#461 (permalink) |
Doooh! Well how high is the shelf you have it on? Maybe I can find a higher shelf....
Where it CT do you live? Might have to get together so that we can help each other break our cars. (my second biggest inhibitor right now, fear of screwing it up). |
#462 (permalink) |
I would not worry about screwing it up. The instructions are great and easy to use. I did mine by myself took me like 8.5 hours. My only problem is that I do not own a laptop so I had to run between the garage and computer to look at the pix.
#463 (permalink) |
MikeS
Just started my install this past weekend and am a little more than half way through. It is a little intimidating pulling half of the car apart (clam off approach) but as has been said before, great instructions, pics, and a great on-line forum for this job.
#464 (permalink) |
Started my install last weekend, hoping to finish next weekend. As long as I had the rear clam off, installing clam hinge and other bits.
2006 polar blue Elise, VF stage II, clam hinge, von Hep exhaust, HID, Zeitronix/Dashdaq (GPS, wideband O2, EGT, fuel+oil pressure), BWR fuel rail, moroso oil pan, HD SS clutch, RTV brace, green wire mod, harnesses, Oddysey 625, alpine pdx-5, jvc avx77 head unit, jl speakers, voltmeter on dash, custom gauge pod, etc. |
#465 (permalink) |
Mine is not install and is for sale...
anyone interested please PM me. FS-Blackwatch Racing Supercharger Kit |
#466 (permalink) |
GR8 SCAPE
Intake Manifold Gasket
Getting ready to begin my install.
Instructions say to re-use intake manifold gasket. My rule has always been to use new gaskets every time. Is it OK to re-use the original gasket? If not, can I use a Toyota one and if so, what is the Toyo Part Number. Thanks. Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
#467 (permalink) | |
(562)694-2226. ask for Kris. EB Turbo
Guldstrand Motorsports Technician. Burbank, CA. PM for custom work and service quotes. |
#468 (permalink) | |
#469 (permalink) | |
GR8 SCAPE
$10.47, Part #1717722010. Regards, Wayne
#470 (permalink) |
GR8 SCAPE
SC Install Completed
Ok, Cory (cory1000) and I spent 2 1/2 days putting this in.
First, thanks to Cory for helping out. He corrected my many mistakes brought on by my only reading half the instructional sentence. I jumped on my assumptions and was off. Not a good thing!! ![]() The install was fairly simple. The instructions and photos were outstanding!! Thanks to Fred at BWR for putting together a fantastic set of directions! No parts were missing, all components lined up correctly and fit into place as needed.We did the install with the clam off. Took about an extra 1-1 1/2 hours to remove the clam. I suppose you can do it with it on, but I wouldn't. Having all that extra room makes everything so much easier to do. Only hiccup was the reflashed ECU which had a "micro-short" according to Tony at PES, when I got it back the first time. As a result the ECU wouldn't "talk" to the car, so nothing happened. I sent it back to PES over the Memorial Day holiday and they turned it around immediately. Started right up after the fix. Thanks to Patrick and Tony at PES! ![]() Cory and I drove it without the clam on and we were both impressed with the improvement of the car's performance. We got it up on the second cam, but you really can't feel it. It is so smooth. Just a tremendous amount of pull. Very nice!! ![]() This is not a hard project, just be patient and follow the instructions. Toughest part was the alternator which required some grinding on the mounting tabs so it could slide into the new position. It all looks very OEM and sounds great. Regards, Wayne P.S. I also took the opportunity to install some extra items including Innovative engine mounts, new brake lines and Defi gauges. Car should be all back together by this weekend.
#471 (permalink) |
GR8 SCAPE
Throwing Codes like confetti...
I've had the SC in for a few days, ran a few test drives up and down the street. Yesterday I did the first serious, high speed runs.
After about 15 minutes of driving, at approx. 7500RPM in 2nd gear, the CEL came on. Car felt fine, no catastrophic failure, just the light. Pulled the codes today and this what I've got: 1. P0103 - MAF circuit high input 2. P0113 - IAT sensor 1 circuit high input 3. P1302 - Manufacturer control, ignition system or misfire Anybody have any ideas about what my problems are? I can't drive it until these things are solved. Any help would be appreciated. Thanks Regards, Wayne
#472 (permalink) |
This is my 5th Lotus ...
i am in the progress of installing 440cc injectors .
Which are the suitables ? SL9-0440 or SL4-0440 Product Categories Thanks guys
2006 Fed Aspen White Elise LSS -SOLD- 2006 Fed Phantom Black Exige BWR/CharlieX tune 2006 Fed Storm Titanium Exige -SOLD- BMW E66 745i GREEKS do it better ![]() www.lotusclub.gr/forum |
#474 (permalink) |
Manifold stud removal
Hi All - hoping to get some help on step #80.
We're working on a 2006 and it mentions removing the studs for later use is this the case with an 06, just confused as to what to do here! Thanks Mick |
#475 (permalink) |
luxige
Hi Mick -
Remove the studs. There is no need to retain them. You will use four M8 bolts to re-attach the TB. Look ahead to the re-assembly, steps 157 and 158, bold print. That should make it clear.
In theory, there is no difference between Theory and Practice. In practice, there is. - Y. Berra |
#478 (permalink) | |
GR8 SCAPE
This tool is used to push the bushing on the alternator mounting tab flush with the edge of the tab. If you look at the "ear" or tab where the alternator is to be mounted, you will see a bushing in the mounting hole. That bushing has a portion of it on the inside on the mounting tab. You need to push this bushing out towards the outside edge of the mounting tab so that the alternator itself can fit into the opening. The bushing edge should be flush with the inner surface of the mounting tab. The special tool is essentially a pusher/puller mechanism that allows you to move the bushing. Very clever idea actually. Let me know if I can explain this better. Good luck. Regards, Wayne
#479 (permalink) | |
Thanks Wayne.
As per the instructions for the special tool is the diagram correct? The long bolt does not fit inside to out(going from right to left). Can we reverse and place the bolt going from the outside inwards to meet the special tool which we would have on the inside of the tab. As per the diagram I cannot get the bolt to fit from the inside as it is too long. Quote:
#480 (permalink) | |
GR8 SCAPE
I have attached a pic of how the mounting tab should look AFTER you have pushed the bushing flush. The pic shows the alternator mounting bolt and spacer tube. This is NOT the special tool. As I recall, the long bolt went in from the left side of the picture, inboard (towards center of the car). The second part of the tool went into the gap between the 2 mountings tabs (you have to separate the tool into 3 separate parts) and then a nut with washer went on the outer side of the outer tab. You then turned the bolt and it gently "rams" the bushing outwards by pushing the hollow tube against the side of the bushing. The tool seems a little counterintuitive until you start playing with it. I actually made a mistake and pushed the upper bushing out, but by reversing the tool, I was able to put it back to its original position. Regards, Wayne
