#261 (permalink) |
vv My Awesome Wife vv
On step 163, you are suppose to reconnect the black hose to the air box flapper. Where does the other end go to?
Also, I can't find the orange hose that goes to the SC TB adapter. Where is the other end suppose to go? How do I connect these back together?
2005 SY-BWR Supercharger, Challenger Grill, AreaP single tip exhaust, Ohlin Double Adjustables, RTDbrace, Custom Kirkey 58 Series seats, Schroth 6 pt. harnesses, Multivex mirrors, Odyssey PC625 battery, Micromirror, HID's, V2arms, Sparco removeable steering wheel, 15"/16" Rota's with RA-1's, Pagid RS 4-2 pads, Cup airbox, Saikou Michi catch cans |
#262 (permalink) | |
luxige
Could someone please explain my torque wrench to me?
In theory, there is no difference between Theory and Practice. In practice, there is. - Y. Berra |
#263 (permalink) |
As everyone is scrambling to answer my air box hose question, some people can answer this question.
![]() These shims fell out when I lifted up the clam (four on each side). Where were they?
#264 (permalink) |
On the road again!
All back together and works great! Only 20 miles on the install, so taking it easy, but no lights, leaks, or problems and GREAT power!
About 10 hours on the install in my garage (not including the fussing with the ECU for the re-reflash.) Fred - thanks for your help, quick response, and GREAT KIT!!!!!![]() |
#266 (permalink) |
Does someone have a picture or schematic of how the engine cover hinge is seated with the clam? A close up picture of the hinges with the engine cover up would be great.
#267 (permalink) |
I have it all together now with the exception of my ECU and this air hose configuration. Can someone answer which goes where?
#268 (permalink) |
I am not as far along as you, but when I removed the manifold, that orange tube was still attached to it. maybe this helps.
2009 White w/ Carbon Birkin Super 7 (on order) 2001 Silver Honda Civic Ex (daily driver) ----------- 2006 Polar Blue Exige - Sold 2006 Chrome Orange Elise - Sold 2000 Porsche Boxster - Sold |
#269 (permalink) |
Chotto,
4 plugs into 3 You should have a orange tube that was in the car originally, hooked to your stock manifold. That would go between 1 and 2. If you really don't have one, you just need some soft of vacuum tube to plug 'em together.
2007 Ardent Red Elise, track pack, BWR SC 2004 RX-8, 350z muncher 2004 BMW 325i, kiddie hauler |
#270 (permalink) |
I approve this message
K2S - Any pictures of the snapped stud? I assume it snapped off flush with the head, is that correct?
Are any of you getting some eratic idle patterns? I have about 60-70 miles so far and occasionally the rpms will bounce at idle and a few times the car has died while at a light.
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934# 2004 s2000 - 378 whp 295 trq 2005 Mini Cooper S 2008 Honda Fit - 35mpg y0! 1965 Austin Mini w/ vtec |
#271 (permalink) |
Okay so I'm going to the hardware store tomorrow, is there a name for the stud that goes into the head and connects the SC manifold? Maybe I could just extract the stud, and find a bolt that fits, instead of a stud and a nut?
#272 (permalink) |
Thanks Goat and Brokenboy. As soon as you said the orange hose was still attached to the manifold, I looked right above my head to a shelf I put the manifold on and it was staring me in my face!
All done. Just need my ECU back now!
#274 (permalink) | |
Yahoo! Got my Rotus!
David Avery 05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE 08 BMW 135i Stock visit Spyderclub.com |
#275 (permalink) |
K2S - You are very fortunate that the stud snapped there and not at the head as that would have required drilling and that is an aweful angle. Just pull the blower back off, grip the stud with some vicegrips and turn it out of there. You will damage the exposed threads but obviously that won't matter anymore. Take the remnants down to a local hardware store and you should be fine.
#276 (permalink) | |
The one in the diagram wouldn't clear though, I used something like this
![]() Quote:
#277 (permalink) |
2009 XP National Champion
![]() Join Date: Oct 2003
If these are for the rear clam, I believe they come out of behind the 2 bolts that connect the rear clam to the rocker panel on either side.
#278 (permalink) | |
What we've seen is that the idle is almost always better with the SC than prior to. Thus I think either you have a small vacuum leak and it is causing the idle air control to go wonky or you need to add a bit of static idle to the throttle(not sure how this is done on DBW). On the 05 cars you can adjust the idle set screw a bit in about 15 seconds to bump the idle a bit. These are 2 opposite conditions, but can have the same effect. 3rd option is that it may settle down as the car adapts.
#279 (permalink) |
What plugs are people going for?
I pulled my plugs last night, and the stock plugs on my 07 are NGK IFR6A's, which are Iridium. Earlier in the thread, someone suggested NGK BKR7E-11's which are the copper V-Power plugs. They'll work, but will wear a lot quicker. At least you can gap 'em ![]() I'm thinking of going with the BKR7EIX-11, which appears to be pretty comparable to the stock plug except for the heat range, and appear to be widely available. Also, is the stock gap 0.044"?
#280 (permalink) |
Selfish Asshat
I put in the BKR7EIX-11's and the stock gap is .044".
2006 Exige StormTi, BWR S/C, Nitto NT-01's (love em) 2005 Stealth Focus Midget (3 of them); 2001 Ocke Mannerfelt B-24 "Batboat" 2007 Honda S2000 (wifes car), 2003 Insight (commuter), 2000 Ford Excursion 2004 Meridan 411 and 96 SeaDoo Speedster boats 2004 Newmar Kountry Star RV and various racing karts and snowmobiles www.capitalcitymidgets.com |
