| View Poll Results: First batch Color | |||
| Red |
47 | 25.97% |
| Orange |
14 | 7.73% |
| Yellow |
20 | 11.05% |
| Green |
7 | 3.87% |
| Blue |
11 | 6.08% |
| Clear |
7 | 3.87% |
| Black |
75 | 41.44% |
| Voters: 181. You may not vote on this poll | |||
#203 (permalink) |
New and Improved!
Payment sent for red ones...
2006 Elise - Chili Red - VF Supercharged and Intercooled Stg 3 - Custom tuned by CharlieX - 2.9" Pulley - Walbro 255 - RC 550cc's - Black Badges - Red Inserts - Grey RAC Monolites - Toyo R888's - South Bend SS-TZ - Fidanza Flywheel - FF CF front spoiler - Craftsquare CF Mirrors - Reverie CF Diffuser - 5" 2bular Ultra - PPE 4-1 FI Header w/ Decat - VonHep Rear Panel - Innovate XD-16/LC-1 - Mr.C Radar Mount - Clutch Travel Mod - Shifter Bolt Mod - re-ENFORCER - A/C Panel Mod - Odessey PC625 |
#204 (permalink) |
Keep it simple and real
Installation and test drive comments
All in all, installing the engine mount inserts is a straight forward, low mechanical skill job that requires some time and patience because of the fiddly bracket base bolts. Having good ground clearance to work under the car and good tools will simplify matters.
![]() The inserts are well made. I expect they will be as durable and have a lifespan comparable to high quality chassis and suspension bushings (time will tell). ![]() The installation took a lot longer than 1/2 hour, which I fully expected. It took me about four hours including time to raise the car onto ramps for work clearance, remove the diffuser and center panel, fiddle with the hard to remove base bolts that attach the front bracket to the engine and rear bracket to the transmission, install the engine mount inserts, put everything back together, and put away my tools and ramps. ![]() In test driving, there is additional and noticeable vibration that can be felt in the seat and seen in the door mirrors as they vibrate ever so slightly at idle. The overall feeling is that the engine is hard mounted to the chassis (kind of reminds me of my Morgan +8!); the engine / drivetrain feel less dampened and more rigid, because they are. Shifting is a lot more precise under hard acceleration and decceleration. This is a good thing and will be appreciated during track use. This mod compromises comfort for the sake of improved shifting precision, improved drivetrain stability, and marginally improved chassis stability and handling in transitional situations. ![]() Overall, I would recommend this mod if your car is used on the track, autocross, or otherwise driven hard. The engine mount inserts result in the car feeling like it has a hard edge to it. My car is used on street as well as the track, and I am pleased with the benefits this mod provides. Though, I have forewarned my wife for when she drives it so she doesn't think something is wrong. I would not recommend this mod if your car is used mostly on the street or as a daily driver, because the additional vibration at idle and hardened feeling of the chassis may become annoying. This is a mod the passenger may not appreciate unless he / she is a hardcore car enthusiast. ![]() ![]() A Big Thanks to Manly for his initiative, being innovative and providing the Lotus community with a cost effective and sensible mod! ![]() ![]() P.S. The red ones will make your car faster! ![]()
'06 Exige - Ph. Black/Touring/Track/LSD/TC/SS. Mods: X balanced - RTD brace - Manly inserts - decambered - Pagid Blacks - Motul fluid - tow hooks - Schroth belts - extinguisher - Green Filter - Larini - oil temp & pressure gauges - gPan - wheel studs & lugs - AO48s & Rotas on track - T1Rs & OEM wheels on street - rear camera & monitor - Stebel horn - speakers upgraded, sub & iPod controller - DRL disabler - aux. fuse panel - sill pockets - leather console - Bootie - roof scoop functional. |
#205 (permalink) |
Legend in my own mind
Installed in approx. 1-hour. Good project to knock out same time as changing oil. Vibration is noticable when idling, but no different than stock while driving. Thanks Manly!
