#561 (permalink) |
the need for speed
Just a quick note, I went up to north jersey to install the LETSLA upgrade kit for an Exige owner. The upgrade made a nice difference. If anyone in the NJ area needs help let me know. Troy, thanks again.
'05 Elise, Storm Titanium, Gullwing top, custom pinstripes, LETSLA, stage II exh, BWR (sitting on coffee table) |
#562 (permalink) |
Head LOONY
We should give this another bumpppppppp!!!!!
Great product and really makes a difference.
Tony Vaccaro 2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter, www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances |
#563 (permalink) |
I did mine this weekend (1st gen kit). Took me about 3 to 4 hours. The engineering required to come up with this kit is impressive. The location of the linkage could not be in a much worse spot. You have to make the adjustments at the shifter under the center console. I did almost all of my adjustments on the lower crossgate cable. I couldn't shift into 1st-2nd at all and ended up turning the end at the shifter out about 4 to 5 full turns. It seems sweet now. I can only get into reverse by pulling up on the lockout.
Here's a tip for removing the center console: Reach either underneath or through the shifter boot hole (if you removed the shifter boot) and simply pop off the upper cable (shifter) with a 12 mm wrench to pry it off. It's a simple ball and socket and pops right off. Then your shifter will go very far forward and you can easily slide the console off. Pop that shifter cable ball socket back on and try out your shifts.
05 Elise BWR 08 Mazdaspeed3 DD 08 Ducati Hypermotard 06 Honda Ridgeline 51,58,65,69,69,71,74 VWs |
#564 (permalink) | |
NOT the Stig
Should I dremel off 1/16 at the end of the cable? ![]() Cheers, E
Eric the Bastard, Esq. Sylmar, CA 2005 Buzzbomb Chrome Orange Larini SE Exhaust LETSLA shift kit
#565 (permalink) |
Enemy of the State
Is there more room to adjust he cable at the transmission end?
06 Elise, AW, Touring, Sport, Premium, Hardtop, Starshield -- S111 Harness bar, Schroth ASM 6 point Harnesses, Seat Grommets, Front Tow Hook, Rear Tow Hook, Halon fire extinguisher, Polk speakers, MicroMirror, Odyssey PC680, ekological HID kit, Pagid RS14 pads, SS brake lines,CF Center Console, CF AC Surround, urethane motor mounts, Titanium Dave's Sub Belt Bars, Heater Core Bypass , Craftsquare Mirrors, Carbon Splitter, LETSLA, DBW Pedals, Xtender |
#566 (permalink) | |
NOT the Stig
![]() Actually, I regret nothing, it worked fine and pulling the whole linkage assembly to get two turns out of the cable without absolute assurance that it would work was a bit daunting in 102°F weather. There was plenty of excess thread on the shifter end to work with. It works beautifully now. ![]()
#567 (permalink) |
Updates on lestla install
hi troy as my mechanic has been super duper busy. the install for the V2 kit has been delayed until 2 days ago
We have made the install... the shift was a little notchy and tight as we could not understand the instructions fully... we finally got HK-FEVER to pop around to the workshop and give us some insight... boy did that help. Shift kit is now installed.... Did a test drive this morning and boy its short and crisp..... alittle notchy but not enough to bug me... i am sure when the system gets used a bit more it will be even smooth ONE question to ask troy, my complete kit is already the V2 kit. With the original cable bracket comes a recatangle aluminium spacer to change the angle of the bracket. We couldnt get the kit to work with the spacer on, the bracket leans forward and down towards the front end. Is this correct ? Kit seems to work fine without this spacer piece ? is it safe to install without this part ? my car is a 2005 exige, one of the first batches of the Exige S2 advise needed SIMON
Krypton Green Exige with Komo-tec 280S Photo Gallery : http://s229.photobucket.com/albums/e...omo/?start=all Modification List : http://s229.photobucket.com/albums/e...SIMONLAU-1.jpg |
#568 (permalink) |
Elise Driver
![]() Join Date: Apr 2008
Simon
I would say you do not have to put the alum angled spacer in there for the cable bracket, but it is made to make the cables at a better angle and should have smoohter operation for it. If you can put it in you should. On the notchy feeling. I would try to make sure you adjust the rod end at the console side for the crossgate lever. Try another turn in and it my solve the problem. If it feels notchy going into 5th gear that will help and make it feel good and smooth.
Trueleo LETSLA 2005 Elise-LR,SP,HT,T, Trueleo LETSLA, Exige side scoops and grills, Stage II exhaust, FF splitter, Air2Gel seat foam, Stripes, Eliminator, Future- TVS SC kit, Fidanza flywheel, ACT HD, Custom SC headers and exhaust, SS valves, Ti Retainers, |
#569 (permalink) |
shifter
hi troy
so far the shifter feel is excellent. on 2nd shortest setting for shifter cable and 3rd setting for the other cable. fine adjustments done so far so good have not installed the rectangular adaptor plate yet will update on progress best Simon
#570 (permalink) |
Hello.
