-2006, 01:15 PM   #42 (permalink)
jamie's Avatar
Hi Guys
I am based in the UK and recently made a trip to Switzerland
And since Bemani came up I thought you might be interested in this
Have a read of my review here its in the Queens English
http://www.exiges.com/ubbthreads/sho...b=5&o=&fpart=1
jamie is offline   Reply With Quote
Old 07-16-2006, 11:02 AM   #43 (permalink)
Val
Nothing
Val's Avatar
Jamie, awsome man!!!
Val is offline   Reply With Quote
Old 07-16-2006, 01:10 PM   #44 (permalink)
jamie's Avatar
cheers mate
