Old 10-19-2009, 09:01 AM   #1 (permalink)
2007 Exige S
robains's Avatar
Moroso oil pan & helicoil repair :(
Guess I've been working out at my gym too much lately, but I successfully stripped the threads on my Moroso oil pan drain plug during an oil change. I'm going to apply a helicoil repair on it, but wasn't sure what size kit to get.
If anyone else has made the same mistake as I , and repaired it with a helicoil kit, could you let me know what size kit you used?
Thanks, Rob.
Old 10-19-2009, 09:13 AM   #2 (permalink)
Lotus Service
twaszak1's Avatar
I have been found guilty of the same thing at one time. I used what is caled a "Time-Sert". They are much better for oil pan repairs, but a bit more pricey. 1/2x20 is the size.
T.J.
twaszak1 is offline   Reply With Quote
Old 10-19-2009, 09:27 AM   #4 (permalink)
2007 Exige S
robains's Avatar
Excellent, thank you sir, I'll try to find a local source.
What length 1.0 "?
Rob.
Old 10-19-2009, 09:41 AM   #5 (permalink)
Lotus Service
twaszak1's Avatar
on the link under drain plug, it has the first option as 1/2x20 for alluminum oil pans. that is the one. I measured the one I have and it was around 5/8" long.
Old 10-19-2009, 10:57 AM   #6 (permalink)
happy motoring!
Walnuts's Avatar
Might I recommend a ball valve drain plug to replace the bolt-like one that's in there? In this case, you'd not have to worry about pulling the drain plug again. Quick Oil Drain Valve You'd get the one for the Celica and it works like a charm. Its a spring loaded lock mechanism and is even more secure thanks to the undertry making it virtually impossible for anything to hit it.
~Rich
2006 Lotus Exige: GG
Walnuts is offline   Reply With Quote
Old 10-19-2009, 11:13 AM   #7 (permalink)
Lotus Service
twaszak1's Avatar
the drain plug on the moroso is a different size than the one for the stock pan, but if those valves give tread and pitch, he has that info.
Old 10-19-2009, 11:31 AM   #8 (permalink)
Casey's Avatar
I would suggest a better fix than a helicoil. Take the pan to a welder and have a male -8an bung welded to the drain plug boss and then just use a -8an cap for the plug.
Casey is offline   Reply With Quote
Old 10-19-2009, 11:55 AM   #9 (permalink)
2/3 hp to the paws.
Simba's Avatar
Yup. Weld a bung. Helicoil will not seal properly.
Old 10-19-2009, 12:25 PM   #10 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
weld in a bung then install a fumoto valve....then dont worry about it again. QuickOilDrainValve.com - the best way to change oil
edit: just noticed walnut suggested the same. I also use the one with a nipple so that I just reach in there and slip a hose on then open the valve and can drain the oil without removing the undertrays.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is online now   Reply With Quote
Old 10-19-2009, 12:31 PM   #11 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
Is there a version of the fumoto valve that fits the Moroso pan as is?
Old 10-19-2009, 01:02 PM   #12 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
maybe. dont know what it is though.
Old 10-19-2009, 01:42 PM   #13 (permalink)
tomrev's Avatar
Images: 10
Looking at thier site, it should be part#: F-101. That's the valve for a 1/2 in 20 thread size. Tom
tomrev is offline   Reply With Quote
Old 10-19-2009, 01:46 PM   #14 (permalink)
apk919's Avatar
Images: 20
Thanks! Is it confirmed that the Moroso plug is 1/2x20? Anyone?
Old 10-19-2009, 02:34 PM   #15 (permalink)
Zinhead's Avatar
I dropped an email to thier customer service this afternoon to find out what the bolt was. Lets see if they reply.
Zinhead is offline   Reply With Quote
Old 10-19-2009, 03:36 PM   #16 (permalink)
Frank Amoroso's Avatar
Hey Shinoo,
You guys should consider this for the oil pan you're developing!
Frank Amoroso
Whatever Press Vehicle(s) I'm driving this week
www.twitter.com/famoroso
Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it?
Frank Amoroso is offline   Reply With Quote
Old 10-19-2009, 08:27 PM   #17 (permalink)
2007 Exige S
robains's Avatar
Taking Casey's suggestion of welding a AN bung and cap -- have a friend that can do this for me, just need to pull the pan -- ugh -- not really a difficult job, just messy and a pain to scrap all the existing sealant off both surfaces.
Since I'm there, I'm looking for an new O ring for the oil line/filter sandwich plate -- anyone know where I can get one quick? As in by Thursday (10/22) since I'm heading out to Infineon on Sat/Sun to run with NASA TT group.
Thanks for all the help and suggestions folks.
Rob
