Old 09-27-2008, 07:35 PM   #1 (permalink)
2009 XP National Champion
fzust's Avatar
'Official BWR SC Install Thread'
Ok, it has been suggested that I setup this thread for folks to share ideas, post questions etc. etc. Please keep it constructive, no flames please. The instructions are pretty thorough. I highly recommend taking a laptop into the shop/garage and use that for the pics. Each pic is numbered and corresponds to a step in the instructions. Pretty easy.
Old 09-27-2008, 07:43 PM   #2 (permalink)
BANNED
I did a BWR install on an 06' Exige. I know the instructions are on an Elise so if you have any Exige specific questions let me know. Remember to disconnect the remote trunk release before you try and pull the clam off for instance.
That being said the install photos and instructions are awesome! Fred also answered any of my questions directly and promptly.
Good luck new BWR owners!
mpsalm is offline   Reply With Quote
Old 09-28-2008, 06:41 AM   #3 (permalink)
thegoat's Avatar
How long does it take to remove the rear clam on the exige, and would you remove it again if you were doing the install again?
Also, are there any fitment issues when replacing it? I am afraid that I will create a new squeak after removing and replacing the clam because it not would be perfectly aligned to factory specs or something like that (yes, this is a question that comes from never having removed a rear clam).
fzust, thanks for setting up this thread.
2009 White w/ Carbon Birkin Super 7 (on order)
2001 Silver Honda Civic Ex (daily driver)
2006 Polar Blue Exige - Sold
2006 Chrome Orange Elise - Sold
2000 Porsche Boxster - Sold
thegoat is offline   Reply With Quote
Old 09-28-2008, 06:50 AM   #4 (permalink)
G-200 Driver
kestrel74's Avatar
Insert Tab A into Slot B..............then turn to page 2.
Old 09-28-2008, 07:55 AM   #5 (permalink)
fzust's Avatar
Ultimately the rear clam sits on shims in the back that are taped in place. It is pretty straightforward to re-align. I think on an exige, your life will be alot easier to install with clam removed.
Old 09-28-2008, 08:42 AM   #6 (permalink)
BANNED
Yeah I would def remove it again. It would be much faster the 2nd time. It's not very hard, a little time consuming. But you should be able to get it off in a few hours. Super easy to realign once removed. It sort of only goes on in one place... No new squeaks from the car and a few old ones are gone now. Hope that helps!
Good Luck!
Old 09-28-2008, 09:25 AM   #7 (permalink)
jim-clayton's Avatar
Get yourself a set of this handy tools.
2005 Elise Storm Titanium
Old 09-29-2008, 01:56 PM   #8 (permalink)
If you get those ratchets, make sure you get the ones with the few degrees of bend on the end, and a switch for the direction. I have a cheapo set from Costco that are totally straight and you flip over to switch directions. They suck. Luckily, those are only my English wrenches. My metrics are like the ones pictured and they are incredible.
brokenboy is offline   Reply With Quote
Old 09-29-2008, 01:57 PM   #9 (permalink)
So what about clam removal on the Elise? I know it can be done either way, and I'm not afraid of removing the clam, but does it save enough time to be worth it?
Old 09-29-2008, 01:58 PM   #10 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Debating on whether or not to remove the clam on my Elise... My hands aren't very slimy, but my buddy's are.
I'm a total mechanical novice.
Old 09-29-2008, 02:12 PM   #11 (permalink)
Overlander23's Avatar
Remove the clam if you're curious and/or have never done it before. It's completely unnecessary for the SC intall, though. Having done both, removed the clam (separate issue) and installed the SC with the clam on, I'd do it again with the clam on... err, again. But having removed the clam, for something, else gave me greater appreciation for the car.
2005 Lotus Elise (Type 25 clone, LSS, Touring, Supercharged)
1970 Austin Mini Cooper, 1971 Series IIA 88" Land Rover, 1999 Land Rover Range Rover 4.6 HSE Callaway #071
Overlander23 is offline   Reply With Quote
Old 09-29-2008, 05:01 PM   #12 (permalink)
well said +1
Old 09-29-2008, 06:34 PM   #13 (permalink)
stinkyonion's Avatar
Images: 2
So overlander23, what was the cause of your check engine light ? I couldnt find the resolution of your issue in the other thread.
stinkyonion is offline   Reply With Quote
Old 09-29-2008, 06:49 PM   #14 (permalink)
Images: 2
Why does everyone remove the diffuser plate with the car on ramps instead of jackstands? (never done it yet)
So the recommended tools for the install are metric wrench and socket sets, pneumatic wrench for loosening, torque wrenches, jack stands, jack, ramps, metric thread chasers for alternator install., protective cloth for clam, and a creeper ?
Then for the Moroso oil pan (also special discount right now on lotustalk $485 delivered) I just need some form of gasket goo like Hondabond and everything for a oil change (6 quarts synthetic 5w40, filter, oil plug gasket, teflon tape).
No other projects to be done at same time I take it. ( I really want a new intake and increased flow exhaust but it messes up the ecu program as I understand it.)
Old 09-29-2008, 06:50 PM   #15 (permalink)
BANNED
If you need a hand let me know. I'm in the city now but am in Westchester on occasion to visit the puppy.
Old 09-29-2008, 07:57 PM   #16 (permalink)
Live to Drive
THE PUPPY!!!!!!!! Thanks a lot! And let me know if I can help you as well!
Old 09-29-2008, 08:36 PM   #17 (permalink)
fzust's Avatar
You may need more than 6 quarts with the Moroso pan. Make sure you check it and don't run it low.
You are correct about the intake. Cat back exhaust is no problem.
Old 09-29-2008, 09:02 PM   #18 (permalink)
Good question... I replaced the stock air filter with a K&N (yeah, yeah I know it doesn't filter as well but I had one on a 1G DSM for 100k and the engine looked new when I tore it apart) and reset the CEL. We'll see if it comes back. I do know that throttle response is now much better, so changing the filter seems to have alleviated a possible over-rich situation.
And while a K&N may possibly not filter as well as stock, I can now hear the supercharger whine starting at around 4k on WOT... and that banshee wail is worth it. I couldn't hear it at all before. Keep in mind that a new stock replacement filter may have done the same thing... I haven't tested that.
Old 09-29-2008, 09:05 PM   #19 (permalink)
Because I like putting jack stands at the rear position for stability... which is under the diffuser. Ramps for clearance... diffuser removal... jackstands on rear crossmember/stand point.
Old 09-30-2008, 11:21 AM   #20 (permalink)
Images: 2
bought some husky torque wrenches at Home Depot today. Sears was sold out of torque wrenches. Dont know where to get other brandsexcept online with waiting for delivery. Hope the huskys are good enough for supercharger install (patiently awaiting arrival).
