Old 10-12-2008, 01:56 PM   #121 (permalink)
thegoat's Avatar
hockey puck!
2009 White w/ Carbon Birkin Super 7 (on order)
2001 Silver Honda Civic Ex (daily driver)
2006 Polar Blue Exige - Sold
2006 Chrome Orange Elise - Sold
2000 Porsche Boxster - Sold
thegoat is offline   Reply With Quote
Old 10-12-2008, 05:16 PM   #122 (permalink)
rstutts's Avatar
2 hockey pucks!
2005 Solar Yellow Elise touring package, star shield, hard top, soft top, ACT HDSS clutch, Saikou Michi catch cans, LED tail lights and VF II, 288 whp ()
2001 Green Toyota Tacoma, 4 x 4
2008 Red 5455 Massey Ferguson, 6 x 6, cab, ipod, GPS navigation, regular beer holder
2001 Yellow Cat D3G-LGP, custom made beer holder
rstutts is offline   Reply With Quote
Old 10-12-2008, 05:32 PM   #123 (permalink)
thegoat's Avatar
2? I will have to check my box again. I only dug around until I found one.
Old 10-12-2008, 05:49 PM   #124 (permalink)
rstutts's Avatar
Maybe since I am mechanically challanged, they thought I needed 2.
I have 2 questions, that has nothing to do with hockey pucks.
My manual calls for 5W/40 motor oil. I went to a couple of places to get Mobil1, but both places said they have never heard of 5W/40. So is there a 5W/40 oil or do you use 5W/30?
Question number 2: I do not run on the track, although I sure floor it alot on the back roads. Since my car now has a s/c on it, do I still use the stock spark plugs that the manual calls for, or the cooler one I have read about on here?
Thanks. Rick
Old 10-12-2008, 06:03 PM   #125 (permalink)
2009 XP National Champion
fzust's Avatar
Thanks. Rick
The manual recommends 1 heat range cooler. If you look around a bit you can find the 5w40 Mobil 1 it is for diesel engines. You want the 5w for the cold start crank bearing tolerance and the 40w for the valve train protection. if not you can use the Havoline synthetic.
Old 10-12-2008, 06:03 PM   #126 (permalink)
2007 Phantom Black Elise
Phil S's Avatar
Drove an Elise with the BWR SC kit today. I don't understand why everyone doesn't have one. I've booked my install and can't wait. If we can get an intercooler kit the car would be close to perfection. (Back to work Fred!)
Cheers......Phil
Phil S is offline   Reply With Quote
Old 10-12-2008, 09:55 PM   #127 (permalink)
thegoat's Avatar
The schucks affiliate I went to try and find some colder spark plugs had the Mobil 1 in 5w/40. As fzust said, it is labeled for turbo diesels.
Also, I had to order the iridiums online because my local auto store didn't carry them. I guess since I have to wait for those now, I will also switch over to a green air filter. Fzust, there is no problem with desnorkling and running a green filter with this kit, right? I am at altitude, so maybe the extra airflow will help decrease my loss.
On the altitude loss, would it be ok to run a smaller pulley without a tune? Or is this something I should get all the aftermarket SC's in the area together for and do a group buy on flying Charlie out for high altitude smaller pulley tune?
Regarding the MAF, I found mine to look a little coated with a black film. Did you say that using an electronic terminal cleaner spray would not work to clean it? I used that on my boxster, when I unfortunately had one, to clean the MAF, and it seemed to work fine.
Sorry - long sloppy post.
Old 10-12-2008, 10:16 PM   #128 (permalink)
sleepe's Avatar
What is the part number for the Denso Iridiums that are one step colder than oem?
Robert
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is offline   Reply With Quote
Old 10-12-2008, 10:18 PM   #129 (permalink)
thegoat's Avatar
bkr7eix-11
Old 10-13-2008, 03:51 AM   #130 (permalink)
rstutts's Avatar
Which is better NGK BKR7E 11 or BKR7EIX 11?
Old 10-13-2008, 04:05 AM   #131 (permalink)
Doublklutch
Brikhaus's Avatar
Cheers......Phil
Yes you did -- I liked your reaction when you got back form the little test drive!:coo lnana:
and I agree!
2007 Elise, British Racing Green, Biscuit, BWR SC , PES Reflash, TP, TC, Stage II, Star Shield, soft top.
2006 Audi A3, 3.2, "S" Line, Quattro,
Brikhaus is offline   Reply With Quote
Old 10-13-2008, 06:39 AM   #132 (permalink)
fzust's Avatar
Green filter is no problem, de-snorkle is no problem, but loses power(at least we proved it in our testing) Makes more noise however.
