#361 (permalink) |
Form and Function
Installed...and driven over the weekend...kit is superb.
Dyno went from 149 to 214, and torque 110 to 141. Charlie did my tune... The engine purrs perfectly at idle, the cam switch over at 5000 RPM is very smooth. The only issue is that the AFR is 13.87 - running a little lean. I'm wondering if this could be due to the fuel injectors being different from the Katana kit...Charlie any comments?
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
#362 (permalink) |
Form and Function
Thanks to DRS for their awesome work!
Kris, Cody, and John are great to work with...here are some pics they took during install: ![]() full fender covers ![]() Intake removed - ready for S/C ![]() Cody solders instead of crimping to ensure optimal contact ![]() S/C in! ![]() compared to measly stock ![]() A peak through the rear mesh ![]() Manly engine mounts also installed ![]() On the dyno...go baby!
#364 (permalink) |
Form and Function
SCC did the work for me! Although there are threads for some who have done the "do-it-yourself" mod...
#365 (permalink) |
Ran the SC on the track yesterday. Much improved!
I agree that the car should have this much power stock. It pulls out of the corners so much better. Was a little disappointed in straight line speed. I was only slightly faster than a stock elise on the straights. But I would say that I gained a second or two or three on each lap (maybe more - wasn't timed at all and we tried to stay within eyesight of each other) at Pueblo over a stock elise with a very good driver driving. We couldn't pin point any specific place where I pulled away, just did it pretty evenly throughout the course of the lap. The car ran very, very well. Excellent job BWR!
2009 White w/ Carbon Birkin Super 7 (on order) 2001 Silver Honda Civic Ex (daily driver) ----------- 2006 Polar Blue Exige - Sold 2006 Chrome Orange Elise - Sold 2000 Porsche Boxster - Sold |
#366 (permalink) |
This is my 5th Lotus ...
is there any instructions manual on pdf file ??
thanks guys Haris
2006 Fed Aspen White Elise LSS -SOLD- 2006 Fed Phantom Black Exige BWR/CharlieX tune 2006 Fed Storm Titanium Exige -SOLD- BMW E66 745i GREEKS do it better ![]() www.lotusclub.gr/forum |
#367 (permalink) |
vv My Awesome Wife vv
Yes. The instructions are in pdf as well.
2005 SY-BWR Supercharger, Challenger Grill, AreaP single tip exhaust, Ohlin Double Adjustables, RTDbrace, Custom Kirkey 58 Series seats, Schroth 6 pt. harnesses, Multivex mirrors, Odyssey PC625 battery, Micromirror, HID's, V2arms, Sparco removeable steering wheel, 15"/16" Rota's with RA-1's, Pagid RS 4-2 pads, Cup airbox, Saikou Michi catch cans |
#368 (permalink) | |
Live to Drive
Those numbers are much better. I was worried something was wrong before!
Be an alpha male. Drive a Lotus. |
#370 (permalink) |
OSX Black hat
13.87 ? send me the dyno graph/afr graph, what load/rpm is it reaching that at?
it'll be that high as you're getting on it, but at wot it'll be at 12.1-12.5, if its that high at wot you're either using an exhaust sniffer and reading after the cat, or something else is up.
#371 (permalink) |
Clam on installation here- No regrets- The only issue was a couple of particularly tight bolts where access was cumbersome (i.e. lower alternator bolt & idler pulley)- Clam on is the way to go if you have a nice assortment of tools-
Grab Life by the Wheel |
#373 (permalink) |
I will appreciate if anyone can send them to me via email ... Thanks
#374 (permalink) | |
2009 XP National Champion
![]() Join Date: Oct 2003
Additionally, as I mentioned previously, the Mass-air sensor being dirty/ not accurate can lead to a lean condition. The injectors are a different brand from the Katana, I believe. We use Bosch, however, they are both 440cc, so that is not the issue.
#375 (permalink) |
The iridiums come pre-gapped at .044. You can't gap iridiums or you will damage them.
#376 (permalink) |
I started to do clam off, got stuck at the oem harness bar and plastic black panel, and finished clam on. Fully recommend clam on. you will save yourself hours. For clam on, remove the rear diffuser, heat shield, rear panel, the underbelly panel next to the rear diffuser, passenger side rear well (I removed both, I had a tough time getting my airbox out through the top), and boot lid.
#377 (permalink) |
Plug Whisperer
Stock plugs seem to be fine on the sub 230ish hp kits...
Best, Phil
#378 (permalink) | ||
Form and Function
Thanks Fred, yes I thought the injectors were the same cc ....will check the mass/air sensor
#379 (permalink) |
OSX Black hat
let it idle 15 minutes, then it'll settle in for a while.
dirty maf can also cause a higher idle, ecu should sit at 880-900 rpm you can regap denso iridiums Installation Guide: DENSO Iridium can't really see any issues with the bosch vs the RC, the spray patterns could be different
#380 (permalink) | |
BUT.... I do potentially have an issue. When I tightened the fuel rail down I heard plastic cracking/popping. I'm hoping that it was from the spacer, there is a small lip around the inside of the hole, that may have not been aligned and got "smashed" with the tightening. IF it was the injectors being crushed, where do I get new ones and how much do they cost? Is everyones injectors "tight", when in place or can they be twisted? Thanks for any assistance!!
Bradley 06 Solar Yellow Elise SM2 14... BWR Supercharger, Pagid Pads. East Tenn Region SCCA
