#101 (permalink) |
My ECU made it back from PES this morning and my mechanic got it installed this afternoon. My install was a clam off installation by a master technician who is not familiar with the Elise. He was extremely impressed by the detailed instructions/photos that came with the kit. He got enough of it put together that I was able to take a quick test drive before quitting time and I was very happy with the initial results; I'll have the "after" dyno done next week once I get a chance to put a few miles on the car.
Regarding the ECU turnaround time, I shipped mine out last Friday to PES and it arrived there at 9:00 a.m. Tuesday. They shipped out the reflashed ECU sometime yesterday (Thursday) via overnight and it arrived this morning at 10:30 a.m. For some reason, I expected that PES would be able to accomplish the reflash and ship it out the same day, but I'm sure they are dealing with a lot of volume from the group buy hitting all at once. Thumbs up to Fred and BWR for a nicely engineered kit!
2006 Elise British Racing Green; LSS, LSD-TC, 2bular exhaust, Blackwatch Racing front bar, BWR Supercharger |
#102 (permalink) |
Selfish Asshat
That is exactly where it seems to occur. I will put some miles on the car this weekend (tonight and tomorrow morning) and see. If it does not go away I will go get some racing fuel and see if that makes a difference.
Thanks
2006 Exige StormTi, BWR S/C, Nitto NT-01's (love em) 2005 Stealth Focus Midget (3 of them); 2001 Ocke Mannerfelt B-24 "Batboat" 2007 Honda S2000 (wifes car), 2003 Insight (commuter), 2000 Ford Excursion 2004 Meridan 411 and 96 SeaDoo Speedster boats 2004 Newmar Kountry Star RV and various racing karts and snowmobiles www.capitalcitymidgets.com |
#104 (permalink) |
#92
That is where I'm at now. Nothing broke yet!
I have a question, are there better air filters out there that I will simply fit in the air filter box? The one that I took out looks cheap. If so, will they affect the s/c? How about the ECU? Rick
2005 Solar Yellow Elise touring package, sport package, star shield, hard top, soft top, K & N air filter and BWR Supercharger, with PES reflashed ECU 2001 Green Toyota Tacoma, 4 x 4 2008 Red 5455 Massey Ferguson, 4 x 4, cab, ipod 2001 Yellow Cat D3G-LGP, custom made beer holder |
#105 (permalink) |
El Jefe - Agent 111
Look at the Green Filter as a simple drop in. Should not be a problem.
* V E R I T A S * A E Q U I T A S * We have been feeling the buzz since 2002 2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds. ..is a stranger in an open car. Tempt you in and drive you far away |
#106 (permalink) |
2008 XP National Champion
The points that CharlieX makes are all excellent, thanks CharlieX!
Additionally, we've done extensive testing and I want to point out something we've discovered. It is CRITICAL that anyone installing ANY supercharger kit inspect & test and/or replace their mass-air sensor element. We've seen that the mass air sensor element can get very dirty(remember in the lotus much dirtier air hits the intake than a car with a front intake.) and this dirt will cause the mass-air sensor to read low(Its a fairly linear change). Aftermarket intakes, higher mileage cars, and cars operated in dustier or dirtier conditions are even more prone to this. This will cause the ECU to think more air is entering the engine than reality you will have a potentially dangerous lean condition! You can test the mass-air sensor with a scan tool by having someone monitoring the mass-air sensor while you drive WOT in second gear. You should see 225-230grams/sec at above 8200rpms. If you see much less than this you should replace your mass-air sensor element. These new mass-air elements may not survive harsh chemical cleaning and should just be replaced.
2008 X Prepared Solo National Champion |
#108 (permalink) |
Legend in my own mind
Supercharger installed. Engine fired right up and runs very smoothly. CEL is on but figure it will go out after I drive it for a while. Double checked all connections and everything is secure. No peculiar sounds or leakage.
