Old 10-15-2008, 05:17 PM   #201 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Apparently mine is ready and can be picked up tomorrow... But I don't have a ride yet... It feels too good to be true. So good that I don't even believe it yet
Old 10-15-2008, 06:29 PM   #202 (permalink)
Mimzy's Avatar
Originally Posted by K2S View Post
Okay, I have 2 questions.
I cannot remove the shorter stud on the head in step 97. I'm using a vise grip, but all it seems to do is strip the stud. I also sprayed some WD-40, but no luck. Should I file the stud down so I can have a better grip on it, or is there a better way?
Thank You
The easiest and fastest way to uninstall the studs is to buy a stud puller kit. About $30 at advanced auto parts for the AmPro 4pc Stud Puller set. (part number T75928). I had the same problem and this got them out in a jiffy.
Mimzy is offline   Reply With Quote
Old 10-15-2008, 06:34 PM   #203 (permalink)
Legend in my own mind
MightyMike's Avatar
Images: 9
Originally Posted by Randy Chase View Post
I think most people are in some stage of installation still
I'm in the driving and having fun stage! CEL went out two days ago. No issues whatsoever at this point.
06 ST Elise
02 SLK32 AMG
BWR Supercharged w/CharlieX tune, Borla Exhaust, OCC, ACT XTSS Clutch, Zeitronix A/F Meter, LETSLA, Manly Mounts, RTD Brace, ReVerie Diffuser, Scoops, Side Skirts, & Shifter Ball, Forcefed Spoiler, & a bunch of other stuff
MightyMike is offline   Reply With Quote
Old 10-15-2008, 06:34 PM   #204 (permalink)
Doublklutch
Brikhaus's Avatar
Be ready - you are going to be blown away!
2007 Elise, British Racing Green, Biscuit, BWR SC , PES Reflash, TP, TC, Stage II, Star Shield, soft top.
2006 Audi A3, 3.2, "S" Line, Quattro,
Brikhaus is offline   Reply With Quote
Old 10-15-2008, 06:38 PM   #205 (permalink)
MightyMike's Avatar
Images: 9
Originally Posted by brokenboy View Post
Does everyone just re-use the intake manifold gasket like the instructions say? Not trying to double guess what appears to be a great kit, but this seems a bit odd based on just about every gasket I have ever worked with. I'm about to do the install tomorrow so I haven't seen the gasket yet- maybe it's obvious it can be reused.
I did. It can easily be reused. Good luck with your install.
Mike
06 ST Elise
02 SLK32 AMG
Old 10-15-2008, 08:01 PM   #206 (permalink)
Next question. when I adjusting the bushing, what is consider the inside? Am i suppose the push the bushing towards the passenger side of the car?
Thank You
Since the studs won't be reused a medium sized pipe wrench (plumbers) makes it easy. About a 10 or 12 inch one.
Yes, bushing towards PS.
vao4v is offline   Reply With Quote
Old 10-15-2008, 10:00 PM   #207 (permalink)
Check engine light
I got the ecu in the mail today and installed it. The car started fine but i have a check engine light. Has anyone else had this problem?
Orangeelise is offline   Reply With Quote
Old 10-15-2008, 10:06 PM   #208 (permalink)
Selfish Asshat
ryoung99's Avatar
I think all of us had it.
Per Charlie, as long as it is not flashing it is fine. Mine went off after a couple of cycles and a short drive.
2006 Exige StormTi, BWR S/C, Nitto NT-01's (love em)
2005 Stealth Focus Midget (3 of them); 2001 Ocke Mannerfelt B-24 "Batboat"
2007 Honda S2000 (wifes car), 2003 Insight (commuter), 2000 Ford Excursion
2004 Meridan 411 and 96 SeaDoo Speedster boats
2004 Newmar Kountry Star RV and various racing karts and snowmobiles
www.capitalcitymidgets.com
ryoung99 is offline   Reply With Quote
Old 10-16-2008, 05:19 AM   #209 (permalink)
rstutts's Avatar
Back to the MAS
My local auto parts has ordered a can of the Mass Air Sensor Cleaner, I think it is by CRC. I hopefully will clean it tonight. I guess you simply spray the probe sticking into the intake tube (after you take it out). My ECU should be back either today or tomorrow. If it starts and no leaks, I then have the chore of putting the clam back on. The local Advance has an OBDII scan tool to test the MAS. When should this be done, as it is suppose to be done while you drive WOT in second gear. I have read a numerous posts on here about breakin procedures, and running above 8200rpms seems pretty harsh to begin with. Evidently this can't be done as soon as the s/c is installed.
