Old 10-20-2008, 09:35 AM   #281 (permalink)
Live to Drive
Bavarian Motorist's Avatar
I have a slight concern. Have had my SC in for almost 200 miles. When opening the throttle more than 50% at any RPM (usually below 5,000), there is a slight delay before there's any real forward acceleration. It feels like throttle cutting out, and it only occurs for a split second. Is this SC lag? What can this be? It's very slight but noticeable.
Old 10-20-2008, 09:43 AM   #282 (permalink)
User, Registered
fpitas's Avatar
You guys asking about plugs may want to read this thread:
To all Katana S/C users...regarding spark plugs.
Francis
Old 10-20-2008, 09:56 AM   #283 (permalink)
Installation manual: #138a is only for the 05' correct? Doesn't seem to apply to '06's. TIA
vao4v is offline   Reply With Quote
Old 10-20-2008, 10:53 AM   #284 (permalink)
Just in case you don't carry the instructions in your back pocket.
#138a says: Remove the lower 13mm bolt as shown from the throttle adapter casting. Attach the supplied support bracket. Re-install the 13mm bolt. Attach the other end of the bracket to the block using the supplied 17mm hex head screw and washer.
Doesn't apply to 06's ... right?
Old 10-20-2008, 11:53 AM   #285 (permalink)
I approve this message
skibum's Avatar
I bolted that supplied bracket up to my 06 and it fit perfect.
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934#
2004 s2000 - 378 whp 295 trq
2005 Mini Cooper S
2008 Honda Fit - 35mpg y0!
1965 Austin Mini w/ vtec
skibum is offline   Reply With Quote
Old 10-20-2008, 12:25 PM   #286 (permalink)
The bracket worked perfect on my '07 as well. It's a different bracket you are thinking of that is only used on the 05 non-DBW cars, and even then, only some of them.
2007 Ardent Red Elise, track pack, BWR SC
2004 RX-8, 350z muncher
2004 BMW 325i, kiddie hauler
brokenboy is offline   Reply With Quote
Old 10-20-2008, 12:39 PM   #287 (permalink)
Tim Taylor's Avatar
Images: 17
Is there more throttle lag than before you installed the SC kit? If so, based on my experience, this isn't normal.
While this isn't directly correlated to your situation, one of the things I do understand about the BWR (and Katana) kit over the intercooled solutions is that the latter has a little more lag due to additional piping with intercoolers.
Tim Taylor is offline   Reply With Quote
Old 10-20-2008, 02:40 PM   #288 (permalink)
2009 XP National Champion
fzust's Avatar
W/O driving it, I would say it is the bypass valve closing and normal. If you are driving at a steady speed in say 3rd gear, then slowly roll in the throttle take say 1 full second to get to 50% throttle. When you get to the 50% throttle. Mash it. Do you still have the delay?
Old 10-20-2008, 02:57 PM   #289 (permalink)
Selfish Asshat
ryoung99's Avatar
It fit perfectly on my 06 as well. So I would say it does apply to 06's.
2006 Exige StormTi, BWR S/C, Nitto NT-01's (love em)
2005 Stealth Focus Midget (3 of them); 2001 Ocke Mannerfelt B-24 "Batboat"
2007 Honda S2000 (wifes car), 2003 Insight (commuter), 2000 Ford Excursion
2004 Meridan 411 and 96 SeaDoo Speedster boats
2004 Newmar Kountry Star RV and various racing karts and snowmobiles
www.capitalcitymidgets.com
ryoung99 is offline   Reply With Quote
Old 10-20-2008, 03:51 PM   #290 (permalink)
Live to Drive
Will post updates soon...
Old 10-20-2008, 06:38 PM   #291 (permalink)
vv My Awesome Wife vv
chotto's Avatar
I sent my ECU FedEx overnight to PES on Thursday and I received it back today (Monday). I was shocked that it was returned so quickly. Thanks PES!
I dropped it in, it fired up, and NO check engine lights. The hard part now is taking it easy for 200 miles. On my inaugural voyage, a hopped up Civic pulled up to me at a light trying to get me to race. In four years of owning this car, I have never drag raced it. Boy, did I want to. I told him to meet me out at Harris Hills some day and we'll see who has a faster car.