I haven't driven my Elise hard yet, but on my test drives, it pulled very well under light acceleration. Is it safe to assume that the CEL light will eventually go out if everything is in place?
really cool 2006 ST Elise
#109 (permalink) |
disproving HD MTBF daily
if its a flashing light, don't ignore it find out what it is, if its steady its an emissions warning and it'll go away if the problem has been fixed, i send out my 06s usually with a setting that resets the ecu back to factory for when you first start it, this helps the adaption set quicker, this causes a steady light for the first few starts, but it goes away.
if its a really bad problem the engine will limit to 6000 RPM. usually its the cat, gas cap, 06's onwards, the ecu being reset. With the bad MAF's it also helps if you can datalog it , the elm scanners that go to laptops can do it, most of hte cheapo hand helds don't though. A working MAF will have a nice bell curve, a bad maf is jumpy and it causes the car to hop a bit, this is because its looking in the wrong spot for fuel/spark while its accelerating, AF's will hop around rather than go from a linear 14.6, 13.5, 13.1, 12.5 , 12.1 at WOT (depending where its set) The K&N intake kit works well and closely matches the stock box.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it. |
#111 (permalink) |
Selfish Asshat
Mike,
Mine was on as well, went off after the third time I shut the engine off. The detonation has gotten better as I drove tonight. Tomorrow I am going to change the mass air sensor element (provided I can find one) just to make sure. Does anyone have the part number for the mass air sensor element? Is it a Toyota part? Same with the air filter, is it a Toyota part? Thanks
#113 (permalink) |
I'm thinking that I am going to do a clam off install so that I can remove the air conditioner unit at this time. Has anyone done this? Any thoughts? What size belt would I then need to go with?
2005 SY-BWR Supercharger, Challenger Grill, Arqray single tip exhaust, Ohlin Double Adjustables, RTDbrace, Multivex mirrors, Odyssey PC625 battery, Micromirror, HID's |
#114 (permalink) |
Got just got my alternator moved. I believe I am going to take a beer break.
#115 (permalink) |
Selfish Asshat
Rick,
It is all downhill from there. Congratulations! See and you did not think you could do the install. Rick
#116 (permalink) |
I got the s/c attached last night. I think the biggest problem I am having is the wiring. The new extention wiring for the alternator seems to be a little short. It reaches but there is not a whole lot excess length. I am heading back out there to do another 15 - 20 numbers!
#117 (permalink) |
+1 re: MAF. Make sure it is clean.
Also, the alternator goes in much easier when you make sure you have pushed the bushings in the front cover totally flush and removed the paint on the ends of the alt bracket where it meets the bushings and alternator. It is only a few thousands of an inch but makes a HUGH difference. Have fun!
2005 Bordeaux Met #21 (HT, Touring, Quicksilver ext, TRM F1 wheels, Stan Stud, HID lights, BWR S/C,Filled motor mounts, catch can) 2004 Audi S4 Sedan (Tip, GAIC Chip, AWE Cat-back, Team Dyanmics Pro 1.2 wheels) 2002 F-350 (Powerstroke, 4x4, Banks power pack, 6th alternator) Couple nice bicycles, way too many snow skis. |
#118 (permalink) | |
I've seen a vacant hole in the roll bar situated below the oem 3-point seat belt hole. -Robert
Elise'06ST:RAC-Girodisc-Larini 8"-Zoom-Braille-Reverie intake-raceview-Saikou Michi-FFengine damper-Nitron sportpro-RTVbrace-extended undertray
#119 (permalink) |
I am done!
![]() ![]() Now I'm just waiting on the ECU. I sent it off Friday, and with Monday being a holiday, I assume it will get there Tuesday. Hopefully I will get it by Friday. Installing this s/c was not near as hard as I figured it would be. Doing it with the clam off helped, although it was definitely more time consuming. I'm going to keep my fingers crossed when I hit that start button. Rick
#120 (permalink) |
I've officially begun installation - No turning back now-
I noticed a baseball-size hole in the box, and I want to be sure I have everything: SC small carboard box installation instructions Is that right?
Grab Life by the Wheel |
