Loose shifter ball joint? (w/video)
Hey all,
Went to do Stan's shifter mod and s111 re-Enforcer today and noticed something a little off when checking the angles of the shifter cable sockets (both seem off to me). I'm thinking at one time the shifter may have been hit by something, bending the tab the ball joint is mounted to. I took a video to try and illustrate what I'm talking about: I have never seen any others in the person, and I couldn't be sure just looking at static pictures. Any insight would be greatly appreciated. -Blake |
| Sponsored Links | |||
Advertisement | |||
Painful Novice
On my shifter, the ball for the ball joint fits firmly in the cup *and* (most importantly) the ball does not wobble around on the plate. It looks like the ball is not properly secured to the plate.
Storm titanium 2005 Elise with carbon fiber spoiler, BWR sway bar, BOE toe links, gPan2, LidBone, sector 111 wheel studs, Grey RAC Monolite wheels with toyo R1R, Team Dynamics 1.4 with Hoosier A6/R6s, Katana2 Supercharger, ECU with 265 flash. PPE headers w/decat, CEL angle eliminator, Silent touch catback, Rear Panel Eliminator, HKS intake, V2 fuel tank, Walbro255 fuel pump. HID lights. |
#3 (permalink) | |
Yeah, that was my thinking. There is no slop in the actual cup, but the ball is definitely off. Do you remember if the metal tab the ball is connected to off the shaft is flat? Mine seems to have a little waviness to it. |
Painful Novice
I can't specifically state, but I suspect it was flat.
That ball is a swedged fit to the arm, looks like a weld would fix it, or replace the lever. I recall others had this same issue on early cars.
Sent from my iPhone using AutoGuide.com App
LZ LoLo survivor |
former Honda fan
Mine did this as well, I just pulled the shift lever out and welded it. It's an extremely overdressed joint and given enough time, I expect all of them to do this.
What's so hard about bumping the existing thread and asking for more info there? I swear to God 99% of the people on this forum think they're the first person to ever have their turn signal pop out, drop their keys in the trunk, want wider tires, wonder if these are good daily cars and on and on and on. It's starting to feel like the Bill Murray movie, Groundhog's Day, around here. 😒🔫 |
#7 (permalink) |
Thanks for the responses guys.
Looks like its time weld it up then. And just to confirm, the tab it's connected to is supposed to be flat as well right? Do you think there would be any long term problems if it were left slightly tweakedas it is? |
#8 (permalink) |
former Honda fan
^ tweaked is fine. You'll need to slightly adjust that cable end anyway which will compensate for it.
#9 (permalink) | |
While I've got the shifter out, is there any place to source the cup for the shifter to crossgate lever union. It appears as if the cup is wiggling inside the lever when the shifter is moved side to side before it actually moves the lever up or down, leading to some slop. Looked on lotusgarage and they only list the whole shifter matrix base at $1150
#10 (permalink) |
former Honda fan
Holy Jesus that's a rip, your best bet would be to bring the ball socket end into a *decent* auto parts / hardware store. It should be fairly easy to find a new metric ball socket and a corresponding ball. Then just remove the wiggly ball altogether and install the new piece. When I did mine I put a washer under the ball to add a little metal to that area since Lotus felt that 1/8" by 1/8" was plenty.
#11 (permalink) | |
#12 (permalink) |
Bumping this up to see if someone can help with this. I decided to replace the ball joints on the cable ends with rod ends, so I took the shifter out of the shifter matrix to cut the swaged fitting off the bracket. Now I can't get it back though....... Any one have experience on getting the shifter back in and clipping the little black cup onto the shifter? Definitely can't get the shifter into the position with the cup already on. It's a bit of a head scratcher.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
