#223 (permalink) |
eTard
I didn't take any because most of my time was spent staring at the garage ceiling while performing painful blind maneuvers in contorted positions. Now I see why he had such difficulty attaining respectable photos of the process.
#224 (permalink) |
Hydrocarbons Rule
Installed my kit last night. Absolutely love it... I have 2 herniated disks that are friggen killing me at the moment from doing the install, but it was worth the pain. I would highly recommend this to anyone that drives the crap out of their car.
#225 (permalink) | |
Prez: The K.G.B.
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - stripes - harnesses - Pagid pads - Green air filter 2002 Jaguar XKR convertible 2000 BMW 528i President - Lotus Limited Southeast http://autos.groups.yahoo.com/group/LLSE/ |
#226 (permalink) |
Yahoo! Got my Rotus!
Cool! How long did it take you start to finish?
David Avery 05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE 08 BMW 135i Stock visit Spyderclub.com |
#227 (permalink) |
Aspen White
I have a quick question regarding this product...is there any relationship between the throw length selected and the reduced sloppiness of the stock shifting mechanism?
I ask this question because I plan to stay near the stock shift length, but want to tighten up my shifter. Thanks.
2006 AW Elise |
#228 (permalink) |
Elise Driver
![]() Join Date: Apr 2008
The ball bearings on the linkages and rod end bearings are what take out most of the slop. There is still some in the cable as all push pull cables have some loss of motion in them. So there will be less slop for sure, but I have not found that the throw length you choose it will feel the same except for throw length.
HTML Code:
I have a quick question regarding this product...is there any relationship between the throw length selected and the reduced sloppiness of the stock shifting mechanism? I ask this question because I plan to stay near the stock shift length, but want to tighten up my shifter. I will check this out for sure. HTML Code:
All the details can be found at LOG 29
Trueleo LETSLA 2005 Elise-LR,SP,HT,T, Trueleo LETSLA, Exige side scoops and grills, Stage II exhaust, FF splitter, Air2Gel seat foam, Stripes, Eliminator, Future- TVS SC kit, Fidanza flywheel, ACT HD, Custom SC headers and exhaust, SS valves, Ti Retainers, |
#229 (permalink) |
Has any done a 2005 Elise?
I didn't see a rectangular plastic cover on my cross-gate lever. My cross-gate lever end has wear marks. Looks like my car never had a cover.
2005 Elise Storm Titanium |
#230 (permalink) |
eTard
Yes, it does look like you have wear. I had the black piece on my '05.
The piece, when attached to the crossgate arm, fits into a small slot on the transmission. My piece came off the arm and was stuck in the small slot (happened when I removed the assembly). Took me forever to find the piece. ![]() |
#231 (permalink) |
Also, my rug was stolen.
Good info guys...I ordered one of these kits and have a low milage '05. What is the "rectangular plastic cover"? What should us '05 owners be wary of before we install?
Thanks!
05 Lotus Elise S/T 06 Porsche Carrera S Coupe - for hauling kids and luggage |
#232 (permalink) |
Hydrocarbons Rule
Took me about 3hrs, but that was with a bunch of smoke breaks to alleviate some back pain. My cable bracket was a bit of a PITA due to my oil catch tank being some what in the way. To top it off my E-break handle allen set screws are stripped. This cause a ass load of fun with trying to pull up the center console to adjust cables.
Last night I did a 5 hr drive around the island with LOTS of shifting. This new shift linkage is smooth, crisp and solid. I would highly suggest trying the settings it ships with before playing around with other settings. I figured I would try the base setting and then go from there, but after driving it with the settings it came in I'm not even going to dick around with it. It's perfect the way he ships it. For anyone who may be holding out this mod is worth every penny and then some.
#233 (permalink) | |
eTard
The black plastic piece is small, and easily slides off the end of the "nub". It can fall off when removing the arm, and given it's size, could easily be lost. This black piece, when attached to the cross gate, fits into a groove on the transmission (sorry, I don't know the technical name for the part it slides into). You won't be able to see where the groove is, but you can feel it with your fingers. Just a note: As I recall, the instructions state to remove the 2 "Allen" screws holing the center console in. On my vehicle, they were actually torx screws. I found it easier to remove the cup holder and shroud between the seats to facilitate removal of the center console. Given the length of the shift lever and positioning of the dash, I was unable to lift the console up enough. Removing the cup holder and releasing the C-clips from the transmission cables made it much more easy. There is one phillips screw in the bottom of the cup holder, and two phillips screws holding the shroud in place. |
#234 (permalink) |
Elise Driver
Jim
All the cars come with the plastic black piece and the wear marks are there from that. Mine looks like that also when I took it out. When I did one install I dropped the piece also, but I knew I dropped it since I was feeling for it. I never heard it drop as it was plastic and could not see it. I had to take the pan off to find it and it was sitting on top of one of the black little are inlet things. I also found that if I take a rubber mallet or something soft I can tap on the bottom of the pan and plastic cover or missing bolt would bounce and I could see where it is so I can get it. You do need that piece. HTML Code:
Has any done a 2005 Elise? I didn't see a rectangular plastic cover on my cross-gate lever. My cross-gate lever end has wear marks. Looks like my car never had a cover.
#235 (permalink) |
Elise Driver
There are new directions on the site now. http://www.trueleo.com/Eliselinkageinstall.htm
I have also added different buy now options for when you purchase to keep track of which car you have instead of the comments field. If you purchased in the last week email me if you have an 07-08 car to make sure you get the kit with the correct sheath protector size in it (everything else is the same).
#236 (permalink) | |
I'll be looking for it today. I hate pulling the diffuser if I don't have to. Here's a couple of photo's I took.
#237 (permalink) |
AR #1275
Damn you TroyLotus why must you tempt me so?!?!?!?!?!?
'06 Ardent Red Elise - black interior with LSS, Touring, HT, Starshield, Lotus Sport Clutch, Moroso Oil Pan, 2ZZ(#2), Ekological HIDs, Lotus Driving Lights, Stebel Horn, Bootie, Razo '06 Pedal mod,Snorkel Delete,Odyssey 680 with s111 bracket. Future Mods:LETSLA (ordered), Rear toe link brace Thank you FVMC! ![]() WOO-HOO!
#238 (permalink) |
Hydrocarbons Rule
I'm telling you... Don't think, just buy now before they are on a 6 month back order..
#240 (permalink) |
Thanks Jim - I am waiting impatiently for the arrival of the kit and have memorized the fitting instructions from reading them so often, but was having trouble visualizing this part.
Then all I have to wait for is the weather to warm up a bit.......
2006 Elise, Chrome Orange, Sport Pack, Touring Pack, Stage 2 2004 Cooper S, Black, -15% s/c pulley, 22mm sway bar |