2005 SY-BWR Supercharger, Challenger Grill, AreaP single tip exhaust, Ohlin Double Adjustables, RTDbrace, Custom Kirkey 58 Series seats, Schroth 6 pt. harnesses, Multivex mirrors, Odyssey PC625 battery, Micromirror, HID's, V2arms, Sparco removeable steering wheel, 15"/16" Rota's with RA-1's, Pagid RS 4-2 pads, Cup airbox, Saikou Michi catch cans
chotto is offline   Reply With Quote
Old 10-20-2008, 06:47 PM   #292 (permalink)
Selfish Asshat
ryoung99's Avatar
I have a few hundred miles on the car now (300+), the detonation problem has gotten better but has not gone completely away.
Today I filled up with 100 unleaded, and now there is no detonation at all. I even think there is a power increase and it already appears that the mileage has gone up. The only issue is here in Sacramento 100 (at the pump) is $7.99/gallon.
I have called the local Sunoco dealer to see what I can get the fuel for by the barrel (and if he will deliver). I am thinking about running 50/50 but we will see.
Given the issue is still there I need to check for leaks now, there is nothing that scares me more than "pinging". So much in fact I will pay $8/gallon to ensure it does not happen.
I have changed the MAS and it did not make any difference (after we cleaned the other one).
The detonation only occurs when the car is under a serious load (with 91 octane).
Anyways, time to keep looking to see if we can find an issue.
Old 10-20-2008, 07:03 PM   #293 (permalink)
Live to Drive
How can you identify pinging? Can you hear it? Sometimes the sound is very faint.
Old 10-20-2008, 07:13 PM   #294 (permalink)
Legend in my own mind
MightyMike's Avatar
Images: 9
You may want to experiment with the ratio of 100/91 octane gasoline. 50/50 mix is probably too much. Recommend that you experiment (e.g. 85/15) to see what works best.
Mike
06 ST Elise
02 SLK32 AMG
BWR Supercharged w/CharlieX tune, Borla Exhaust, OCC, ACT XTSS Clutch, Zeitronix A/F Meter, LETSLA, Manly Mounts, RTD Brace, ReVerie Diffuser, Scoops, Side Skirts, & Shifter Ball, Forcefed Spoiler, & a bunch of other stuff
MightyMike is offline   Reply With Quote
Old 10-20-2008, 07:23 PM   #295 (permalink)
Selfish Asshat
ryoung99's Avatar
I can hear it, then again I am listening for it with the radio off. As I said it did get better after we cleaned the mass air sensor, did not get any better after I replace the sensor.
Mike
Agreed, but what a pain. Any idea if you can use Octane boost and accomplish the same thing with less pain and more economical?
Although I do like the added power with 100
As long as do not tell the wife I am paying $8 a gallon maybe there is not a problem.
Old 10-20-2008, 07:32 PM   #296 (permalink)
MightyMike's Avatar
Images: 9
Certainly is a pain. I do not recommend using octane booster. It offers very little bang for your buck.
Did you change out your spark plugs?
06 ST Elise
02 SLK32 AMG
Old 10-20-2008, 07:44 PM   #297 (permalink)
Selfish Asshat
ryoung99's Avatar
I did
Old 10-20-2008, 08:42 PM   #298 (permalink)
MightyMike's Avatar
Images: 9
No vacuum leaks? Have you tried gas from another service station? I share your frustration as a couple of years back I had similiar problems with my supercharged Jeep Wrangler. I ended up getting my ECU reflashed and a slightly larger pulley.
06 ST Elise
02 SLK32 AMG
Old 10-20-2008, 08:52 PM   #299 (permalink)
skibum's Avatar
I am up to 120 miles since install and I can already feel the increase in tq without even going close to WOT. I did have a CEL for running too rich which I assume is coming from my test pipe. I cleared and will monitor.
2005 Mini Cooper S
Old 10-21-2008, 12:50 AM   #300 (permalink)
stinkyonion's Avatar
Images: 2
What size is the extended crowsfoot that is needed? Starting install next week...just trying to make sure I have everything and will need to order this.
stinkyonion is offline   Reply With Quote