Sorry for always asking questions!
2005 Solar Yellow Elise touring package, star shield, hard top, soft top, ACT HDSS clutch, Saikou Michi catch cans, LED tail lights and VF II, 288 whp ()
2001 Green Toyota Tacoma, 4 x 4
2008 Red 5455 Massey Ferguson, 6 x 6, cab, ipod, GPS navigation, regular beer holder
2001 Yellow Cat D3G-LGP, custom made beer holder
rstutts is offline   Reply With Quote
Old 10-16-2008, 06:49 AM   #210 (permalink)
2009 XP National Champion
fzust's Avatar
After the car is warm etc. you can take the car up to high RPMs to check this. Just get there using less than WOT. the critical RPM range, as CharlieX mentioned, is about 4500-5800rpms. Above 6k roll into WOT and check. As I mentioned before, strongly recommended to have someone help while you drive!
Old 10-16-2008, 02:35 PM   #211 (permalink)
check engine light
Well i took the car out for a drive and the check engine light started blinking. On the lotus ecu does the blinking mean the ecu is throwing codes, if so can you read the codes by the blinking or do you need a obd2 scanner.
Old 10-16-2008, 02:38 PM   #212 (permalink)
rstutts's Avatar
Just wanted to let everyone know I go my ECU back. I put it on, put the fuse boxes back on and then put the fuel pump fuse back in. I attached the battery and went and got a fire extinguisher (I sure hoped it was not needed). I got in the car, crossed my fingers and tried to start the car. NOTHING! Then it hit me, push the starter button. The car hesitated starting for maybe 2 seconds, then purred like a kitten. I put down the fire extinguisher and looked for leaks. None! The CEL light is not even on, although it may come on. I let it idle till it got to 170, then turned it off. I was sure wanting to rev the engine, but I didn't want to deviate from the instructions. The clam will be on tonight, and I will be SUPERCHARGED! That is for sure worth 3 dancing bananas!
Once again, thanks Rick for all the encouragement!
Rick
Old 10-16-2008, 03:12 PM   #213 (permalink)
fzust's Avatar
Yes, it means you have something going on. You need a scan tool. Make sure you check all the electrical connections.
Old 10-16-2008, 03:35 PM   #214 (permalink)
check engine light
Does anyone know were i can get a cheap scanning tool
Old 10-16-2008, 05:41 PM   #215 (permalink)
fzust's Avatar
Alot of times you can go to Checker or Advance Autoparts and they will let you borrow one. They "sell" you the shop one. When you return it, they refund your money.
Old 10-16-2008, 08:06 PM   #216 (permalink)
Check engine light
Thanks. I ended up finding out it was one of the injector plugs, I pushed it in and set the ecu and everything worked.
Old 10-16-2008, 08:26 PM   #217 (permalink)
I approve this message
skibum's Avatar
Oh man - I finished my install tonight and the car started right up when I ran in to this issue:
I did a preliminary alignment of the hinges (hand tight) on the engine lid of my 06 Exige and then closed the lid to see how it fit. Now I pull the release and it won't let go of the lid. I can hear the release cable working but the lid wont budge. I had a friend wiggle and try to shake it free but nothing seems to work. I am dying to take the car out for a spin but don't want to risk it.
30 mins later - I got the lid open and can't wait to take her out.
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934#
2004 s2000 - 378 whp 295 trq
2005 Mini Cooper S
2008 Honda Fit - 35mpg y0!
1965 Austin Mini w/ vtec
skibum is offline   Reply With Quote
Old 10-17-2008, 06:44 AM   #218 (permalink)
ishur's Avatar
Well, I am up and running as of yesterday. FVMC did a neat and professional job (as you would expect), the car passed its MAS test with flying colors, and (knock on wood) everything seems to be just fine.
Between the little supercharger whine (like an eager puppy straining on a leash) and the mid-rev power that has magically appeared, the car has a very different personality. I've already put about 125 miles of varied driving on it, resisting the temptation to use WOT with great difficulty.
I think once I hit 200 miles I will be able to resist no longer...
ishur is offline   Reply With Quote
Old 10-17-2008, 07:41 AM   #219 (permalink)
jim-clayton's Avatar
I have good luck with these people.
Inexpensive OBD II Scan Tool at D.I.Y. Diagnostics.com - - - Turn off that check engine light!
2005 Elise Storm Titanium
Old 10-17-2008, 08:00 AM   #220 (permalink)
fzust's Avatar
Jim,
That looks similar to what I use; a software package called car-code OBD-2. I spent about $100, but it does everything.