06 ST Elise, BWR Supercharged with lots of other stuff 01 Birkin S3 Super Sport (Lotus 7 replica) 99 Miata Sport |
#206 (permalink) | |
LOL I'm speechless. That is just way extreme dude. I hope you drive a little faster than you wrench. hehe. j/k I'm happy to hear you guys are happy with the mod. ![]() My first time doing the install took me just a little short of an hour because I did not have any instructions at all. After the first time, it only takes me ~30mins. Since I provided all the instructions, I was expecting most can do it around ~30min range. and ~40min with RTD brace. My approx install time: 1) backing up the car onto ramps: 2 min 2) removing undertray and diffuser: 5 min (I have a cordless driver) 3) Front lower mount remove and reinstall: ~5 min (only three bolts) 4) Rear lower mount remove and reinstall: ~10 min (RTD brace add ~10min) 5) Reinstall undertray and diffuser: 5 min 6) drive the car off the ramp 2 min No more loose or broken exhaust, improve shift accuracy, and improve throttle response...priceless. ![]() ![]() ![]() yup, you will notice slightly more vibration when the car is at idle only. Once you give it a couple hundred revs, it feels stock vibration-wise.
http://www.trackHQ.com |
#207 (permalink) | |
I don't think you will ever need replacements. But yes, I can send you a new one if one does break.
#208 (permalink) | |
2) No, it is a lotus. I don't think the noises you are referring to comes from the engine bay.4) no, only have to remove the undertray and diffuser.
#209 (permalink) |
I have no doubt it can be done in 1/2 hour.
Where I lost a lot of time was with removal of the lower bolt on the front mount, where the bracket attaches to the engine, and removal of the upper bolt on the bracket that attaches to the transmission. ![]()
#210 (permalink) |
If you just upgraded ONE of the two mounts, would there be less vibration at idle, but still some reduction in engine movement? Sort of for occasional track days? Just a thought, although I guess no one has tried this. Possibly I will.
#211 (permalink) |
Hmmm...all these reports of vibration at idle.... this is why I was asking about this before, and it is why I waited to install mine to see what others reported.
Sounds like the vibration is a bit harsher than the website let on, if the mirrors are shaking. I am about 80% daily-driver/20% track. But I don't mind a few compromises to enjoy performance. Shaking mirrors may be a bit much. At least it is a reversible mod. Unfortunately it'll be a couple weeks before I get to the install. But I'll give it a shot, and see what it feels like. I just remember my buddy's Neon R/T long ago, when he installed engine mounts. It literally felt like the engine was bolted to the interior. It was almost painful after a while. I remember he used a fairly aggressive mount/bushing upgrade. I was hoping the kit offered in this thread was a bit less aggressive. I guess we'll see. So if folks who have installed so far had to rate the vibration, how would you rate it on the scale below: 1 (barely noticeable) - - - - 5 (mirrors and eyeballs shake) - - - - 10 (teeth shake, feel it in my skull) My friend's Neon was a definite 10 in the harshness dept. Where would folks place this bushing mod in terms of harshness/vibration intensity? Thanks
-Smoky '07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, 2Bular 8x24, ACT XTSS Clutch, Fidanza Flywheel, S111 RTD brace, S111 Ultra Discs, rls Intercooler, Goodrich S/S brake lines, Innovative engine mounts, Valentine 1 |
#212 (permalink) |
Don't worry about the vibration. It just feels different than stock - in a good way. On Smoky's vibration scale, I'd give it a 4 (eyeballs don't shake).
#213 (permalink) |
+1 for the "4"...slight vibration in side mirror but no eyeball issues.
#214 (permalink) |
06 S280
I'll see if I can tell a difference tomorrow. Just put them in today. Only took an hour and a half. Most of that time was crawling back out from under the car to get the correct sockets.
Seriously, who uses a 15mm on anything?!?!? ![]() Thanks for the quick shipping though, got here very quickly. |
#215 (permalink) | |
New and Improved!
#216 (permalink) |
06 S280
I can come by and show you how to do it.
The sweat will be yours though. heheReally not that tough though. I'll be happy if it stops the flex enough that my stage2 stops hitting my PPE headers. At least until my 2bular gets in. Really don't want to swap back to stock headers and cat for the sept 6th MSR event... |
#218 (permalink) |
Exige Cup 255
Location: 33.87°S 151.21°E Car: ロータス MKII エキシージ Type: Komo-Tec S300
Engine mounts are the way to go to ensure you properly reduce engine flex/movement. Torque dampers are more a "secondary/bandaid" solution, ultimately, it's the mounts that carries all the load.
#220 (permalink) |
(Formerly PESTODUDE)
I have the ForcedFed dampener. At Butonwillow two weeks ago we did some unscientific testing between my car and a car with these mounts and there was significantly more engine movement in my car. I plan to switch out my dampener for the new mounts.
Randy Modified |
