Old 10-28-2008, 11:41 AM   #341 (permalink)
Form and Function
plastique999's Avatar
anybody run dyno #'s before and after?...i will
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 10-28-2008, 12:04 PM   #342 (permalink)
Phantom's Avatar
Images: 1
I almost made it through the entire install with out any assistance, but...
HELP!
Almost 3 years ago the first mod to my 2006 Elise was a Fujita intake- No regrets; loved it- But as we all now know, the reflash is for stock- So, I blew all of the dust off the stock intake, installed it, and now I'm a little confused by the vacuum hose arrangement-
I know there are a few posts that cover this issue, but there's not quite enough detail for my feeble brain- Besides, I had packed the Fujita installation instructions neatly away with the OEM intake, and there's no mention of replumbing vacumm hoses- So, I'm not sure why / how I came up with the Fujita arrangement-
Anyway, I was able to determine this much from LT threads (see below)- The long hose (red arrow) on the back VSS barb opens the flap- The orange hose (blue arrow) with the small canister, and connected by a "T", goes to the the intake- But where does the hose marked with the green arrow terminate? It's not very long, and I do not see any obvious connections on the box-
I have also attached the factory schematic (Thanks Tim Mullen), and cross-referenced to my photograph- I beleive the schematic shows a connection on the air box for the mystery hose-
Any help would be greatly appreciated-
Grab Life by the Wheel
Phantom is offline   Reply With Quote
Old 10-28-2008, 12:10 PM   #343 (permalink)
Doublklutch
Brikhaus's Avatar
Originally Posted by plastique999 View Post
Can people comment on the PES tune? I've heard of people needing reflash?
PES Tune -- everything is firing perfectly, no issues, just pure FUN! Car purrs and growls when I need
2007 Elise, British Racing Green, Biscuit, BWR SC , PES Reflash, TP, TC, Stage II, Star Shield, soft top.
2006 Audi A3, 3.2, "S" Line, Quattro,
Brikhaus is offline   Reply With Quote
Old 10-28-2008, 12:17 PM   #344 (permalink)
Doublklutch
Brikhaus's Avatar
Very interested to see the changes
Old 10-28-2008, 04:34 PM   #345 (permalink)
thegoat's Avatar
Originally Posted by MightyMike View Post
Here's a pic of my cover. Used a band saw to trim off the edge, then used a rasp and tabletop sander to finish off. IMO, looks better than leaving the cover off entirely.
Looks great. Thanks for the reply.
2009 White w/ Carbon Birkin Super 7 (on order)
2001 Silver Honda Civic Ex (daily driver)
2006 Polar Blue Exige - Sold
2006 Chrome Orange Elise - Sold
2000 Porsche Boxster - Sold
thegoat is offline   Reply With Quote
Old 10-28-2008, 05:09 PM   #346 (permalink)
I approve this message
skibum's Avatar
Phantom - The green line in your picture goes to a small nipple on the airbox located in the picture below.
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934#
2004 s2000 - 378 whp 295 trq
2005 Mini Cooper S
2008 Honda Fit - 35mpg y0!
1965 Austin Mini w/ vtec
skibum is offline   Reply With Quote
Old 10-28-2008, 06:08 PM   #347 (permalink)
Form and Function
What pre-dyno #'s are people getting?
I'm a little concerned as my dyno stock on Dynojet was 149.8 , 110 torque...seemed a bit low.
Perhaps, my Larini SE dual exhaust is restrictive?
www.FaceNBody.com
Old 10-28-2008, 06:30 PM   #348 (permalink)
Live to Drive
Bavarian Motorist's Avatar
110 torque is very low
Old 10-28-2008, 07:10 PM   #349 (permalink)
Phantom's Avatar
Images: 1
Ah Ha! Found it Skibum!
Thanks!
Old 10-28-2008, 08:36 PM   #350 (permalink)
skibum's Avatar
You are welcome!
