J. Caesar
lsd
i notice monkey wrench racing has an lsd on its catalog for the elise....is the only time we may need lsd is on tight turns?? it doesent do anything for straight line right?
the only other mods i saw for the elise besides engine build stuff, (pistons, etc) were flywheels and clutches.... ive never noticed a difference with lighter flywheels....would it make a difference on the elise? |
elise groupie
When I lightened the flywheel on my X1/9 (1900lbs and about 80bhp), I noticed a huge difference. The car was quicker off the line. I'm sure it added more hp to the wheels because it was less rotating mass. Never dynoed it though so I cant give you real estimates. It felt a million times better too.
So in the elise, I'm sure you would feel a difference. Less rotating mass is a very good thing. Same reason to use lighter wheels.
Long live the
#3 (permalink) | |
It makes the 2zz rap up like a bike and rev matching much easier. Not roughness or starting issues.
It is removing rotating mass but gear dependant not speed dependant like wheels. Removing 5 lbs from the flywheel in 1st gear is like removing about 150 lbs of stationary weight from the car. As the gear ratios decrease the mechanical advantage also decreases. In short I have a Tom's 8 lb flywheel on my 2zz and it makes for a faster funner car. If you are doing a clutch a flywheel is a good coice to do at the same time or vice versa.
Built 2zz powered, 6 speed-lsd mr2 spyder |
Exige S Komo 280bhp
The lightweight flywheel feels fantastic in the Elise, but make sure you get a properly balanced one. Factory motorsports ones are the best, 3rd party ones have been known to blow up.
As for the LSD, I have the Quaiffe ATB unit in my Elise and it certainly aids high speed cornering. I can feel the torque transfer. It makes no difference in the straight line unless one wheel is on a slippery section.
User formerly known as tonyyoshi 2007 Lotus Exige S Aspen White with LSD, Traction Control, Komo-Tec Phase 2 280bhp and SJR Titanium Exhaust. Komo-tec Acceleration Watch Me Race |
#10 (permalink) |
The '05 MR2 spyder lsd is available as a part for about 500.00 less and is a helical lsd like the quaife.
I have had the toyota part in my car for some time. It is "invisible" until you need it. Watch the second driver of the elise in this video. He needs a lsd. The inside tire in this high speed turn ignites. http://topgear.breedbandportal.kpn.com/cars.aspx
#11 (permalink) |
I think Robert and I have the Elise roughly dialed in and it was working well at the last autocross. Except one thing. Inside rear wheel spin became more apparent. There is other ways to reduce or solve that, but number one is an LSD.
Please do not PM me. My box is full. Thanks. |
#12 (permalink) |
Most of the higher powered track cars go with a stiffer front sway bar so that in corners we lift the inside front wheel rather than the rear. Try this first as it is easier to adjust and cheaper than fitting an LSD.
#13 (permalink) | |
#14 (permalink) | |
His Impatientness
www.agentsofentropy.com |
#15 (permalink) |
I't s been about a month since I saw any talk about a factory LSD option in 05. Does anyone know if this is still the case?
Dan Parker 92 BMW 325 - JP Race Car 09 Jetta Tdi 06 Z4 M Coupe 09 Child on the way (anyone need a car?) |
#16 (permalink) |
>>>You have it in your MR2, right? Do we know that it will fit in the Elise? I don't know anything about transaxles, but in a "normal" differential, different ring gears can require different differential sizes.<<<
There are (and have been) several limited slip options that will drop right into the Toyota gearbox without issue and which are already proven in Toyota automobiles. |
#17 (permalink) | |
#18 (permalink) | |
#19 (permalink) |
Edited because my gut reaction was a snide remark.
Where are the gear specs for the elise? The "european" gt-s 6 speed? I bet a fat steak dinner that they are one in the same. ![]() FWIW I have the gt-s tranny with these gears 3.166 2.050 1.481 1.166 0.916 0.725 F 4.529 This is the best list I have seen. http://www.spyderchat.com/phpBB/viewtopic.php?t=144
Built 2zz powered, 6 speed-lsd mr2 spyder Last edited by LittleRocket : 11-30-2004 at 10:38 AM. |
#20 (permalink) | |
One thread. Randy even mentioned it in this thread:The engine will be the Toyota engine and tranny used in the Celica GTS. It will be tuned by Lotus to put out 190hp and with a higher 8500 rpm redline. The 6 speed tranny will be the one use in the European Celica. It been referenced many other times. Basically the Euro spec Celica GTS gets a closer ratio transmission than the US spec Celica GTS.
