#281 (permalink) |
Good idea. As long as it suits RHD as well.
www.petersracing.com 2008 Exige S PP |
#282 (permalink) |
eTard
**Newbie alert....The following question may contain material, which would obviously be considered developmentally delayed. If reading these types of comments/statements cause you to monkey punch yourself, please do not read any further**
*Warning.....this is your last chance to bail out of this question* What's the problem with the seat rail? |
#283 (permalink) | |
Then I want to complain about the seat rail has the following problems: ![]() - little play when new, then getting bigger and bigger 2 questions about the driver seat - Steel to Aluminum contact noise, no matter how you tie up the bolts on the seat rail, the steel to aluminum contact noise just won't go away especially when you step on the clutch . I am trying to find some nylon washers to place between the steel rail and the alumnium body. |
#284 (permalink) |
Meow!!
Ok here's my mini-review for now... more to come later!
Overall feel is at least 10x better than stock. Feels amazing. It's deceptive that you THINK that you have to push/pull the lever farther than you really have to. When running stock you have neutral, a no-man's land area and then a space of about an inch forwards and backwards where the gear sits in. Now the grey area and the operative area are much smaller. I left the "as shipped" setting for the forwards/backwards motion but was not happy with the "too short" feel of the "as shipped" left-right motion so it was set to the next hole for more lateral movement. It's perfect now. The only caveat (and it has nothing to do with the LETSLA) is that I couldn't engage 3rd this evening when I took the car home from TurboPhil's (TVS installation - more to come on that in the morning ). 3rd previously would just give a quick "grind/chirp" but would still engage - now it's all gharrrrrraaharrhhaaarrrr metal on metal. I think I'll try to reposition my forwards/backwards movement at the actual shifter to try to get more forward movement out of it. If if then it's C60 time for me (I want the taller 6th anyway).A solid 10/10 for a mod. This is the way the shifter should have been from the factory.
#286 (permalink) |
Head LOONY
I am going to order anywhere from 2 to 4 pretty soon....
Tony Vaccaro 2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter, www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances |
#287 (permalink) |
Elise Driver
![]() Join Date: Apr 2008
Here is a quick message on the possible problem with 3rd gear install. I had the sheath protectors initial design with a 1.5" depth inner diameter to slide over the sheath protector and sent out for quote with that. After testing I found that it needed to be 1.75" minimum. I wanted to extend the sheath protector as far as I could to help with protection as much as possible. When it was manufactured they did not look at my updated drawings and ran them with 1.5". So the sheath protector with the smaller inside may stop the car from going in 3rd gear because it extends to far on some cars. I have already corrected the problem with the latest orders shipped and I have received more sheath protectors with the correct size. I sent them out to all that have had ordered so far and you should have them soon. This has only happened on two cars so far, but better to send out all new sheath protectors for the bellcrank lever. If you do have that issue you can just take off the sheath protector you have until you get the new one.
Troy
Trueleo LETSLA 2005 Elise-LR,SP,HT,T, Trueleo LETSLA, Exige side scoops and grills, Stage II exhaust, FF splitter, Air2Gel seat foam, Stripes, Eliminator, Future- TVS SC kit, Fidanza flywheel, ACT HD, Custom SC headers and exhaust, SS valves, Ti Retainers, |
#288 (permalink) | |
Meow!!
I'll change it out when it gets here and will let you know. Whew!
#289 (permalink) | |
Hydrocarbons Rule
It also helps if you don't screw the heim joint on too far.
#291 (permalink) | |
Elise Driver
Dragon-
That is a really easy way to do it. Out of the 50 kits I have sold and sent only two people had this issue and you were one. I had all new ones made that were deeper as they were supposed to be and sent them out to everyone. You should received them anytime now. I did not think anyone else had the issue and if 3rd gear works then it does. I did know that if you do not turn the rod end bearing all the way in and then out 5 turns you would not have enough Clarence so if that is the problem make sure you followed that step first. If you do not want to wait you can simply take a 7/16" drill (1/2" if you have an 07-08) and drill it about 1/4-1/2" deeper. I just sent out all new ones as I did not know who would have that size drill bit, a drill or a vice to hold the part. Better to be safe then sorry. Quote:
Trueleo LETSLA 2005 Elise-LR,SP,HT,T, Trueleo LETSLA, Exige side scoops and grills, Stage II exhaust, FF splitter, Air2Gel seat foam, Stripes, Eliminator, Future- TVS SC kit, Fidanza flywheel, ACT HD, Custom SC headers and exhaust, SS valves, Ti Retainers, Last edited by Mr. Know : 04-14-2009 at 12:49 AM. |
#292 (permalink) |
Great product and great customer service - thanks Troy! Look forward to receiving the revised sleeves shortly.
Does the Letsla need any lubrication? Also, should I be using some lubricant/grease on the cables? ![]()
2006 Elise, Chrome Orange, Sport Pack, Touring Pack, Stage 2 2004 Cooper S, Black, -15% s/c pulley, 22mm sway bar |
#293 (permalink) | |
Elise Driver
Thanks and the LETSLA comes with all sealed pre lubricated bearings so it is not needed. You also do not need to lubricate the cable.
Trueleo LETSLA 2005 Elise-LR,SP,HT,T, Trueleo LETSLA, Exige side scoops and grills, Stage II exhaust, FF splitter, Air2Gel seat foam, Stripes, Eliminator, Future- TVS SC kit, Fidanza flywheel, ACT HD, Custom SC headers and exhaust, SS valves, Ti Retainers, Last edited by Mr. Know : 05-17-2009 at 11:02 AM. |
#294 (permalink) |
I sent my monies in last Friday but haven't heard anything back. Any idea when my order would have or will ship?
2007 Ardent Red Elise, track pack, BWR SC 2004 RX-8, 350z muncher 2004 BMW 325i, kiddie hauler |
#295 (permalink) | |
Elise Driver
#296 (permalink) |
Also, my rug was stolen.
Got mine today. Plan to install Friday or Saturday. Will update progress.
First impression: if you bought your Elise due to appreciation engineering & design, like I did, you need this kit; just to touch it and feel its movement.
05 Lotus Elise S/T 06 Porsche Carrera S Coupe - for hauling kids and luggage |
#297 (permalink) |
I did as well. Can't wait to get it installed, but I have to wait for my more technically-competent friend to assist.
'05 Elise Last edited by petroboy : 03-06-2009 at 09:33 PM. |
#298 (permalink) |
Received mine here in the UK yesterday, fitted today. Looks a top quality product. Many thanks Troy
Fitting only took about 1/2 hour, but I do have the clam, intercooler and airbox off at the moment and interior fully stripped. Big respect to all those who have fitted this kit with all bodywork on The kit will get its first and a serious work out weekend of the 14th 15th as I have 2 consequtive track days in Northern France. will update on how it performs |
#299 (permalink) |
AKA XHILR8N!
OK I'm in
Simplicity is the ultimate sophistication. Leonardo Da Vinci 2005 Elise LRG, Trim Shop interior, full cage, Cup wheels, other stuff. 2007 Toyota Tundra (about 10 cup holders) 2004 BMW X3 (4 small cup holders) 1980 Rover SD1 |
#300 (permalink) |
TL
Laser blue,biscuit, micro mirror, "Blue knob" ,HID lights,modded rear lights,rear badge,blue starter button, replaced speakers,perma grin, Club111 ![]() ![]() The Sith lord of the LB's loyal henchman
