#181 (permalink) |
eTard
I just finished my install.
Let me tell you, I would like to nominate this as being the Best Modification Ever. ![]() Honestly, the instructions leave a bit to be desired (Troy is updating them as I type). When I had the product in hand and read the instructions, my first thought was "Oh my....I may have just wasted a bunch of money". Boy was I wrong! On the PITA to install scale, I would rate this as a 6-7 out of 10, but it is well worth the pain (literal and figurative pain). I used the shortest throw possible, which is amazingly short. I can't wait for the roads to clear up so I can do the final tweaks/adjustments. Troy, you my friend are one hell of an inventor and visionary. ![]() ![]() |
#185 (permalink) |
Plug Whisperer
I just placed my order...
Troy, you're nuts! I can't even justify making one of these for myself at the price you're charging. As soon as you ship and process my order, you should raise the price ![]() Cheers, Phil
#186 (permalink) |
wow this thing is small..
Just ordered via your website, Troy... can't wait to join the legions of overjoyed users!
Thanks for taking the time to put these out! ![]()
06 Elise - chrome orange scootypuff 06 Magnum SRT8 - loaded black rocketbrick 05 SSR - yellow funbuggy 70 Charger R/T 440 - plum crazy snarlybeast 70 Cuda 440 convert - sublime burlycruiser |
#188 (permalink) |
I couldnt hold back anymore, order placed.
05 Ardent Red, FF rear wing, FF half carbon front splitter,CF mirrors, exedy clutch, toda flywheels, revire Side scoops, arqray single tip, larini decat, fujita intake. all lights, minus the heads, blacked out. |
#189 (permalink) |
I want this so much I just paid for 2 kits!!!
hung dot eric at gmail 06 111R (Daily Driver) 08 A5 (Winter beater) 05 AP2(SOLD) 97 GTi VR6 (SOLD) 02 RS250 (On Sunny Days) 05 600RR (SOLD) 04 NSR50 (Track Bike) 93 MC21 (SOLD) |
#190 (permalink) |
eTard
Here's a short video of 1st through 3rd gears, which will visually demonstrate the throw distances.
Installed in '05 Elise. Adjusted to the shortest throw possible. Not road tested. Car not running. Cold transmission. I've not made any adjustments to the cables. Sorry the video is sideways, but this was the only way I could hold the camera and shift at the same time. |
#191 (permalink) |
Exige? SEXIGE!
more videos! does it get rid of the "wiggle" when you're in gear? How about rowing though all 6 gears?
Phantom Black 2007 Exige S221.56436. All options. Black 01' Mustang Cobra 'Vert ("some" modifications) daily driver Facebook group: Add lightness...and Darkness! |
#192 (permalink) |
eTard
Yes, the wiggle is virtually gone. It's pretty rock solid. I had to use a Dremel to remove some metal from the base plate of the shifter because the tapped hole in the floor didn't line up with the drilled hole in the base plate.
As requested, another video: Last edited by craracer : 02-24-2009 at 08:23 PM. |
#193 (permalink) |
Hydrocarbons Rule
Got mine today
. Just wanted to confirm everything is already locktighted since it comes preassembled (awesome) before installing it.
2006 Exige; BWR Supercharger, Adj Sway Bar, Ohlins Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Clutch, Custom Exhaust, Black Volk Racing CE28N's w/ Toyo R1R's, 2 piece rotors, Pagid Blue Pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Panels), Dry Carbon rear Diffuser, Harness Bar, BWR Gauge Mount, OMP Superquadro steering wheel, LETSLA Short Shifter, V2arms, Rear Tow Link Brace, RLS Battery Bracket, BOE Tow Bar, Stickers. Last edited by Dragon : 02-25-2009 at 01:05 AM. |
#194 (permalink) | |
Exige? SEXIGE!
Thanks! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#195 (permalink) | |
JabStrongFierce
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning |
#196 (permalink) |
Elise...Best Daily Driver
Hi Troy, I PMed you, I would like to purchase if you have another kit available. Thanks, Rob
2005 Elise, Starlight Black/Red, Modified tilting clam, driving lamps, LED Tail lamp set, hybrid longtail/ and hardtop, Exige rear wing, radio delete, air bag delete, Custom Leather & Alcantra binacle, UK steering wheel, HVAC controller relocated, UK ECU, Carbon mirrors side mirrors, Zoom carbon rear view mirror, and Cup Wheels & Tires. |
#197 (permalink) |
Troy, Just ordered mine. Regards, Robert
#198 (permalink) | |
The throw is still noticeably shorter, without being quite that extreme. And the outstanding feel remains regardless of which setting you use. If I want to go with the shortest throw, I can adjust it in about 5 minutes. Ditto if I want it out closer to stock, or even all the way back to stock. That's what's interesting about Troy's approach. He could've just replicated the stock mechanism, just improving the feel by taking out the play. He could've just shortened the throw. He not only did both, but engineered in EASY adjustability. He didn't have to throw in 'Stan's Shifter Mod' bits. He could've charged and gotten what he's getting without doing it... he could've just recommended it be done with your own bits while you have the console off. He didn't need to throw in the cable bracket. That probably doesn't materially help the feel, but it will likely help with cable longevity. He also didn't need to mill the bracket out of billet aluminum. As with 'Frank's Sleeves' (ahem) over the cable ends. He didn't need to include them. He just saw a potential tangential problem while he was fiddling with the thing, turned a few pieces on his metal lathe, and threw them in the kit. Phil....re telling him to raise the price right after YOU get YOUR kit...funny thing is that's what I told him and mine was the first install!!! ![]() Last edited by lotusforsale : 02-25-2009 at 02:02 AM. |
#199 (permalink) |
Elise Driver
![]() Join Date: Apr 2008
WOW. Thanks for all the kind words. I knew by the reaction whenever anyone got in my own car and it feels it was worth making. I went through like 5 different versions and ideas over a few months before I got it just where it is with everything I wanted.
On the directions I have done it so many times myself now I forget the little things and I do not have a good camera (iphone only). If anyone wants to take good pics and send them to me I can put them up to try to make it easier. If anyone wants to email me any fixes to the directions or other ideas on directions please feel free to as I love feedback. Also, taking apart the LETSLA does make the install easier IMOP, but there are different ways to install it. I have heard it taking from 30 minutes to 3 hours so slot some time, take your time and it will work out fine. If you have any questions just email me your number and I can call you. I just do not want to give my number out on a forum. Thanks for the video, that is good stuff. I also tried to make the kit as comprehensive as possible and include everything needed. I also tried to give options on where the shift is as some want stock, some want super short like myself and there is in between. I did not want just some short throw shifter and you are stuck with a position you might not like. I even threw in a ziptie for the front console leather boot just to be anal. I do have some in stock right now that I am going to ship out, but I need to check all my orders. I am having another production run of parts shipped to me this week so I will have plenty in stock for everyone. If I did not ship this week it will be Monday/Tuesday of next.
Trueleo LETSLA 2005 Elise-LR,SP,HT,T, Trueleo LETSLA, Exige side scoops and grills, Stage II exhaust, FF splitter, Air2Gel seat foam, Stripes, Eliminator, Future- TVS SC kit, Fidanza flywheel, ACT HD, Custom SC headers and exhaust, SS valves, Ti Retainers, |
#200 (permalink) |
I just placed the order for the shift kit. I will be installing it on the 2-11. I just met with Dave Simkins and Abraham of Lotus this past Monday and we spoke briefly about your kit. they are interested in knowing how it works and holds up.
I will be letting them know and I will give you a running report after the car goes out on track. Hoping for the best, Al B. Houston. |