2005 Mini Cooper S
Old 10-29-2008, 06:38 AM   #351 (permalink)
2009 XP National Champion
fzust's Avatar
You should get the car checked out. That is low. On Dynojet we are seeing 160-170HP. Specifically get a compression & leakdown test and have the valve cover removed to inspect the Cams.
Old 10-29-2008, 06:44 AM   #352 (permalink)
Live to Drive
Could be as simple as a dirty air filter, but like Fred said, it could be serious.
Old 10-29-2008, 07:07 AM   #353 (permalink)
OSX Black hat
charliex's Avatar
plastique, post the sheet if you can, that might help give an idea as to whats going on.
Old 10-29-2008, 09:56 AM   #354 (permalink)
Form and Function
Compression and leakdown test were normal, although one was reported slightly higher, and cams were fine
I will get Green filter and cup air box
I will have DRS send me the dyno graph
www.FaceNBody.com
Old 10-30-2008, 11:31 PM   #355 (permalink)
srw
srwhitman's Avatar
Got forcefed install w/PES - no issues
I've had my car done a few weeks now. Its almost perfect - I now just get nice linear response that I just forget I even have it!
A few things though:
- seems to generate excessive heat in the engine compartment. FF suggested getting the BWR kit that removes the shielding but then someone else said thats not a good idea (would toast the trunk and/or cause the exhaust to overheat and cause a fire). Note, my engine temps are where they were before - but when you get out of the car and go to the trunk, you can definitely feel extra heat coming off the engine
- love the power. I'm actually almost scared of it! Can't really do much with it on a public road. I was hoping to check it out at the autox this weekend at Marina. I might wimp out though - its supposed to rain. I've gone in the rain before and thats a tossup - fun to drive, pain in the butt to work.
- treated the Elise to the Moroso oil pan at the same time - I figured cheap insurance (ok, not cheap but...)
- got new tires and brakes. I love the EBC brakes. Better the stock, better than the Porterfields.
- all in all, the best car now is even better
- By the way, whats WOT???? I am guessing it has something to do with putting the car to redline?
- Oh, be careful of this. I went to my dealer (SVAG) and got 2 service campaigns on the car. One was HVAC. The other was - get this - reflash the ECU to upgrade the software. Doh! Don't want to do that. They were very cool about it and marked it down but didn't do it. Great guys there - I really like that place. They are still hoping Lotus will release their SC as a kit. I was originally going to go for that but I'm glad I didn't wait.
Scott
srwhitman is offline   Reply With Quote
Old 10-31-2008, 01:48 AM   #356 (permalink)
Form and Function
Scott
Fred, or someone, can you comment on the heat generated?
WOT = wide open throttle
who did your tune?
www.FaceNBody.com
Old 10-31-2008, 07:59 AM   #357 (permalink)
Rotary Refugee
Murix's Avatar
Images: 3
It's in his title.
who did your tune?
Murix is offline   Reply With Quote
Old 10-31-2008, 08:32 AM   #358 (permalink)
fzust's Avatar
who did your tune?
Strangely, when you create more power, more heat gets generated! Darn those Laws of thermodynamics! Cooling system is up to the task.
Seriously, it hasn't been an issue. if it concerns you, a Von Hep rear panel eliminator will open it up.
Old 10-31-2008, 09:12 AM   #359 (permalink)
Form and Function
Yes, heat, heat...would be nice for IC....my current Larini SE (with rear panel eliminated) was producing so much heat on to my plastic license bracket it was melting...
I do have the Von Hep rear panel elim. (thanks to BWR), and I ordered 2bular GT3 and decat (again through you), so hopefully this setup will accomodate the flow better once the kit is on.
www.FaceNBody.com
Old 11-01-2008, 09:39 PM   #360 (permalink)
EliseAutoXr's Avatar
Well I just put the belt on and called it a night. Great instructions, everything has gone well so far.
Bradley
06 Solar Yellow Elise SM2 14... BWR Supercharger, Pagid Pads. East Tenn Region SCCA
EliseAutoXr is offline   Reply With Quote
