#41 (permalink) |
2009 XP National Champion
![]() Join Date: Oct 2003
Sorry, there is not. Too many intakes with different flow characteristics and diameters for the Mass-Air sensor. Can't make the numbers work for such a small market to do a ton of different tunes.
#42 (permalink) |
Legend in my own mind
Alternator Install w/Clam On
My install is going well. Doing clam-on install. At present, I am having some difficulty trying to get the alternator pushed up far enough to slide the mounting bolt through the bushing and alternator. It's a close fit and probably more an issue of leverage than tolerance. Any suggestions?
Thanks, Mike
06 ST Elise 02 SLK32 AMG BWR Supercharged w/CharlieX tune, Borla Exhaust, OCC, ACT XTSS Clutch, Zeitronix A/F Meter, LETSLA, Manly Mounts, RTD Brace, ReVerie Diffuser, Scoops, Side Skirts, & Shifter Ball, Forcefed Spoiler, & a bunch of other stuff |
#43 (permalink) | |
#44 (permalink) |
The bushing alignment tool worked quite well. Presuming that I pulled the bushing far enough to the right (as seen from below), should the alternator slide right in or should it take some force? BFH will not fit, so don't worry about me using that! Thanks!
#45 (permalink) |
Selfish Asshat
Mike,
That is pretty funny, we are at the exact same place in the install. I did move the bushing a bit to far, but was able to push it back pretty easily (just took some time). We spent about 3 hours on the car tonight and have the alternator all hooked up in it's new location. Unless I am missing something we should be done tomorrow night and then we will just be waiting for the ECU (which I sent off this morning, next day air). The biggest issue we had was getting the belt off the car, but we did it without removing the wheel well. In fact at this point the only things we have taken off the car is the hatch and right wheel. My buddy works on cars all day long and must be double jointed to get to some of the spots he gets to. Rick
2006 Exige StormTi, BWR S/C, Nitto NT-01's (love em) 2005 Stealth Focus Midget (3 of them); 2001 Ocke Mannerfelt B-24 "Batboat" 2007 Honda S2000 (wifes car), 2003 Insight (commuter), 2000 Ford Excursion 2004 Meridan 411 and 96 SeaDoo Speedster boats 2004 Newmar Kountry Star RV and various racing karts and snowmobiles www.capitalcitymidgets.com |
#46 (permalink) |
Good luck with the remainder of your install. I'm away to Atlanta for the rest of the week, then I'm going on a quick vacation, so I will not be able to finish up until sometime late next week.
#47 (permalink) | |
that dang tensioner nut. Phase 2 is a ratchet tie down to hold the breaker bar /tensioner while I attach the belt. Of course now I have a tilt claim and can reach it easily from the top. One belt change aggravation pays for the tilt clam.
2005 Elise Storm Titanium |
#48 (permalink) |
Selfish Asshat
Jim,
Thanks for the advise. We have to put the belt back on tonight and will figure something out, infact I better call my buddy DaveSki and remind him to bring a tool or two that we can use. If we need to cut down a socket we better get going on that one. I see the need for the breaker bar as you cannot get a ratchet in there. Is there no one else installing their BWR right now? I figured this thread would be hopping with stories, questions and photos. If I am the first one done the rest of you should be ashamed as I got mine very late as I was out of the country the last week of the deal. If there are any others in NorCal that would like help putting theirs on, Dave and I would be happy to assist. Like I said we are having a blast and I have a lift at the house which does help. Rick
#49 (permalink) |
I use a 6 point regular short 19mm socket and either an extending handle socket wrench or breaker bar + long pipe over the handle. Works great!
#50 (permalink) |
Love is More
Fred beat me to it while I was drawing.
I did the belt on my own by using a breaker-bar that was sleeved by a steel pipe that I could slide up the shaft to clear the floor then slide down and touch the floor past 6 o'clock. Attached is a picture for demonstration. Tell me if there is something wrong with doing it this way. The pressure let the pipe stick and I could remove the belt on my own. Essentially you slide the pipe down when its past 6 o'clock and let it catch against the floor.
Will WTB: Elise Hardtop with Hardware - Storm Ti. (Color Code B121) Please send PM Elise: My process of adding exige side scoops (+ Front Mesh) | 2005 Lotus Elise : Sport Pack : Biscuit Touring Pack : Storm Ti | BWR Supercharger | Exige Side ducts and front mesh | LETSLA Short Shifter (ordered) | |
#51 (permalink) |
2007 Phantom Black Elise
What periodic service is required if any for the SC? Are there any items (belts ect.) that we should know part numbers in the event we have to purchase parts locally. Is there a list of do's and don'ts when driving a SC vehicle?
#52 (permalink) |
The SC manual tells you to check and replace the oil in the SC every now and then, and the oil is a standard Ford part. The belt is a standard goodyear gatorback that has the part number printed right on it. You'd replace the belt at the same interval Lotus tells you to normally replace the belt.
Don't drive slow. It makes the SC depressed and one day you'll wake up and find it's walked out on you. |
#54 (permalink) | |
Doublklutch
and PES REFLASH -- installed and tuned by EU AUTOWERKS (Toronto & "the Bridge"). I am speechless -- this baby is fast fast fast. ![]() ![]() ![]() ![]()
2007 Elise, British Racing Green, Biscuit, BWR SC , PES Reflash, TP, TC, Stage II, Star Shield, soft top.2006 Audi A3, 3.2, "S" Line, Quattro, |
#56 (permalink) | |
Selfish Asshat
Congrats, it appears you are first. If I can get my ECU back maybe we can have the distinction of being the first DIY for the group. Glad you are happy, now I am even more motivated to get it done tonight. Rick
#57 (permalink) | |
Wow, this makes my job easier, thanks! We also strongly recommend Race gas on track days and good top tier premium the rest of the time. Change the oil regularly, etc. etc.
#58 (permalink) | |
Doublklutch
![]() ![]() I have noticed that the sound from my stage II exhaust has gotten a little tamer but sweeter. The cam shift @ 5200 is smoother not as much "kick" but a boost. Courtney @ EU Autowerks did an amazing job at an amazing price. ![]() Wow -- ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#59 (permalink) |
I approve this message
I had an interesting break thru today while on the phone with PES. I was speaking with Tony and he told me that header & decat would not make the car run lean like an intake would. This was somewhat nice news to hear but I am still somewhat skeptical.
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934# 2004 s2000 - 378 whp 295 trq 2005 Mini Cooper S 2008 Honda Fit - 35mpg y0! 1965 Austin Mini w/ vtec |
#60 (permalink) |
It will run leaner with the header & exhaust, however as it is comprehended in the closed-loop control of the ECU, the car will adapt over time. with a different intake, the Mass-Air sensor diameter is changed and thus calibration of the closed-loop control is changed and no adaption will occur.