I'm now installing the Letsla kit V2 on my 08 Exige and have a few questions: Cable length: I'm confused about the number of turns that the cables must enter into the rod ends at the gearbox side. I did the following: I fully screwed the locking nut on each cable, then fully screwed the rod end on the cable until it reaches the nut. Then I unscrewed each rod end by 5 full turns as explained n Troy's instructions. Is this correct as I saw for the Crossgate that it should by unscrewed by 2 turns and not 5... Can I have more explanations please? ![]() Shifter movement I have seen a table comparing the shifting length of the stock install VS the Letsla install with the default setting. Did anybody measured these lengths with the different Letsla settings? Shortest throw I have read that the shortest throw required more force for shifting. Does that mean also that it might break the cables easier??? What are your recommendations for the rod ends hole position for both cables? Is the default position (2 for shift, 3 for crossgate) ideal? Console fine adjustment I have read the threads for the crossagte adjustments, that is clear. What about the shift cable adjustment. Does it need to be adjusted? What will this influence? Thanks for your help! ![]() François |
#572 (permalink) |
Elise Driver
onthebeach. I have answered through email, but I will post it here also for anyone else that needs it.
Cable Length- On the bellcrank turn in all the way and then out 5 turns. On the crossgate you can turn it in all the way and then out 2-5 turns. You will also have to adjust it at the console, but sometimes you can get lucky with the cable length and 1st-2nd and reverse will be right where they need to be, but usually it takes a turn or two of adjustment to make it work just right. Shifter movement. The farthest setting is basically the stock location. The shortest is a little less than half, but I have not measured specifically before and after. On the next install I will try to remeber to do this. Console- On the forward back 1-2, 3-4 and 5-6 shifting you do not have to adjust it up front. If you do it will move the shifter closer or farther from you and if you like it one way better then the other then go for it. I did mine a tiny bit to be closer to me, but I am a shorter person so closer to me and the steering wheel seems to fit me better, but everyone is different. On one other note I have come out with a new longer cable mounting bracket for those that want to keep the stock throw and it is really nice. I have used it for a few months and like the feel of it. I will put details on my site over the weekend once I get time. Troy
#573 (permalink) |
I don't get it.....the oem shifter has never been a REAL issue.
The REAL issue is the weak motor mounts. -Robert
Elise'06ST:[size="1"]RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi-Nitron sportpro-RTVbrace-widened undertrays-VF2 -manly's inserts-engine damper
#574 (permalink) |
NOT the Stig
The oem shifter is an absolutely flacid slopfest. The LETSLA provides positive engagement. I love it and I don't have to add stiffer mounts that inevitably transfer vibration to the cabin. Still considering a ForcedFed damper though.
#575 (permalink) |
My FF damper arrived today, I'll let you know what I think if you like.
2006 111R Elise,VF stg 1 supercharged,HIDs,Harness bar, LETSLA,Nitrons, Ferodo DS 2500,FF engine damper. Saikou Michi catch cans.Toyota MWR Transmission Lotus 6-spd 3.9:1 LSD Uprated clutch. |
#576 (permalink) |
Serial Thrilla
Love this product. Shift feel is fantastic. I didn't do the install myself, so I can't speak to ease of installation.
If you don't already have this product, you should get it!!!
05' Elise - BWR supercharger, Quaife LSD, Nitron Race Triple Adjustable, LETSLA, Larini Decat, Larini Exhuast, ACT HDSS, Fidanza flywheel, V2 Fuel Tank, V2 Steering Arms, BWR sway bar, desnorkled, ForcedFed CF splitter, Manly's engine mounts, S111 harness bar, Schroth harness w/ S111 seat grommets, Oil Drain Valve, Painted Black Diffuser, Braille battery, Custom Battery Switch 05' Corvette - Z51 Convertible - 630hp 6.6L [DON'T YOU JUDGE ME!!!] (SOLD!) |
#577 (permalink) |
NOT the Stig
Yes please - I assume you already have the LETSLA installed? I can't help but think that finding 2nd and 3rd when downshifting into a corner wouldn't benefit from this.
#578 (permalink) |
FF engine damper
I finished installing the FF damper a couple of hours ago and have taken it for a drive. It does transmit more vibration than without it.(Next Morning) I have just refitted it with the unit being tight but 'passive' I had to enlarge one of the top mounting holes so the unit was not under compression in a static state. Now it idles with no more vibration than stock.VERY HAPPY.
I don't think engine movement has a great effect on gear changing as the cables are fixed rigidly to the gearbox and so move with the engine.
2006 111R Elise,VF stg 1 supercharged,HIDs,Harness bar, LETSLA,Nitrons, Ferodo DS 2500,FF engine damper. Saikou Michi catch cans.Toyota MWR Transmission Lotus 6-spd 3.9:1 LSD Uprated clutch. Last edited by RichardNHCooper : 10-02-2009 at 06:28 PM. |
#579 (permalink) | |
#580 (permalink) |
#334
Installation questions
OK, so I think I have it installed and adjusted properly, but...
In Section B. of Troy's LETSLA Installation procedure for the 2nd generation kit, he says "The bellcrank will still need to be unscrewed 5 full turns to have the clearance for the sheath protector." What does this mean? How does one unscrew the bellcrank--isn't the bellcrank the L-shaped aluminum lever? I had extra parts left over Please see the photo below and give me a hint as to what they are and where they go.Thanks, Joe |