I would not recommend the smaller pulley with the same tune. Your gas at altitude is crappier to account for the thinner air!
Terminal cleaner may work, but I don't know if it will damage the thin film element.
Old 10-13-2008, 06:43 AM   #133 (permalink)
Live to Drive
Bavarian Motorist's Avatar
I don't even have my car back yet and I already am thinking I want more power..... Stage 2 upgrade...
Old 10-13-2008, 06:57 AM   #134 (permalink)
Phantom's Avatar
Images: 1
2 hockey pucks!
Everything's here!
Thanks!
Grab Life by the Wheel
Phantom is offline   Reply With Quote
Old 10-13-2008, 07:34 AM   #135 (permalink)
Yahoo! Got my Rotus!
dma550's Avatar
I have a green filter and my snorkel is sitting on my workbench. How much less power with it missing?
David Avery
05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE
08 BMW 135i Stock
visit Spyderclub.com
dma550 is offline   Reply With Quote
Old 10-13-2008, 08:11 AM   #136 (permalink)
Maybe the combination of the two (more air) disturbs the flow of air past the MAF, confusing the readings and the tune.
It would seem that the de-snorkle and the stockfilter would keep the airflow smoother and possibly not lose any power?
Was that combo tested, if not what's your theory Fred?
vao4v is offline   Reply With Quote
Old 10-13-2008, 08:35 AM   #137 (permalink)
fzust's Avatar
I must remember NOT to post when tired. OK, what I meant was that the greenfilter works great, no issues. When we took a de-snorkled car to the dyno, we saw that the power was off a bit(2-3hp max). Tony made a makeshift snorkle out of PVC and because we got some cooler air, we got the power back. Remember, this is on the dyno, not on the road, so you might not see the same losses on the road, I am just calling it as I see it.
I like the snorkle for 2 reasons: 1. I don't like the car loud when I am driving around(I have FrankenLotus car for that!) and because I think it helps reduce the amount of crap that makes it into the intake/filter. Because the intake is on the side right where the wheels are, it catches alot of junk. That said, your mileage may vary, some restrictions do apply, not valid in all 50 states....
Old 10-13-2008, 10:42 AM   #138 (permalink)
Love is More
Whiskey's Avatar
I got the s/c attached last night. I think the biggest problem I am having is the wiring. The new extention wiring for the alternator seems to be a little short. It reaches but there is not a whole lot excess length. I am heading back out there to do another 15 - 20 numbers!
I had the same problem, so be careful with your wiring. The alternator cable should not be too tight. The engine moved enough that it pulled/sheared the wires going into the alternator. I had to solder a wire into the plug and extend and redo the other wires. Take a look at the picture in the instruction manual again. I didn't route mine properly the first time and ended up on the side of the road. Luckily, only a half-mile from my house and with a friend available for a ride.
The shear didn't appear for a few hundred miles. You will know that this wire is an issue if you notice your lights dimming and maybe a flickering MIL due to the slight short that occurred before a full sever of the wire.
Check the routing of your alternator's wiring and make sure it's exaclty as the picture displays. I haven't had the wiring problem since the correction.
Will
WTB: Elise Hardtop with Hardware - Storm Ti. (Color Code B121) Please send PM
Elise: My process of adding exige side scoops (+ Front Mesh)
| 2005 Lotus Elise : Sport Pack : Biscuit Touring Pack : Storm Ti | BWR Supercharger | Exige Side ducts and front mesh | LETSLA Short Shifter (ordered) |
Whiskey is offline   Reply With Quote
Old 10-13-2008, 12:47 PM   #139 (permalink)
jallingt's Avatar
If your alternator harness wires ever break at the gray plug you can get new pig-tales and re-wire the plug. Toyota part, ~$6ea. The replacement pig-tales actually seem to be heavier than the orginals.
2005 Bordeaux Met #21 (HT, Touring, Quicksilver ext, TRM F1 wheels, Stan Stud, HID lights, BWR S/C,Filled motor mounts, catch can, no camber shims, Tillett saddles)
2004 Audi S4 Sedan (Tip, GAIC Chip, AWE Cat-back, Team Dyanmics Pro 1.2 wheels, H-sport sway bars)
2002 F-350 (Powerstroke, 4x4, Banks power pack, 6th alternator)
Couple nice bicycles, way too many snow skis.
jallingt is offline   Reply With Quote
Old 10-13-2008, 07:49 PM   #140 (permalink)
rstutts's Avatar
Thanks yall. I went out and looked and it is wired like the picture.
