Old 06-12-2009, 10:18 AM   #1 (permalink)
Professional Fat Kid
NHG35GUY's Avatar
My Monkey Wrench experience
Huge props to the guys at Monkey Wrench racing. I needed cams for my 2005 Elise as the factory cams were wearing prematurely. Once a closer look at the cams and rockers was available, it was noticed that the rockers needed to be replaced too. With short notice, Monkey Wrench was able to get rockers out the Guys at Synaptic 3 for install. There was a small snafu with a shipping mistake, and Greg took care of it immediately! They are on their way to be installed!
FREAKING AWESOME!
Thanks again for the quick response and help from the team at Monkey Wrench Racing! I can't wait to drive the car with the new Piper Stage 2 cams!
Oh and if you have a 2005 and have not checked your cams. you prolly should and soon. It's worth the piece of mind to know if they need to be replaced or not.
NHG35GUY is offline   Reply With Quote
Old 06-12-2009, 10:26 AM   #2 (permalink)
insert clever title here
MattG's Avatar
Images: 11
Are any changes needed to the ECU programming for use with the Piper cams?
Old 06-12-2009, 11:23 AM   #3 (permalink)
NHG35GUY's Avatar
No, the Stage 2 are supposed to work just fine with factory ECU.
Old 06-12-2009, 11:27 AM   #4 (permalink)
So glad we were able to make it happen for you. I think the label went on the box literally 2 minutes before the truck was here to pick it up. Have fun out there with the new cams!
>replaced or not.
Definitely. The replacement cam/rocker kit is very inexpensive and even pretty easy to install. If you let the stock cam and rockers go too long you can get in to problems with debris or even failure of the rockers. Don't trash that engine over something simple like this.
Monkeywrench is offline   Reply With Quote
Old 06-13-2009, 03:00 AM   #5 (permalink)
shadowhusky's Avatar
How many miles did you have on you car when you had the cams replaced.
2005 Elise, Aubergine, Touring Pack, Sport Pack, Hardtop, Quicksilver Exhaust, Cup Air Box, Tilting Clam, Mesh Grills all around - ( fabricated, not purchased ) 55w 6000k HID's, Painted Engine Covers, Center Console, A/C Surround, Polished Shifter Arm, Ball,and E-Brake Handle, Multivex Mirrors.
2008 Jeep Liberty, Jeep Green Metallic
2002 VW Jetta TDI, Metallic Blue, Daily Driver, 155,000 miles and going strong
shadowhusky is offline   Reply With Quote
Old 06-13-2009, 04:08 AM   #6 (permalink)
Yeti's Avatar
What keeps the new cams and rockers from failing?
Yeti is offline   Reply With Quote
Old 06-13-2009, 05:10 AM   #7 (permalink)
NHG35GUY's Avatar
The car has just under 9k miles on it. They were checked and the number 3 lobe on the intake side I believe was in really sad shape with varying amounts of bad wear on other lobes.
Old 06-13-2009, 07:14 AM   #8 (permalink)
Elise Driver
kmt63's Avatar
Images: 2
has there been some sort of a fix for the cam spray tube?i remember seeing a long thread about it.i dont remember if there was a fix for it though.problem being the way the factory punches holes in the tube.it would spray oil to the side and miss the cams.
rls west~nci motor sports fabrication
kmt63 is offline   Reply With Quote
Old 06-13-2009, 09:08 AM   #9 (permalink)
Resident Drunk
zygotesoup's Avatar
I also had a great experience with MWR with this same cam issue...
Great experience w/ Monkey Wrench Racing
Yeti - The 05 cams had a hardening issue from the factory, the new cams that you replace them with have had this issue resolved in the manufacturing process.
I agree that anyone with an 05 or 06 should definitely pop the valve cover off to take a look at the intake camshaft, it only takes about 5 minutes. Me and a friend did the install ourselves, fairly easy if you have the right tools and know how.
2005 BADA55 Lotus Elise
1993 Black BMW 325i
2000 Solar Yellow MR-S - SOLD
1987 White on White Porsche 944 Turbo - SOLD
1993 Maroon Lexus SC400 - SOLD
zygotesoup is offline   Reply With Quote
Old 06-13-2009, 09:22 AM   #10 (permalink)
Yeti's Avatar
I've checked and I have a bad cam. I'll have to give Monkey Wrench a call next week.
Old 06-17-2009, 12:30 PM   #11 (permalink)
Yes, it's a defect with the pieces installed in those 05 and 06 cars from the factory. The cams are not hardened properly and start to wear which messes up their surface finish enough that they also eat the rockers. The replacements are properly heart treated and won't fail in the same fashion.
Old 06-17-2009, 01:28 PM   #12 (permalink)
Resident Drunk
zygotesoup's Avatar
what cylinder?
make sure you get new rockers too
1993 Black BMW 325i
Old 06-17-2009, 02:03 PM   #13 (permalink)
Yeti's Avatar
#3, talked to MW. I am going with a whole new head.
Old 06-17-2009, 02:08 PM   #14 (permalink)
intofx's Avatar
Images: 14
Is there a VIN range/build date for cars with an issue? My car runs great but is there any way of knowing (symptoms) you have an issue without visual inspection?
Matt
2006 Phantom Black Exige
2004 Porsche C4S
2007 Black Hummer H2 SUT
intofx is offline   Reply With Quote
Old 06-17-2009, 02:09 PM   #15 (permalink)
Resident Drunk
zygotesoup's Avatar
why?
I assume this has something to do with the "gravel" noise you were hearing?
1993 Black BMW 325i
Old 06-17-2009, 02:11 PM   #16 (permalink)
Resident Drunk
zygotesoup's Avatar
Matt
I've heard you can do an oil analysis, but I would say the quickest, easiest and cheapest way to know for sure is to remove the valve cover. Again... 5 minute or less job.
1993 Black BMW 325i
Old 06-17-2009, 03:55 PM   #17 (permalink)
Yeti's Avatar
I am figuring that replacing the whole head is the easiest solution to the cam problem. I am shooting for reliability at this point. Since I've seen several positive threads like this one about MWR, I am willing to spend the extra money to do this as insurance. I'll worry about more power when my driving skills catch up to what the car has now. That may never happen...
Old 06-18-2009, 06:46 AM   #18 (permalink)
NHG35GUY's Avatar
I hope to have my car back tonight. I will post pics of the worn cams and rockers. I can not express how important it is to get this checked if you have a 2005 MY car.
Old 06-27-2009, 05:21 PM   #19 (permalink)
NHG35GUY's Avatar
Guys, I have posted pics here of the cams: Shout out to Synaptic 3 / Piper cam install
